@7183f1cd
03/05/15 10:51:25 |
Sebastian Huber |
score: Add compiler memory barrier to atomic ops
4.115
@7d6e94b
03/04/15 07:02:19 |
Sebastian Huber |
score: Implement fine-grained locking for events
Use the ISR lock of …
4.115
@4c8a0ac
03/04/15 07:02:09 |
Sebastian Huber |
score: Add thread wait flags
Update #2273.
4.115
@5b393fa5
03/01/15 12:50:55 |
Sebastian Huber |
score: Add thread acquire
Update #2273.
4.115
@43e1573c
02/28/15 17:06:37 |
Sebastian Huber |
score: Add ISR lock to Objects_Control
This enables per-object SMP …
4.115
@1512761
02/28/15 16:24:52 |
Sebastian Huber |
score: Thread dispatch dis/enable without Giant
Update #2273.
4.115
@222dc775
02/26/15 09:32:08 |
Sebastian Huber |
score: Add and use _Thread_Do_dispatch()
The _Thread_Dispatch() …
4.115
@6157743
02/23/15 15:54:54 |
Sebastian Huber |
score: Simplify and fix signal delivery
Deliver the POSIX signals …
4.115
@b8a5abf
02/26/15 09:33:36 |
Sebastian Huber |
score: Update _Thread_Heir only if necessary
Previously, the …
4.115
@81b03c6
03/05/15 07:11:27 |
Sebastian Huber |
score: Add and use PRIORITY_PSEUDO_ISR
4.115
@77510c7
03/05/15 09:53:20 |
Sebastian Huber |
libmd: Disable SHA modules for m32c
Close #2219.
4.115
@16b2de35
03/05/15 10:11:25 |
Sebastian Huber |
capture: Fix warnings
4.115
@c735cd5
03/05/15 09:34:28 |
Sebastian Huber |
dosfs: Fix warnings
4.115
@6fd5b4e
03/05/15 09:26:30 |
Sebastian Huber |
tests: Fix warning
4.115
@d0061287
03/05/15 09:11:23 |
Sebastian Huber |
tests: Fix warnings
4.115
@5155069
03/05/15 09:05:49 |
Sebastian Huber |
libchip/serial: Fix warning
4.115
@b4fa5a52
03/05/15 09:04:37 |
Sebastian Huber |
bsps: Fix warning
4.115
@2c88438
03/05/15 09:26:22 |
Sebastian Huber |
IMFS: Fix warning
4.115
@29d36fa
03/05/15 08:58:43 |
Sebastian Huber |
IMFS: Include missing header file
4.115
@81c73acf
03/05/15 08:58:22 |
Sebastian Huber |
IMFS: Fix warning
4.115
@5d428576
03/05/15 08:57:18 |
Sebastian Huber |
libblock: Fix warning
4.115
@b8aa1c1
03/05/15 08:53:09 |
Sebastian Huber |
score: C/C++ compatibility macros for ISR locks
Update #2273.
4.115
@5b5d2fd4
03/05/15 08:37:36 |
Sebastian Huber |
Filesystem: Delete unused null_op_fsmount_me()
4.115
@7f577d3
03/05/15 08:06:44 |
alexander.krutwig |
tests: Refactor parallel test execution
4.115
@51acbdc
03/04/15 12:07:02 |
alexander.krutwig |
score: Documentation
4.115
@18d0a49
03/05/15 07:44:59 |
Sebastian Huber |
Move test support from sapi to libmisc/testsupport
4.115
@8ac3549
03/04/15 15:13:49 |
Sebastian Huber |
score: Delete unused CPU_UNROLL_ENQUEUE_PRIORITY
4.115
@3358d62
03/04/15 23:15:41 |
Hesham Almatary |
score/cpu/or1k: Add cpuatomic.h to fix broken build.
4.115
@461a930
03/04/15 20:53:36 |
Joel Sherrill |
capture01: Update screen file
4.115
@57a914a3
03/03/15 21:15:00 |
Joel Sherrill |
Add simple test for scandir() on all file systems tested
updates 1394
4.115
@56c7192
03/03/15 16:08:51 |
Gedare Bloom |
psxtests/psxclock01: use clock() and CLOCKS_PER_SEC
Closes #2182
4.115
@76f37656
02/25/15 19:52:10 |
Gedare Bloom |
libcsupport: scale times() call to microseconds
4.115
@e50297e
03/04/15 09:15:02 |
Sebastian Huber |
score: ISR lock C/C++ compatiblity issue
Empty structures are …
4.115
@d2ffb7dc
02/26/15 10:35:28 |
Sebastian Huber |
score: Add and use _Thread_Enable_dispatch_body()
Update #2273.
4.115
@b99be6e
02/26/15 10:32:45 |
Sebastian Huber |
score: Inline _Thread_Disable_dispatch() for SMP
4.115
@2b7fe356
02/26/15 09:29:02 |
Sebastian Huber |
score: Add parameter to Giant acquire/release
Update #2273.
4.115
@c5436ff4
03/04/15 10:56:25 |
Sebastian Huber |
smptests/smpcapture01: Avoid livelock condition
4.115
@0324410
02/26/15 09:26:49 |
Sebastian Huber |
smptests: Do not use Giant directly
This ensures that thread …
4.115
@396ce49
03/03/15 20:51:24 |
Joel Sherrill |
xdr_float.c: Fix typo
4.115
@262a0d7
03/03/15 20:09:41 |
Hesham Almatary |
or1k/or1k-exception-default.c: Eliminate dependency on BSP provided .h file
4.115
@39655741
03/03/15 18:48:14 |
Hesham Almatary |
librpc: Include or1knd part of the recongnized CPUs at xdr_float.c
4.115
@e4154b8
03/03/15 15:17:26 |
Joel Sherrill |
mips BSPs: Remove .global for unprovided symbol
closes 2253
4.115
@4ccb79bc
03/02/15 11:23:20 |
Sebastian Huber |
score: Enable SMP barriers for all configurations
4.115
@991fdb33
02/26/15 20:31:27 |
Martin Galvan |
ARM: Add BSP_START_NEEDS_REGISTER_INITIALIZATION
This patch adds the …
4.115
@63e91fe6
02/26/15 17:39:05 |
Martin Galvan |
ARM: Fix _ARMV4_Exception_fiq_default
In …
4.115
@6357e14a
02/26/15 11:55:43 |
Sebastian Huber |
psxtests/psx05: Adjust test case
Update #2170.
4.115
@bd1c9248
02/26/15 09:19:38 |
Sebastian Huber |
sptests/sp76: Check that the right task executes
4.115
@c0e01a28
02/24/15 15:27:08 |
Gedare Bloom |
posix: fix error return code for pthread_mutex_trylock
4.115
@ee870077
12/22/14 00:50:31 |
Chris Johns |
Panic on RTEMS_FAST_MUTEX network semaphore claim/release.
Fix the …
4.115
@9d090fb7
02/23/15 20:42:59 |
Gedare Bloom |
sparc64: fix copyright notices.
The sparc64 port had some incorrect …
4.115
@ced84fc0
02/23/15 17:27:05 |
Jeffrey Hill |
rpc: misaligned pointer dereference in clnt_udp.c line 363
closes #2248
4.115
@49ff36b
02/23/15 17:06:21 |
Jeffrey Hill |
rpc: misaligned address exception in get_myaddress.c
closes #2249 see …
4.115
@748fbd1
02/23/15 15:49:15 |
Sebastian Huber |
rtems-bin2c: Fix Windows build
Update #2238.
4.115
@25e14e31
02/23/15 15:46:22 |
strauman |
networking: alignment exception in ioctl(SIOCGIFCONF)
Access memory …
4.115
@1281c34
02/23/15 15:38:37 |
Gedare Bloom |
Use counted strnlen in bin2c. Closes #2238.
4.115
@83fe4468
02/23/15 14:59:49 |
Gedare Bloom |
psxtests: add string param to printf. closes #2241
4.115
@dc9aaf7
02/20/15 13:08:01 |
Martin Galvan |
ARM: Support VFP-D16
This patch allows the existing FPU code to …
4.115
@a45dfa14
02/20/15 08:42:15 |
Sebastian Huber |
IMFS: Fix copy on write for linfiles
4.115
@5eb27ce
02/20/15 04:00:47 |
Nick Withers |
Don't fail to create passwd and group files if /etc already exists
4.115
@c53705c
02/17/14 08:39:27 |
Nick Withers |
doc: Note that rename() is only partially implemented.
Replacing of …
4.115
@7f1bb40a
02/19/15 20:48:47 |
Gedare Bloom |
bfin: do not reset dispatch needed
Closes #2148
Fix suggested in …
4.115
@a3316f47
02/19/15 10:12:01 |
Sebastian Huber |
sptests: Add missing test extension
4.115
@4e3d9a4d
02/18/15 16:46:37 |
Sebastian Huber |
score: Make <rtems/score/atomic.h> available
Make …
4.115
@fd14430
02/18/15 16:06:05 |
Sebastian Huber |
IMFS: Silence warning
4.115
@7fcb71a
02/17/15 12:43:57 |
Sebastian Huber |
score: Fix _Thread_Start_multitasking() on SMP
Close #2268.
4.115
@8d6e6eeb
02/17/15 09:00:43 |
Sebastian Huber |
score: Fix FP context restore via _Thread_Handler
After a context …
4.115
@c34f94f7
02/16/15 10:55:03 |
Sebastian Huber |
score: Add _CPU_SMP_Prepare_start_multitasking()
Update #2268.
4.115
@a43a3466
02/15/15 09:38:15 |
Sebastian Huber |
IMFS: Implement variable length node names
This reduces the average …
4.115
@f785492
02/14/15 19:07:19 |
Sebastian Huber |
IMFS: Add CONFIGURE_IMFS_DISABLE_READDIR
4.115
@5640dd5
02/11/15 23:36:34 |
Joel Sherrill |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add ftp01
4.115
@79b45a1
02/11/15 23:34:44 |
Joel Sherrill |
lpc1768_mbed-testsuite.tcfg: Add ftp01
4.115
@2d84c4e
02/13/15 21:07:45 |
Sebastian Huber |
score: Mention ticket in comment
4.115
@249766c5
02/13/15 20:26:17 |
Sebastian Huber |
IMFS: Rename CONFIGURE_IMFS_DISABLE_FCHMOD
Rename …
4.115
@40a18d7f
02/13/15 20:11:55 |
Sebastian Huber |
IMFS: Add CONFIGURE_IMFS_DISABLE_MKNOD_FILE
4.115
@12eee4fd
02/13/15 19:53:41 |
Sebastian Huber |
IMFS: CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
Resurrect …
4.115
@50f8bfd
02/13/15 17:52:43 |
Joel Sherrill |
sapi/Makefile.am: Do not install libsapi.a
sapi/preinstall.am: …
4.115
@353506b9
02/02/15 13:55:23 |
Sebastian Huber |
sys/event.h: Update to FreeBSD 9.3
4.115
@b57a6a7
02/11/15 19:59:29 |
Joel Sherrill |
psxhdrs: Reorganize into subdirectories per .h file and rename files
4.115
@86076f3
02/11/15 19:31:30 |
Joel Sherrill |
psxhdrs: Remove test of pthread_attr_[gs]et_cputime
These methods are …
4.115
@eedaf9b
02/11/15 20:00:35 |
Joel Sherrill |
psxhdrs: Add tests for <sys/socket.h> API compliance
4.115
@547c2282
02/11/15 20:12:48 |
Joel Sherrill |
sys/socket.h: Include <sys/types.h> for ssize_t
closes 2245
4.115
@a9df916
02/08/15 18:43:09 |
Sebastian Huber |
IMFS: Add fine grained configuration
Remove miniIMFS. Statically …
4.115
@a2f5c7e1
02/08/15 15:09:27 |
Sebastian Huber |
IMFS: Allow static initialization of FS info
4.115
@11026956
02/06/15 19:50:49 |
Sebastian Huber |
IMFS: Fix resource leak
4.115
@60cf8a5
02/06/15 15:32:39 |
Sebastian Huber |
IMFS: Add root directory to FS info
Fix memory leak in IMFS_fsunmount().
4.115
@9247d3f
02/05/15 15:58:09 |
Sebastian Huber |
IMFS: Simplify IMFS_symlink()
4.115
@e4d35d8
02/05/15 15:43:58 |
Sebastian Huber |
IMFS: Split linfile and memfile modules
Make several functions static.
4.115
@24ec25d
02/05/15 15:14:59 |
Sebastian Huber |
IMFS: Introduce IMFS_mknod_control
Drop IMFS_node_control::node_size …
4.115
@194eb007
02/12/15 19:52:16 |
Sebastian Huber |
Filesystem: Use ENOTSUP for default mount/unmount
4.115
@5efbb66
02/04/15 09:33:17 |
cederman |
grspw: Fix typos
4.115
@8244a2f
01/12/15 10:24:58 |
cederman |
doc: Document network task affinity option
4.115
@b92f737
01/12/15 10:24:16 |
cederman |
doc: Describe new default error handler for Sparc
4.115
@8d8573ac
02/04/15 09:04:05 |
cederman |
smpcapture02: Add test of functionality to add custom entries to …
4.115
@0c94a46
01/09/15 08:03:59 |
cederman |
bsp/sparc: Move BSP_ISR_handler to a separate file and rename it
This …
4.115
@1c7ee73
02/10/15 20:18:27 |
Hesham Almatary |
or1k/cpu.c: Eliminate dependency on BSP provided header
4.115
@16939b18
02/09/15 18:09:23 |
Sebastian Huber |
Filesystem: Simplify FIFO and pipe configuration
4.115
@eb77534
02/09/15 14:37:00 |
Sebastian Huber |
Filesystem: Delete unused fsmountme_h handler
4.115
@b4e52ce9
02/06/15 20:12:38 |
Sebastian Huber |
fstests/fsrename: Avoid double initialization
4.115
@cf4dfc1
02/04/15 17:20:27 |
pisa |
arm/tms570: sci context has to be writable because it holds state …
4.115
@924cbd4f
01/31/15 20:27:01 |
Sebastian Huber |
IMFS: Simplify ino generation
The type of ino_t is unsigned long, so …
4.115
