@e76c517
05/01/15 18:52:51 |
Sebastian Huber |
score: Fine grained locking for semaphores
Update #2273.
4.115
@cc18d7b
04/30/15 11:12:54 |
Sebastian Huber |
score: Fine grained locking for message queues
Aggregate several …
4.115
@c654b525
04/30/15 11:18:45 |
Sebastian Huber |
score: Delete _CORE_message_queue_Flush_support()
Check the number of …
4.115
@f5d6c8b
04/27/15 14:25:52 |
Sebastian Huber |
score: Delete Thread_queue_Control::timeout_status
Use a parameter …
4.115
@cc366ec
04/24/15 10:02:20 |
Sebastian Huber |
score: New thread queue implementation
Use thread wait flags for …
4.115
@383cf42
04/22/15 09:15:46 |
Sebastian Huber |
score: More thread queue operations
Move thread queue discipline …
4.115
@568af83
04/21/15 08:17:13 |
Sebastian Huber |
score: Add Thread_queue_Operations
Replace the …
4.115
@02c4c441
04/23/15 08:01:22 |
Sebastian Huber |
score: Add Thread_queue_Control::Lock
Move the complete thread queue …
4.115
@08fe84b
04/22/15 08:06:05 |
Sebastian Huber |
score: Generalize _Event_Timeout()
Add a thread wait timeout code. …
4.115
@b7cff7fe
04/26/15 13:22:20 |
Sebastian Huber |
score: Reduce thread wait states
Merge THREAD_WAIT_STATE_SATISFIED, …
4.115
@776a50c
05/04/15 07:32:00 |
Sebastian Huber |
Filesystem: Thread life protection for env changes
4.115
@4a3c920
05/04/15 07:30:21 |
Sebastian Huber |
libcsupport: Fix umask() locking
Delete comment related to an …
4.115
@2b0bbc4
05/04/15 07:29:38 |
Sebastian Huber |
libcsupport: Avoid Giant lock in rtems_verror()
4.115
@c07c85f
05/04/15 07:24:10 |
Sebastian Huber |
Filesystem: Use lock for deferred release
4.115
@5f7f469
05/04/15 07:22:26 |
Sebastian Huber |
libcsupport: Avoid Giant lock in _times()
4.115
@d5a9c80
05/04/15 06:56:14 |
Sebastian Huber |
rtems: Use once mutex for timer server init
4.115
@a382010c
04/10/15 13:31:31 |
Sebastian Huber |
score: New timer server implementation
Use mostly the standard …
4.115
@fd53d25
04/24/15 07:53:58 |
Sebastian Huber |
score: Move _Watchdog_Tickle()
Make internal function …
4.115
@1ccbd052
04/15/15 08:53:29 |
Sebastian Huber |
score: Add Watchdog_Iterator
Rewrite the _Watchdog_Insert(), …
4.115
@6d253941
04/15/15 14:28:42 |
Sebastian Huber |
score: Add _Watchdog_Acquire|Release|Flash()
Update #2307.
4.115
@2903090
04/15/15 09:26:46 |
Sebastian Huber |
score: Add header to _Watchdog_Remove()
Add watchdog header parameter …
4.115
@a61d385
04/24/15 08:51:24 |
Sebastian Huber |
score: Optimize _Thread_queue_Compare_priority()
4.115
@56729d8
04/23/15 19:29:56 |
Sebastian Huber |
score: Delete STATES_WAITING_ON_THREAD_QUEUE
Avoid the usage of the …
4.115
@22788bc
04/23/15 11:01:05 |
Sebastian Huber |
score: _Thread_queue_Extract()
Remove thread queue parameter from …
4.115
@cf255ff
04/24/15 09:47:35 |
Sebastian Huber |
score: Add _SMP_Assert()
4.115
@7e19330e
05/19/15 09:37:26 |
Sebastian Huber |
score: Fix assert
4.115
@b1b5ddf0
05/15/15 11:17:16 |
Sebastian Huber |
smptests/smpcache01: Restructure
Restructure to avoid large maximum …
4.115
@a0001d6
05/14/15 09:17:00 |
Sebastian Huber |
Remove obsolete rtems_clock_major/minor
These global variables are …
4.115
@47c9c083
05/12/15 08:53:47 |
Sebastian Huber |
score: Avoid Giant lock in _Objects_Id_to_name()
This prevents a …
4.115
@be0366b
05/10/15 19:30:26 |
Sebastian Huber |
score: Fix scheduler helping protocol
Account for priority changes of …
4.115
@438e78e
05/04/15 21:32:48 |
Joel Sherrill |
mrm332-testsuite.tcfg: Add fileio
4.115
@5b9dfff5
05/06/15 14:39:12 |
alexander.krutwig |
sptests/spcontext01: Check FPU task combinations
4.115
@a6502a58
05/06/15 09:54:19 |
Sebastian Huber |
score: Fix Thread_Control and Thread_Proxy_control
Fix layout of the …
4.115
@c639cf2
04/30/15 13:26:23 |
Sebastian Huber |
score: Delete unused Thread_queue_Timeout_callout
4.115
@a8e4352
04/29/15 05:24:00 |
Chris Johns |
libmisc/cpuuse: Top support for current load.
The cpuuse top command …
4.115
@40d24d5
04/26/15 18:26:50 |
Sebastian Huber |
sptests/spstkalloc02: Fix namespace issue
Avoid collision with …
4.115
@7f53035
04/27/15 08:11:47 |
Sebastian Huber |
bsps/sparc: Use inline functions for cache manager
4.115
@4bf2a6aa
04/27/15 07:40:16 |
Sebastian Huber |
bsps/cache: Clarify range functions support
4.115
@1602bf3
04/24/15 17:55:04 |
Hesham Almatary |
Fix broken BSPs due to a shared cache function declaration.
Get rid …
4.115
@f60b4f93
04/27/15 07:10:49 |
Sebastian Huber |
dosfs: Fix warning fix
4.115
@3dead51
04/26/15 16:28:08 |
Hesham Almatary |
Fix or1k C++ build failure
Closes #2329
4.115
@d83127e
04/24/15 06:36:33 |
Sebastian Huber |
posix: Use right thread dispatch disable function
4.115
@f329353
04/23/15 13:25:13 |
Sebastian Huber |
score: Fix POSIX thread join
A thread join is twofold. There is one …
4.115
@694f155
04/22/15 14:10:24 |
Joel Sherrill |
sp13/system.h: Account for all message buffers
There may be a way to …
4.115
@5a8cd17
04/19/15 01:28:22 |
Joel Sherrill |
simsh*.tcfg: Add iostream
4.115
@d9ef7ebe
04/19/15 01:27:56 |
Joel Sherrill |
gensh2-testsuite.tcfg: Add iostream
4.115
@07d9954b
04/19/15 01:27:40 |
Joel Sherrill |
gensh1-testsuite.tcfg: Add iostream
4.115
@ba885bd
04/19/15 01:27:09 |
Joel Sherrill |
mbx8xx/include/bsp.h: Add include of <rtems/irq.h>
4.115
@9a9614e5
04/19/15 01:26:41 |
Joel Sherrill |
ods68302-testsuite.tcfg: Add iosteam
4.115
@f620ac7
04/19/15 01:26:20 |
Joel Sherrill |
mrm332-testsuite.tcfg: Add iostream and sptls02
4.115
@0c87234f
04/19/15 01:25:44 |
Joel Sherrill |
mcf5225x-testsuite.tcfg: Add iostream
4.115
@e38fdc2
04/19/15 01:25:22 |
Joel Sherrill |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add sptls02
4.115
@2e9baac
04/18/15 15:23:51 |
Joel Sherrill |
lm3s3749-testsuite.tcfg: Add cdtest
4.115
@9cac9c5
04/23/15 11:09:56 |
Sebastian Huber |
score: Delete _Thread_queue_Dequeue_priority()
4.115
@be6c461
04/23/15 08:27:07 |
Sebastian Huber |
score: _CORE_mutex_Seize_interrupt_blocking()
Move some code into …
4.115
@9f10911
04/22/15 19:29:21 |
Sebastian Huber |
score: Delete Thread_queue_Control::state
Use a parameter for …
4.115
@d349e8a4
04/21/15 07:21:29 |
Sebastian Huber |
score: Fix priority message queue insert
Move the linear search into …
4.115
@b0686b4
04/22/15 11:57:18 |
Sebastian Huber |
score: Delete _CORE_RWLock_Timeout()
This function was identical to …
4.115
@49d4364
04/22/15 09:35:14 |
Sebastian Huber |
score: Delete bogus THREAD_QUEUE_WAIT_FOREVER
It makes no sense to …
4.115
@36413201
04/22/15 07:22:27 |
cederman |
smptests/smpcache01: Enable interrupts before waiting for other CPUs
4.115
@d3802bb5
04/20/15 07:50:01 |
Sebastian Huber |
score: Delete object control block ISR lock
The Objects_Control::Lock …
4.115
@1041de1
04/20/15 07:45:10 |
Sebastian Huber |
score: Add _Thread_Get_interrupt_disable()
Remove _Thread_Acquire() …
4.115
@413b9e28
04/20/15 07:49:39 |
Sebastian Huber |
score: Modify _Thread_Dispatch_disable_critical()
Return the current …
4.115
@3bf4a9fa
04/20/15 06:52:52 |
Sebastian Huber |
score: _Objects_Get_isr_disable()
Do not disable thread dispatching …
4.115
@4db0ae8e
04/20/15 06:45:41 |
Sebastian Huber |
Use ISR_lock_Context instead of …
4.115
@1981b469
04/19/15 08:27:08 |
Sebastian Huber |
score: Add _ISR_lock_ISR_disable/enable()
4.115
@26c142e5
04/17/15 10:05:16 |
Sebastian Huber |
score: Refactor SMP cache manager support
4.115
@3d597c0
04/18/15 16:25:51 |
Hesham Almatary |
Rename or1ksim BSP to generic_or1k
or1ksim BSP was initially named …
4.115
@491434cd
04/15/15 19:39:56 |
Joel Sherrill |
sp13: Document message buffer usage and adjust configuration
4.115
@3985e758
04/17/15 14:46:08 |
Joel Sherrill |
user/libpci.t: Make it build and clean up
4.115
@c5d86ec0
04/17/15 14:45:05 |
Joel Sherrill |
or1k-utility.h: Add missing end of C++ header pattern
closes 2326.
4.115
@41b37e00
03/27/15 13:08:10 |
Martin Galvan |
score: Improve assert
While cpu_self->thread_dispatch_disable_level …
4.115
@b8cdc38b
04/17/15 08:46:02 |
Sebastian Huber |
sptests/sp52: Reduce clock tick interval
This helps on slow simulators.
4.115
@c7a6508
04/17/15 07:18:05 |
Sebastian Huber |
Fix build for non-SPARC targets
4.115
@8d6fd40
04/17/15 06:45:50 |
Sebastian Huber |
sapi: Avoid declaration in source, fix type
4.115
@a211a732
04/16/15 20:24:59 |
Sebastian Huber |
score: Fix _TOD_Set_with_timestamp()
Update the current time before …
4.115
@c77e3cb
04/14/15 07:31:05 |
Daniel Hellstrom |
LEON3: gptimer drvmgr init simplified wrt boot
4.115
@9fe249d
04/14/15 07:28:54 |
Daniel Hellstrom |
LEON3: move timer variable to where initialized
4.115
@efd43ad
04/14/15 07:24:33 |
Daniel Hellstrom |
LEON3: simplify amba initialization
4.115
@628e739
04/14/15 06:18:27 |
Daniel Hellstrom |
LEON3: clock irq always same as timer instance
The leon.h already …
4.115
@291c5391
04/13/15 11:12:33 |
Daniel Hellstrom |
DRVMGR: remove struct driver registration func
4.115
@4c9c46d
04/13/15 10:58:37 |
Daniel Hellstrom |
DRVMGR: clean-up DRV_OPS_NUM
4.115
@bef5e23e
04/13/15 09:31:53 |
Daniel Hellstrom |
DRVMGR: renamed RES_EMPTY to DRVMGR_RES_EMPTY
4.115
@4d3e70f4
04/13/15 09:26:52 |
Daniel Hellstrom |
DRVMGR: KEY_TYPE now a enum drvmgr_kt
4.115
@14d55deb
04/13/15 09:12:04 |
Daniel Hellstrom |
DRVMGR: renamed info_dev to get_info_dev
4.115
@246fe22
04/13/15 09:07:54 |
Daniel Hellstrom |
DRVMGR: change name of freq_get to get_freq
4.115
@bb2f220
04/13/15 08:49:47 |
Daniel Hellstrom |
DRVMGR: renamed private drv_mgr and its struct name
4.115
@bf2c3f8b
04/13/15 08:47:22 |
Daniel Hellstrom |
DRVMGR: updated README
4.115
@4f09060
04/13/15 08:32:50 |
Daniel Hellstrom |
DRVMGR: only build on SPARC platform
4.115
@4a7d1026
04/13/15 08:25:52 |
Daniel Hellstrom |
sparc bsps: updated license to rtems.org
4.115
@e53daed
04/09/15 14:09:42 |
Daniel Hellstrom |
LIBPCI: updated license to rtems.org
4.115
@0decc806
04/09/15 14:09:13 |
Daniel Hellstrom |
DRVMGR: updated license to rtems.org
4.115
@cc3f87c0
04/09/15 06:36:39 |
Daniel Hellstrom |
DRVMGR: removed a goto and added comments
4.115
@1b645c3
04/08/15 15:00:43 |
Daniel Hellstrom |
LIBPCI: corrected documentation
4.115
@f4bf22c
04/08/15 08:51:45 |
Daniel Hellstrom |
LIBPCI: new implementation private header file
- new implementation …
4.115
@1f4f1e2e
04/08/15 08:39:41 |
Daniel Hellstrom |
LIBPCI: various comment/unsed clean-ups
4.115
@346a9a5
04/08/15 08:16:51 |
Daniel Hellstrom |
LIBPCI: use enum with pci_system_type
4.115
@15620f5b
04/08/15 08:03:45 |
Daniel Hellstrom |
LIBPCI: use RTEMS_INLINE_ROUTINE
4.115
@dc623099
04/08/15 08:01:48 |
Daniel Hellstrom |
LIBPCI: moved comment out of license header
4.115
@e189f241
04/08/15 08:00:48 |
Daniel Hellstrom |
PCI BUS: moved comment out of license header
4.115
