@a48bfc0f
10/20/15 09:25:06 |
maberg |
leon, grspw_pkt: Fixed txpkt flag for link error
There was a mixup …
5
@3395ca99
06/30/15 13:00:51 |
maberg |
leon, grspw_pkt: Fixed parameter check in grspw_dma_open()
5
@4431f7d
04/13/15 07:01:54 |
Daniel Hellstrom |
leon, gr1553b: RT status words register declarations fix
The fix does …
5
@d745297
01/02/15 12:18:33 |
Daniel Hellstrom |
leon, gr1553b: comment cleanup
5
@91df5a69
01/02/15 12:17:18 |
Daniel Hellstrom |
libpci: code cleanup
5
@be66bbc1
01/02/15 12:16:10 |
Daniel Hellstrom |
leon, grspw: rxPktSize must set DMA RX max length
5
@cb056d0
03/03/17 08:04:12 |
Sebastian Huber |
cdtest: Print begin of test only once
5
@c0dafd7b
03/02/17 15:53:45 |
Sebastian Huber |
bsp/qoriq: Use at most 2GiB of RAM
5
@d3f60af
03/02/17 14:25:34 |
Sebastian Huber |
bsp/qoriq: Adjust workspace according to FDT
5
@35136d3
03/02/17 14:20:52 |
Sebastian Huber |
bsp/qoriq: Use -O2
5
@62f16ad
03/02/17 14:20:19 |
Sebastian Huber |
bsp/qoriq: Enable linker garbage collection
5
@891b834f
03/02/17 14:17:35 |
Sebastian Huber |
bsp/qoriq: Do not overwrite configured baud
5
@805d7213
03/02/17 10:57:28 |
Sebastian Huber |
powerpc: Fix warnings
5
@09dab28d
03/02/17 10:54:58 |
Sebastian Huber |
powerpc: Fix interrupt thread dispatch
Update #2751.
5
@1f618ab0
03/02/17 06:54:52 |
Sebastian Huber |
posix_devctl: Fix for pre C99
Use restrict just like in <devctl.h> …
5
@08d85992
03/01/17 10:31:57 |
Sebastian Huber |
bsps/powerpc: Fix warnings
5
@a60db69
02/27/17 10:50:30 |
Sebastian Huber |
dosfs: Fix FAT32 formatter
The second FAT entry contains a bit to …
5
@267de79a
02/27/17 09:40:49 |
Sebastian Huber |
dosfs: Directories should have a file size of 0
Close #2755.
5
@f71ccc34
02/28/17 08:12:13 |
Sebastian Huber |
termios: Simplify some calculations
Use the modular arithmetic …
5
@902ffed
02/24/17 13:56:51 |
Sebastian Huber |
termios09: Test send callback
5
@36635433
02/24/17 13:44:04 |
Sebastian Huber |
termios: Implement non-blocking write
5
@a165a96
02/23/17 14:43:41 |
Sebastian Huber |
termios: Make write POSIX compatible
Currently only blocking …
5
@c41b47e3
02/23/17 14:19:47 |
Sebastian Huber |
termios: Introduce doTransmit()
5
@5244d31e
02/23/17 13:04:24 |
Sebastian Huber |
termios: Simplify oproc()
Call rtems_termios_puts() only once. …
5
@06d14667
02/24/17 10:46:26 |
Sebastian Huber |
termios09: Test output post processing
5
@c80f6aa9
02/24/17 09:29:05 |
Sebastian Huber |
termios: Fix infinite loop in receive path
In canonical mode, the raw …
5
@9fa0f54
02/23/17 10:35:44 |
Sebastian Huber |
termios: Change receive callback invocation
Call the receive callback …
5
@49d8f653
02/23/17 08:38:54 |
Sebastian Huber |
termios: Change tty_rcvwakeup to bool
Optimize callout invocation check.
5
@9f69ac2
02/23/17 09:35:16 |
Sebastian Huber |
termios: Ignore carriage return early if desired
In case carriage …
5
@bb087cb0
02/23/17 09:06:52 |
Sebastian Huber |
termios: Protect raw input buffer with device lock
Use the device …
5
@d60c2d79
02/23/17 08:12:36 |
Sebastian Huber |
termios: Simplify rtems_termios_read_tty()
Remove dead code.
Update …
5
@5bfeddc0
02/21/17 08:01:49 |
Sebastian Huber |
termios: Add kqueue() and poll() support
Real implementation is …
5
@c833970
02/21/17 07:58:29 |
Sebastian Huber |
score: Add RTEMS_WEAK_ALIAS()
5
@3398602
02/21/17 14:25:03 |
Sebastian Huber |
Add rtems_interrupt_server_request_submit()
This function may be used …
5
@11f0d52
02/22/17 08:01:40 |
Sebastian Huber |
bsp/xilinx-zynq: Add interrupt support to UART
5
@6b2fcc4
02/21/17 09:30:30 |
Sebastian Huber |
bsp/xilinx-zynq: Use new Termios device driver
5
@c54769e7
02/21/17 11:10:43 |
Sebastian Huber |
spextensions01: Fix extension create order
Update #2692.
5
@df184eb
08/10/15 04:21:02 |
Nick Withers |
Remove old CVS keywords
Update #2388.
5
@7318e7db
02/15/17 12:41:02 |
Sebastian Huber |
bsp/lpc24xx: Remove debug output
5
@6afeeda
02/15/17 12:39:02 |
Sebastian Huber |
5
@f6f764c1
02/15/17 12:28:02 |
Sebastian Huber |
5
@c847451b
02/15/17 12:22:36 |
Sebastian Huber |
sapi: Fix warnings
5
@32292d5d
02/15/17 12:14:40 |
Sebastian Huber |
5
@661be20
02/15/17 12:05:27 |
Sebastian Huber |
shell: Fix warnings
5
@bc744618
02/15/17 11:57:56 |
Sebastian Huber |
bsps/sparc: Fix warnings
5
@f5cf2fe
02/15/17 10:19:50 |
Sebastian Huber |
libdl: Fix warning
5
@444cb5c
02/15/17 10:12:40 |
Sebastian Huber |
bsps/arm: Fix prototype
5
@73f8d93
02/15/17 10:09:50 |
Sebastian Huber |
5
@7a462cc
02/15/17 10:09:32 |
Sebastian Huber |
score: Fix warning
5
@611f9262
02/14/17 10:30:00 |
Sebastian Huber |
psxtests: Fix warnings
5
@468e9a4
02/14/17 10:10:40 |
Sebastian Huber |
monitor: Print short and long task names
Print wait object identifier …
5
@71ac0a6
02/14/17 09:05:24 |
Sebastian Huber |
spqreslib: Remove invalid test cases
5
@ad25f10
02/14/17 09:03:42 |
Sebastian Huber |
spcbssched02: Remove invalid test cases
5
@ecf53c8
02/14/17 08:57:22 |
Sebastian Huber |
psxsem01: Fix warning
5
@54835ae
02/01/17 13:10:18 |
Sebastian Huber |
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS
Rename …
5
@c341463
02/14/17 07:58:33 |
Sebastian Huber |
tmacros.h: Fix print defines
5
@9333de2f
02/14/17 07:54:51 |
Sebastian Huber |
sppagesize: Include missing header file
5
@5eee718
02/14/17 07:46:22 |
Sebastian Huber |
shell: Fix warnings
5
@6dbbafc6
02/14/17 07:42:48 |
Sebastian Huber |
score: Fix warning in _Thread_Set_name()
5
@d9c65429
02/13/17 14:13:02 |
Sebastian Huber |
dosfs: Fix msdos_find_file_in_directory()
For a filename match the …
5
@239dd35f
02/03/17 10:24:30 |
Sebastian Huber |
smptests: Fix warnings
5
@07d71279
02/01/17 13:48:17 |
Sebastian Huber |
Prefix confdefs.h internal def with an underscore
Close #2895.
5
@85ed95e
02/03/17 09:49:13 |
Sebastian Huber |
termios: Fix static device initalization
This enables early printk() …
5
@bbfbfc8
02/03/17 07:57:18 |
Sebastian Huber |
score: Move _Thread_Scheduler_ask_for_help()
Move …
5
@ca1e546e
02/02/17 15:24:05 |
Sebastian Huber |
score: Improve scheduler helping protocol
Only register ask for help …
5
@e2b1c47d
02/03/17 09:16:40 |
Sebastian Huber |
sparc: Fix volatile clobber
Do not adjust the stack pointer, since …
5
@d4ff66e
02/03/17 07:43:56 |
Sebastian Huber |
confdefs.h: Simplify
5
@f9db6fd
02/02/17 22:44:31 |
kevin-kirspel |
confdefs.h: Only define _CONFIGURE_SMP_APPLICATION if RTEMS_SMP defined
5
@6dd96af
02/02/17 08:16:53 |
Sebastian Huber |
rtems: Fix RTEMS_NO_TIMEOUT define
Cast the internal …
5
@f95fa387
02/01/17 11:11:33 |
Sebastian Huber |
Remove CONFIGURE_SMP_APPLICATION
Enable the SMP support if …
5
@70f559d8
02/01/17 12:00:15 |
Sebastian Huber |
rtems: Fix RTEMS_MAXIMUM_PRIORITY define
Cast the internal …
5
@f7ba2945
01/31/17 08:01:37 |
Sebastian Huber |
monitor: Add support for BSD wakeup messages
5
@e366f77
01/31/17 07:08:24 |
Sebastian Huber |
score: Add _Thread_queue_Object_name
Add the special thread queue …
5
@70488f56
01/31/17 08:37:54 |
Sebastian Huber |
score: Fix _Thread_Initialize()
5
@166a9f67
01/30/17 18:34:28 |
c0066c |
sprmsched01/spedfsched04: Revise
Instead of using the target time and …
5
@c5430e06
01/30/17 11:29:31 |
Sebastian Huber |
score: Fix unused parameter warning
Close #2890.
5
@575c2e21
01/30/17 10:24:57 |
Stavros Passas |
Complete STACK_CHECKER_EXTENSION. Fixes #2889
5
@180107e9
01/30/17 10:33:31 |
Christian.Mauderer |
bsps/arm: Fix Cortex-M DWT CPU counter.
It is necessary to enable the …
5
@0794197
01/27/17 22:15:50 |
c0066c |
rtems: Fix _Rate_monotonic_Renew_deadline()
Prepare a precondition to …
5
@4ea92d1e
01/27/17 07:06:06 |
Sebastian Huber |
score: Clarify _Heap_Extend()
Update #1747.
5
@abc963d
01/27/17 06:42:29 |
Sebastian Huber |
score: Fix typo
5
@6f6da82c
01/26/17 10:06:50 |
Sebastian Huber |
score: Fix user extensions order
Use forward and reverse order for …
5
@d1505a1
01/26/17 10:05:00 |
Sebastian Huber |
sapi: Add rtems_task_terminate_extension
5
@d7feb86
01/25/17 20:47:48 |
c0066c |
Remove rtems_rate_monotonic_postponed_job_count()
Add a variable …
5
@27bfcd8
01/25/17 13:32:02 |
Sebastian Huber |
score: Delete _CPU_Context_Fp_start()
Since the FP area pointer is …
5
@7cb7454f
01/25/17 10:46:51 |
Sebastian Huber |
psxtests: Relax shared memory tests
There is currently no proper …
5
@090bdc7e
01/25/17 10:45:49 |
Sebastian Huber |
posix: Fix use of uninitialized variable
Update #2859.
5
@23a11b6
01/25/17 10:16:02 |
Sebastian Huber |
sptests/spedfsched04: Merge and fix
Merge into one file and fix …
5
@b43c2e8
01/24/17 14:40:31 |
kevin-kirspel |
Adding ARM VFP V2 support
5
@29e08d4
01/24/17 14:34:47 |
Sebastian Huber |
sptests/sprmsched01: Merge and fix
5
@b8d6eb7
01/24/17 14:05:22 |
Sebastian Huber |
rtems: rtems_rate_monotonic_postponed_job_count()
Use proper locking …
5
@625bd6a
01/24/17 14:04:11 |
Sebastian Huber |
rtems: Fix _Rate_monotonic_Release_postponed_job()
5
@1240aade
01/24/17 13:37:42 |
Sebastian Huber |
Make …
5
@6af2221
01/24/17 09:07:57 |
Sebastian Huber |
fsscandir01: Check MAXNAMLEN and NAME_MAX
Update #1394.
5
@436a4b3
01/24/17 08:43:20 |
Sebastian Huber |
smptests/smpsignal01: Check signal ISR level
Close #2751.
5
@3d20f5fb
01/23/17 14:04:44 |
Sebastian Huber |
sparc: Relax CPU_STACK_ALIGNMENT
Close #2352.
5
@4aa23c96
01/23/17 07:12:18 |
Sebastian Huber |
Remove CPU_BIG_ENDIAN and CPU_LITTLE_ENDIAN
Use de-facto standard …
5
@2711914f
01/23/17 07:06:41 |
Sebastian Huber |
Use <sys/endian.h>
Update #2803.
5
@dc9b704
01/23/17 06:58:42 |
Sebastian Huber |
Provide <endian.h> for glibc compatibility
Update #2803.
5
@2f8f951b
01/23/17 13:51:27 |
kevin-kirspel |
bsp/lpc32xx: Fix interrupt controller suppport
Enable/Disable? vector …
5
