@805ef2f2
11/30/13 19:53:41 |
Sebastian Huber |
arm: Add ARMv7-M SHCSR register bits
4.115
@c369e84
01/07/14 10:41:29 |
Sebastian Huber |
bsp/realview-pbx-a9: Fix PL111 color encoding
4.115
@5b85cca
01/01/14 18:40:31 |
Sebastian Huber |
bsps/arm: Use handlers for PL111 set up/tear down
4.115
@e83be28
01/09/14 23:57:08 |
Chris Johns |
testsuite/rtems++: Output format change.
Alter the output to avoid …
4.115
@e327e69
01/09/14 22:05:54 |
cynt6007 |
libbsp tm27.h: Add Doxygen file header to all tm27.h
4.115
@8d7c3ca
01/09/14 21:59:21 |
Joel Sherrill |
tasksetpriority.c: Remove obsolete comment
4.115
@05b3db65
01/09/14 15:50:18 |
hazirguo |
spsize/size.c: Fix typo.
From pull request at …
4.115
@46123cf2
01/09/14 15:41:44 |
cynt6007 |
libtests: Add contents to rbheap and stackchk documentation files
4.115
@4e108d79
01/09/14 15:41:17 |
cynt6007 |
tmtests: Add contents to multiple documentation files
4.115
@a19a7077
12/18/13 00:01:11 |
strauman |
posix: fix race condition between pthread_create and capture engine
4.115
@3096f5c9
12/06/13 22:13:27 |
Daniel Ramirez |
libtests/termios01: Add tests for cfsetspeed() and cfmakeraw()
4.115
@1d325e7b
12/06/13 08:52:26 |
radustoma |
sparc BSP shared: Improve Doxygen
Add doxygen to the header files in …
4.115
@8950204
12/19/13 04:58:53 |
Daniel Ramirez |
libtests/uid01: Fix Copyright information
4.115
@7cf81ba4
12/19/13 04:58:53 |
Daniel Ramirez |
libtests: added test to confirm patch fixes bug
4.115
@66bf2cc9
12/19/13 00:54:53 |
allanh |
mw_uid: corrects uid_read_message short timeouts
4.115
@2b03a62
11/01/13 13:59:41 |
Jim Panetta |
NTP: Sync time correctly when receiving broadcast updates
1) The …
4.115
@78c84df
06/10/10 13:10:00 |
Gerardo Puga |
PR 1548: ERC32 console stops working when UART error flags are set
4.115
@35b8f48a
12/06/13 18:21:20 |
Daniel Ramirez |
libcsupport: Refactor rtems_deviceio_errno
Renames …
4.115
@a77c3719
01/03/14 12:35:39 |
zsoltisharkboy |
powerpc/mvme3100: Improve Doxygen
4.115
@d48ac181
01/01/14 21:30:24 |
zsoltisharkboy |
m68k/gen68360: Improve Doxygen
4.115
@540b771a
01/05/14 20:33:57 |
radustoma |
sp16, sp17, and sp20: Documentation Fixes
Fix the documentation for …
4.115
@e87b300
01/05/14 21:43:54 |
zsoltisharkboy |
shared vmeUniverse: Improve Doxygen
4.115
@d4960953
01/02/14 17:43:18 |
radustoma |
genmcf548x: Improve Doxygen
Add doxygen to the header files in the …
4.115
@7388557
01/03/14 20:18:58 |
radustoma |
av5282: Improve Doxygen
4.115
@73a7713
01/08/14 18:48:37 |
cynt6007 |
fstests and libtests: Add contents to multiple documentation files
4.115
@893aac16
01/08/14 00:31:32 |
Joel Sherrill |
rhealstone: Add start end and messages
4.115
@bc55e4f
01/08/14 00:02:46 |
Joel Sherrill |
psximfs02: Clean up output
4.115
@f3f30498
01/08/14 00:01:55 |
Joel Sherrill |
spfifo02: Clean up output
4.115
@23d53e8a
01/07/14 21:08:48 |
cynt6007 |
fsdosfsformat01.doc: Add contents
4.115
@d8cd49cb
01/07/14 19:33:36 |
cynt6007 |
fsbdpart01.doc: Add contents
4.115
@564ce0f
12/06/13 02:21:05 |
Daniel Ramirez |
libcsupport: implemented termios functions cfsetspeed and cfmakeraw
4.115
@b6c1578
01/05/14 17:17:08 |
Joel Sherrill |
rhealstone: Add rh prefix to all test names
This makes them easier to …
4.115
@e8c7dbe7
01/05/14 16:39:34 |
Joel Sherrill |
rhealstone/*.c: Add Print_Warning() call to indicate debug enabled
4.115
@acc636e1
01/05/14 16:38:57 |
Joel Sherrill |
rhealstone/README: Formatting
4.115
@19e9bf8
01/04/14 19:58:44 |
Daniel Ramirez |
Added Rhealstone benchmark to testsuites
The Rhealstone benchmarks …
4.115
@4470ae9b
01/04/14 17:07:56 |
Joel Sherrill |
sp09: Remove partition specific parts
4.115
@f17a9269
01/04/14 17:06:20 |
Joel Sherrill |
spregion_err01: Clean up comments
4.115
@7132d3d
01/04/14 17:04:51 |
Joel Sherrill |
sppartition_err01: Remove dead parts, reduce, and clean up.
Also fix …
4.115
@524e785
01/03/14 19:12:43 |
shailysangwan |
psxtime: Added doc file.
4.115
@12f81c09
01/03/14 14:25:14 |
mjuvekar0 |
pskey09, sp17: documentation cleanup.
4.115
@6b1ee025
01/03/14 14:14:49 |
zsoltisharkboy |
idp: Add doxygen headers.
4.115
@255178e
01/02/14 19:22:36 |
mjuvekar0 |
sptests: Refactor sp09 into sppartition_err01 and sp09.
4.115
@56ac38e
01/02/14 15:40:06 |
radustoma |
gen68340: Add doxygen header files.
4.115
@3bba3f58
12/30/13 20:24:12 |
radustoma |
gen68302: Add doxygen headers.
4.115
@bbe0542
12/30/13 20:07:13 |
zsoltisharkboy |
m32rsim: Add doxygen headers.
4.115
@7c70c1d7
12/30/13 17:08:13 |
radustoma |
m68k_csb360: doxygen improvement
4.115
@85f2486b
12/30/13 18:54:46 |
Joel Sherrill |
libbsp misc: Fix comment formatting
4.115
@41aebd8
12/30/13 17:40:26 |
zsoltisharkboy |
m32cbsp: Add doxygen headers.
4.115
@fa01e0d0
12/30/13 16:48:57 |
radustoma |
i386/pc386: Add doxygen file headers.
4.115
@19530271
12/30/13 15:53:22 |
Joel Sherrill |
sp09: Remove region test references
4.115
@8211b9f
12/30/13 15:48:08 |
Joel Sherrill |
spregion_err01: Remove unneeded fluff copied from sp09
The goal is to …
4.115
@dfcb3ac
12/30/13 03:56:13 |
mjuvekar0 |
spregion_err01: New test refactored from sp09
4.115
@d281de9
12/28/13 22:32:17 |
zsoltisharkboy |
h8sim: Add Doxygen directives
4.115
@7183e01d
12/28/13 10:05:26 |
radustoma |
Test suite documentations corrections and fixes.
Correct the …
4.115
@9bb28849
12/26/13 18:51:20 |
zsoltisharkboy |
libbsp/m68k: Add doxygen to m68k shared files.
4.115
@b23ef87
12/26/13 16:10:52 |
rishisharma7361 |
psx03: Add doc file
4.115
@d2d4a8f9
12/25/13 12:06:19 |
mjuvekar0 |
utf8proc1/spedgsched01: minor fixes in test document files
4.115
@03d184d0
12/24/13 21:58:18 |
radustoma |
lm32_milkymist: improve doxygen
4.115
@5b4c479
12/24/13 19:13:13 |
radustoma |
lm32_evr: improve doxygen
4.115
@997f223
12/24/13 18:06:55 |
Daniel Ramirez |
bfin_eZKit533: added new doxygen
4.115
@c51645f
12/24/13 09:01:42 |
mjuvekar0 |
psxtests/psx14: Add doc file
4.115
@7b5f6643
12/24/13 13:32:37 |
cdesai |
sptests: refactor sp09/screen13 into a new test spclock_err02
4.115
@0c09ccf3
12/24/13 10:14:15 |
Daniel Ramirez |
bfin_TLL6527: added new doxygen
4.115
@6a26e9b
12/24/13 07:08:29 |
Chris Johns |
cpukit/capture: Print the uptime and diff in ctrace.
Print the uptime …
4.115
@9f9c0bb
12/24/13 05:42:23 |
Chris Johns |
cpukit/capture: Use the new RTEMS API to get the uptime in …
4.115
@2d1bdc8
12/24/13 05:38:42 |
Chris Johns |
cpukit/rtems: Add rtems_clock_get_uptime_nanoseconds to the RTEMS API. …
4.115
@c2b7528
12/23/13 19:03:25 |
Daniel Ramirez |
mips/shared: added new doxygen
4.115
@52943a24
12/23/13 18:19:00 |
cdesai |
i386: shared: Add doxygen
4.115
@9dc999a
12/23/13 17:06:34 |
cdesai |
lm32: Enhance Doxygen #2
4.115
@c541862e
12/23/13 16:44:42 |
cdesai |
lm32: Add doxygen
4.115
@8224d2af
12/22/13 21:55:40 |
Daniel Ramirez |
arm_stm32f4: added new doxygen
4.115
@b7212b9
12/23/13 02:07:02 |
zsoltisharkboy |
libbsp/arm: add doxygen to arm shared headers
4.115
@21dd58d9
12/22/13 23:18:34 |
Daniel Ramirez |
arm_xilinx-zynq: added new doxygen
4.115
@9543fdbb
12/23/13 01:54:01 |
Gedare Bloom |
rtl22xx: delete extra temporary file.
4.115
@78e529a6
12/22/13 19:49:52 |
Daniel Ramirez |
arm_rtl22xx: added new doxygen
4.115
@c0f731d
12/22/13 16:33:16 |
Daniel Ramirez |
arm_smdk2410: added new doxygen
4.115
@582553d9
12/21/13 21:46:33 |
Daniel Ramirez |
arm_gp32: added new doxygen
4.115
@49232d0
12/21/13 21:50:55 |
Daniel Ramirez |
arm_edb7312: added new doxygen
4.115
@3d6e1740
12/21/13 21:36:05 |
Daniel Ramirez |
gumstix: added new doxygen
4.115
@2bafb960
12/21/13 03:44:12 |
Daniel Ramirez |
rtems: classic api to/from core priority conversions
4.115
@1464599
12/20/13 16:37:25 |
mjuvekar0 |
psxtests/psxfatal01: add doc file
4.115
@c1d8ee4
12/17/13 09:59:13 |
Sebastian Huber |
libcsupport: Accept NULL for zero-length entries
4.115
@56bea43
12/16/13 13:26:29 |
Sebastian Huber |
Filesystem: Use default kqfilter and poll handler
4.115
@2f68778
12/16/13 12:44:13 |
Sebastian Huber |
Filesystem: Add readv/writev handlers
The readv() and writev() …
4.115
@95a57280
12/16/13 12:12:22 |
Sebastian Huber |
libcsupport: Add and use rtems_libio_iovec_eval()
4.115
@7b10f130
12/19/13 21:51:42 |
radustoma |
arm/gba: doxygen improvement
4.115
@fe011a5
12/16/13 19:13:14 |
Jennifer Averett |
sptests/spcpuset*: Add tests for fixed size cpu_set_t operations.
4.115
@db8a89e
12/19/13 08:01:23 |
Chris Johns |
cpukit/capture: Update the capture engine.
The capture did not work …
4.115
@f466e56
12/19/13 03:49:11 |
Chris Johns |
arm/a9mpcore: Add support to get the clock via a weak linkage …
4.115
@6c1e530
12/19/13 03:44:29 |
Chris Johns |
arm/zynq: Add support for application supplied MMU tables.
Users can …
4.115
@4a9e52e
12/19/13 00:45:19 |
Chris Johns |
Fix the broken conflict from the revert.
4.115
@1ab4f76
12/19/13 00:35:22 |
Chris Johns |
Revert "bsps/arm: Use ALIGN_WITH_INPUT"
This reverts commit …
4.115
@a9619f3c
12/18/13 17:00:42 |
alan.cudmore |
For PR 2164 - RFS File System - fix bitmap_create_search loop bug
4.115
@9b48dc6
12/18/13 17:37:47 |
alan.cudmore |
For PR 2162 - RFS File System - statvfs reports 1 block free
This is …
4.115
@e60b7b1
12/18/13 16:39:19 |
alan.cudmore |
For PR 2163 - RFS File System - fix group search algorithm bug
This …
4.115
@540a635
12/18/13 20:01:20 |
email.anukul |
psxtests: add psxcleanup/psxcleanup.doc
4.115
@d970738
12/17/13 21:55:22 |
radustoma |
arm_lm3s69xx: improve doxygen
4.115
@f859d20
12/16/13 13:45:26 |
Sebastian Huber |
arm: Fix set by but not used warning
4.115
@14e1c677
12/11/13 10:42:41 |
Sebastian Huber |
bsp/genmcf548x: Increase network TX FIFO watermark
This prevents …
4.115
@a19b915
12/11/13 10:35:10 |
Sebastian Huber |
bsp/genmcf548x: Fix network FIFO error handling
Use a buffer handling …
4.115
