@e78e7fe0
04/02/19 11:33:49 |
andreas.dachsberger |
doxygen: Added Version to API->Classic
Update #3706.
5
@6b23763e
04/02/19 11:32:40 |
doxygen: Added Frame Buffer Device Driver Interface to Device Drivers
5
@4b841b3
04/02/19 11:30:31 |
doxygen: Added some subgroups to IO Library
Update #3706.
Types and …
5
@333bead
04/02/19 11:05:29 |
doxygen: Removed XXX group
Update #3706.
Content was added to …
5
@b2b7b58e
04/02/19 11:02:47 |
doxygen: Added Management to Example CPU Architecture
Update #3706.
5
@1964b268
04/02/19 10:30:22 |
doxygen: Added subgroup Generic to BSP->SPARC64
Update #3706.
5
@529d251b
04/02/19 10:11:21 |
doxygen: Added libmisc group and libmisc mouse group
Update #3706.
5
@0f02e6f
04/02/19 10:09:49 |
doxygen: Added toplevel group for device drivers
Update #3706.
5
@b7927ef
04/02/19 10:06:30 |
doxygen: Added further groups to RTEMSAPI
Update #3706.
5
@ff1f374
04/02/19 10:01:42 |
doxygen: Added Mainpage to RTEMSAPIClassic
Update #3706.
5
@6644867
04/02/19 08:14:56 |
doxygen: User Extensions Implementation group now in Internal->Classic …
5
@fbe8a7a
04/03/19 10:44:42 |
Sebastian Huber |
doxygen: Rework some Doxygen comments
They are intended as examples …
5
@a2aec0b7
04/03/19 09:34:53 |
Goetz.Pfeiffer |
Set the small data section size to max. for beatnik BSPs.
This …
5
@0a9b4513
04/01/19 10:22:37 |
doxygen: bsps: Added remaining Sparc64 groups
5
@058f637
04/01/19 09:48:57 |
doxygen: score: Added ScoreRWLock to Score group
Update #3706.
5
@5342261
04/01/19 08:55:15 |
doxygen: Added groups to IO library
Update #3706.
5
@493c1e8
04/01/19 07:14:14 |
doxygen: score: Put ARM Co-Processor 15 group in ARM
Update #3706.
5
@b07c721
03/28/19 12:27:05 |
doxygen: Restructured cpukit/include/rtems/rtems
Update #3706.
5
@b86148a
03/28/19 10:42:58 |
doxygen: Reviewed cpukit/include/rtems/posix
Update #3706.
5
@7a722e75
03/28/19 09:28:40 |
doxygen: Reviewed cpukit/include/rtems/rtems
Update #3706.
5
@69d6671f
03/28/19 08:46:08 |
doxygen: Reviewed cpukit/include/rtems/score
Update #3706.
5
@95c76030
03/27/19 10:17:16 |
doxygen: score: Add x86-64 CPU architecture group
Update #3706.
5
@9f8af67
03/27/19 10:11:54 |
doxygen: score: Add V850 CPU architecture group
Update #3706.
5
@2a50f87
03/27/19 09:59:35 |
doxygen: score: Add SPARC64 CPU architecture group
Update #3706.
5
@25afa79
03/27/19 09:50:44 |
doxygen: score: Add SPARC CPU architecture group
Update #3706.
5
@2b37eca5
03/27/19 09:46:08 |
doxygen: score: Add SuperH CPU architecture group
Update #3706.
5
@71f9098
03/27/19 09:38:56 |
doxygen: score: Add RISC-V CPU architecture group
Update #3706.
5
@6ddbcbc
03/26/19 10:48:20 |
doxygen: score: Add powerpc CPU architecture group
Update #3706.
5
@39594416
03/26/19 10:40:41 |
doxygen: score: Add or1k CPU architecture group
Update #3706.
5
@92c2db64
03/26/19 10:33:40 |
doxygen: score: Add nios2 CPU architecture group
Update #3706.
5
@f2e282d
03/26/19 10:25:44 |
doxygen: score: Add Moxie CPU architecture group
Update #3706.
5
@0be1e54
03/26/19 09:44:58 |
doxygen: score: Add m68k CPU architecture group
Update #3706.
5
@ee38c54
03/26/19 09:22:26 |
doxygen: score: Change no_cpu architecture group
Groups CPUContext …
5
@9fa3561b
03/26/19 08:50:42 |
doxygen: score: Add lm32 CPU architecture group
Update #3706.
5
@d670ef9
03/26/19 08:02:04 |
doxygen: score: Add i386 CPU architecture group
Update #3706.
5
@40b90a08
03/26/19 07:15:29 |
doxygen: score: Add Epiphany CPU architecture group
Update #3706.
5
@eca13a8f
03/25/19 14:19:41 |
doxygen: score: Add Blackfin CPU architecture group
Update #3706.
5
@294c6f4
03/29/19 22:58:31 |
Chris Johns |
Set the small data section size to max. for mvme5500 and mvme2100 BSPs …
5
@cbfc3415
03/14/19 07:20:54 |
Sebastian Huber |
ttest01: New test
This is an example test using the RTEMS Test …
5
@cfcc2cbf
01/31/19 13:45:31 |
Sebastian Huber |
Add RTEMS Test Framework
Update #3199.
5
@6fe01e4b
01/14/19 08:08:18 |
Sebastian Huber |
build: Move test support to librtemstest.a
One reason to move the …
5
@abec398
03/25/19 09:42:52 |
Sebastian Huber |
score: Add ARM CPU architecture group
Update #3706.
5
@5a19915
03/25/19 09:33:05 |
Sebastian Huber |
score: Add example CPU architecture group
Update #3706.
5
@5526527e
03/25/19 09:45:25 |
Sebastian Huber |
score: Rename ScoreCPU Doxygen group
Update #3706.
5
@40d15f5
03/25/19 09:31:51 |
Sebastian Huber |
score: Add implementation top-level group
Update #3706.
5
@127ee3a5
03/18/19 13:47:58 |
joel |
psxhdrs/stdio/v*.c: Fix warnings in varargs tests
5
@b0f524f
03/18/19 13:46:56 |
joel |
libfs/src/pipe/fifo.c: Fix warning.
5
@6163ab2
03/18/19 13:46:32 |
joel |
erc32/start/setvec.c: Fix warning
5
@db23c3c
03/15/19 17:16:48 |
joel |
pthreadcreate.c: Silence unused variable warning (CID 1399716)
5
@7a1934d
03/25/19 07:09:09 |
Sebastian Huber |
build: Always build libmghttpd.a
5
@311270c
03/20/19 10:03:12 |
Sebastian Huber |
score: Update Objects_Information documentation
5
@dad6fd43
03/09/19 18:04:42 |
Chris Johns |
libdl: Add an archive command
- The archive command lists archives, …
5
@a5f84c6a
03/19/19 09:04:33 |
Sebastian Huber |
bsp/atsam: Fix SPI driver DMA support
5
@5f813694
03/19/19 09:45:06 |
Sebastian Huber |
bsp/atsam: Simplify XDMAD_Handler()
Remove the channel status …
5
@007d4e12
02/25/19 06:07:19 |
Sebastian Huber |
bsp/lpc24xx: Convert I2C driver to Linux API
Change license to …
5
@9e48958
03/15/19 06:32:28 |
Sebastian Huber |
bsps/powerpc: Initialize stack earlier
The eabi() call may use the …
5
@31e8f1b
03/14/19 19:25:18 |
joel |
shmopen.c: Fix logically unreachable code (Coverity ID: 1399706, …
5
@c319945
03/13/19 15:07:23 |
joel |
main_edit.c: Use strncpy() to eliminate potential buffer overflow.
5
@11eb818
03/13/19 15:06:45 |
joel |
fifo.c: Eliminate logically dead code (Coverity 1437635)
5
@90232bc
03/12/19 19:33:20 |
joel |
z85c30.c: Do not process 0 baud and return an error (CID 1399713)
5
@3fe2155
02/01/19 09:00:36 |
Sebastian Huber |
Remove superfluous <rtems/system.h> includes
5
@12075ac3
03/14/19 10:09:09 |
Sebastian Huber |
sparc64: Do not include <rtems/asm.h> in C source
5
@20d472d
01/31/19 13:45:17 |
Sebastian Huber |
Add rtems_board_support_package()
5
@da4ca4d
02/01/19 09:01:05 |
Sebastian Huber |
posix: is_initialized is of type int not bool
5
@286e935
03/13/19 07:14:40 |
Sebastian Huber |
Regenerate cpukit/headers.am
Updates #3686.
5
@51d11dd
03/13/19 07:12:54 |
Sebastian Huber |
bsp/lm3s69xx: Fix typo in test configuration
5
@d7e2e8bb
03/12/19 15:59:56 |
joel |
mpc5643l_evb-testsuite.tcfg: : Update to account for static allocation …
5
@f22a59de
03/12/19 15:59:28 |
joel |
mpc5643l_dpu-testsuite.tcfg: Update to account for static allocation …
5
@870b527
03/08/19 22:41:46 |
joel |
mcf5225x-testsuite.tcfg: Update to account for static allocation and …
5
@539caca
03/08/19 22:41:46 |
joel |
mcf52235-testsuite.tcfg: Update to account for static allocation and …
5
@d929c483
03/08/19 22:41:46 |
joel |
tms570ls3137_hdk_with_loader-testsuite.tcfg: Update to account for …
5
@0186e39
03/08/19 22:41:45 |
joel |
tms570ls3137_hdk_intram-testsuite.tcfg: Update to account for static …
5
@8ff85c6
03/08/19 22:41:45 |
joel |
tms570ls3137_hdk-testsuite.tcfg: Update to account for static …
5
@c5dca3b7
03/08/19 22:41:45 |
joel |
stm32f4-testsuite.tcfg: Update to account for static allocation and …
5
@4f67dbda
03/08/19 22:41:45 |
joel |
stm32f105rc-testsuite.tcfg: Update to account for static allocation …
5
@0abfdc3
03/08/19 22:41:45 |
joel |
lpc32xx_mzx_stage_1-testsuite.tcfg: Update to account for static …
5
@5f07bdac
03/08/19 22:41:45 |
joel |
lpc23xx_tli800-testsuite.tcfg: Update to account for static allocation …
5
@dc632e0
03/08/19 22:41:45 |
joel |
lpc2362-testsuite.tcfg: Update to account for static allocation and …
5
@aafae0d
03/08/19 22:41:45 |
joel |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Update to account for static …
5
@774ea37a
03/08/19 22:41:45 |
joel |
lpc1768_mbed_ahb_ram-testsuite.tcfg: Update to account for static …
5
@17046c9b
03/08/19 22:41:45 |
joel |
lpc1768_mbed-testsuite.tcfg: Update to account for static allocation …
5
@1526b7b
03/08/19 22:41:45 |
joel |
lm4f120-testsuite.tcfg: Update to account for static allocation and …
5
@bb1f3b4
03/08/19 22:41:44 |
joel |
lm3s6965-testsuite.tcfg: Update to account for static allocation and …
5
@c8e71bf
03/08/19 22:41:44 |
joel |
lm3s3749-testsuite.tcfg: Update to account for static allocation and …
5
@c10e8b6
03/08/19 22:38:46 |
joel |
coremsgseize.c: Fix spelling error
5
@1400210
03/08/19 10:12:31 |
Sebastian Huber |
bsp/lpc24xx: Convert SSP driver to Linux API
Use interrupts instead …
5
@b2eaa6c6
03/12/19 14:50:37 |
Sebastian Huber |
bsp/lpc24xx: Add alternative SSP2 pins
5
@01a5ced5
03/12/19 08:00:51 |
Sebastian Huber |
record: Add more system events
Update #3665.
5
@ebb8c28e
03/12/19 07:27:52 |
Sebastian Huber |
record: Add system call entry/exit events
This corresponds to the …
5
@d91951fb
03/12/19 07:15:19 |
Sebastian Huber |
record: Rename internal per-CPU events
Update #3665.
5
@0a154d5
03/02/19 17:09:39 |
shashvatjain2002 |
Correct psxtmtests_plan.csv
5
@ba34ed9c
03/11/19 06:12:38 |
Sebastian Huber |
bsp/atsam: Fix use after free
5
@529b5868
03/08/19 06:57:24 |
Sebastian Huber |
bsps: Adjust umon Doxygen groups
Update #3706.
5
@cbf773d3
03/07/19 12:29:58 |
Sebastian Huber |
bsp/atsam: Add Doxygen groups
Add Doxygen groups for contributed code …
5
@f3db3835
03/07/19 11:09:53 |
Sebastian Huber |
bsp/altera-cyclone-v: Add Doxygen groups
Add Doxygen groups for …
5
@15359bb
03/07/19 10:56:31 |
Sebastian Huber |
bsps/arm: Adjust CMSIS Doxygen groups
Update #3706.
5
@828276b
03/05/19 06:58:18 |
Sebastian Huber |
bsps: Adjust shared Doxygen groups
Update #3706.
5
@c991eeec
03/04/19 14:32:15 |
Sebastian Huber |
bsps: Adjust bsp.h Doxygen groups
Update #3706.
5
@2e8a66d
03/01/19 18:21:34 |
Jonathan Brandmeyer |
shell: Correct argument order of mfill
Close #3720.
5
@b1ac3a5
03/01/19 18:21:52 |
cpukit/arm: Correct register definition
The register definition for …
5
