@9860cc7
03/16/18 10:01:03 |
Sebastian Huber |
bsps/powerpc: Fix linker command files
Update #3339.
5
@be3d7d75
03/15/18 22:20:23 |
joel |
pc386/include/edid.h: Fix macro name to use _ not -
Closes #3349.
5
@8307723d
03/15/18 22:18:14 |
joel |
beatnik/include/bsp.h: Add spaces around "."
Closes #3348.
5
@b3360235
03/15/18 15:01:37 |
joel |
mvme5500/include/bsp/VMEConfig.h: Remove spaces after \ and remove tabs
5
@3200c300
03/15/18 14:58:13 |
joel |
bsp/arm-a8core-start.h: Add void return type to fix warning
5
@74fe9ce
03/15/18 14:49:11 |
joel |
rtems/bfin/bf533.h: Eliminate redefinition warning and add sanity …
5
@dce920ae
03/15/18 14:48:21 |
joel |
mvme3100/include/bsp.h: Add spaces around "."
Closes #3345.
5
@0c70535
03/15/18 14:44:45 |
joel |
mcf5272.h: Fix duplicate defintions for INT3
Closes #3344.
5
@8ce93dc9
03/15/18 14:42:10 |
joel |
lm32_evr/include/bsp.h: Remove definition of BSP_DIRTY_MEMORY to …
5
@a4eb7836
03/14/18 21:14:41 |
joel |
bsps/arm/gdbarmsim/include/bsp.h: Fix warning
5
@820c667
03/14/18 21:14:07 |
joel |
5
@52cdb134
03/14/18 21:11:51 |
joel |
bsps/sh/gensh1/include/bsp.h: Fix redefined warning
5
@ca866cc
03/14/18 20:24:37 |
joel |
mcf5206elite/include/ds1307.h: Fix extra tokens at end of #endif warning
5
@9b61342
03/16/18 13:23:45 |
Sebastian Huber |
bsp/gen83xx: Fix define redefinitions
Close #3340.
5
@478dc89
03/16/18 06:01:48 |
Sebastian Huber |
imfs: Use most efficient way to get the time
As a side-effect, this …
5
@0a7a30d
03/12/18 19:53:09 |
joel |
Add PowerPC paravirtualization support
Cannot read or write MSR when …
5
@c0443b4c
03/12/18 19:42:47 |
joel |
Add ARM Paravirtualization support
Closes #3305.
5
@7c39cab
03/12/18 19:46:29 |
joel |
Rework i386 Paravirtualization to have paravirt.h
5
@71c5552f
03/12/18 15:43:28 |
christian.mauderer |
bsp/atsam: Allow setting the drive strength.
This adds a simple …
5
@7633f5b
03/12/18 05:59:15 |
Sebastian Huber |
sparc64: Move libcpu content to cpukit
This patch is a part of the …
5
@8b5778e
03/12/18 05:37:36 |
Sebastian Huber |
sparc: Move libcpu content to cpukit
This patch is a part of the BSP …
5
@c4905d8d
03/10/18 09:17:35 |
Sebastian Huber |
bsps/arm: Move libcpu content to bsps
5
@b6755af
03/09/18 15:45:56 |
Sebastian Huber |
bsps/mips: Move libcpu content to bsps
5
@961e2ef
03/12/18 05:23:08 |
Sebastian Huber |
bsps/mips: Remove Mongoose-V README
5
@4c83f292
03/12/18 07:16:17 |
Sebastian Huber |
bsps: Remove unused RTEMS_CPU_MODEL
5
@a4570829
03/09/18 15:22:25 |
Sebastian Huber |
bsps: Remove unused memcpy() implementations
This patch is a part of …
5
@c2282d6d
03/08/18 23:28:31 |
joel |
sparc/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@55e76c2
03/08/18 23:27:37 |
joel |
sparc64/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@d978d1b
03/08/18 23:25:54 |
joel |
powerpc/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@8d96b46
03/08/18 23:24:47 |
joel |
m68k/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@5b88ec5
03/08/18 23:23:21 |
joel |
riscv/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@eb142fee
03/08/18 23:16:59 |
joel |
arm/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@43bd6b15
03/08/18 23:11:03 |
joel |
v850/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@e88abc0
03/08/18 23:10:38 |
joel |
no_cpu/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@7dde32f0
03/08/18 23:09:52 |
joel |
or1k/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@924cecd9
03/08/18 22:56:14 |
joel |
m32c/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@a518ff4b
03/08/18 22:16:42 |
joel |
moxie/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@fce900b5
03/08/18 20:15:47 |
joel |
sh/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@0706581
03/07/18 20:31:31 |
joel |
misc sh: Remove includes of rtems/score/types.h
5
@00acca28
03/08/18 19:29:17 |
joel |
nios2/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@c83d169
03/08/18 19:23:06 |
joel |
epiphany/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@c98d4748
03/08/18 19:18:43 |
joel |
lm32/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@a1df2fdc
03/08/18 19:09:17 |
joel |
i386/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@859251a
03/08/18 18:29:23 |
joel |
mips/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@cbbe68b
03/08/18 18:28:54 |
joel |
bfin/include/rtems/score/types.h: Eliminate this file
Updates #3327.
5
@2cec5ac
03/12/18 09:29:21 |
Sebastian Huber |
shell: Fix rtems_shell_init_env()
Do not discard a user provided task …
5
@0fb724a
03/12/18 09:04:11 |
Sebastian Huber |
libblock: C++ compatibility
5
@6fadb7af
03/08/18 05:33:24 |
Sebastian Huber |
config: Use new scheduler configuration defines
Update #3325.
5
@2ef85b1
03/08/18 05:20:10 |
Sebastian Huber |
config: Simplify clustered scheduler configuration
Do not use names …
5
@4dfeba3
03/09/18 15:38:31 |
amaan.cheval |
bootstrap: Use printf instead of echo -e for POSIX shells
On POSIX …
5
@16f4661f
03/09/18 07:38:18 |
Sebastian Huber |
network: Optionally install network headers
Install the network …
5
@89ac281
03/08/18 00:40:20 |
joel |
cpukit/include/mqueue.h: Delete unneeded includes
5
@c006bf50
02/19/18 19:22:37 |
joel |
score/cpu/powerpc/include/rtems/score/powerpc.h: Fix typo
5
@bc16c65
02/19/18 19:21:36 |
joel |
powerpc/include/rtems/score/types.h: Remove unused ppc_isr
Updates #3327.
5
@828049cb
03/08/18 07:48:28 |
Sebastian Huber |
sptests/sp19: Fix test output methods
Do not use fprintf() in non-fp …
5
@0231ebc
03/07/18 15:29:52 |
Sebastian Huber |
config: Remove RTEMS prefix from internal defines
Update #3325.
5
@d39cc068
03/07/18 05:37:55 |
Sebastian Huber |
bsps: More verbose bsp_fatal_extension()
Close #3318.
5
@ef900ab
03/07/18 12:01:19 |
Sebastian Huber |
capture: Fix get priority methods
5
@a4151d0
03/07/18 12:00:44 |
Sebastian Huber |
libtests/capture01: Fix configuration
5
@befae6ab
03/07/18 09:32:42 |
Sebastian Huber |
bsp/genmcf548x: Fix printk() support
5
@d440a9e
03/07/18 09:32:09 |
Sebastian Huber |
bsps/m68k: Fix entry point in linkcmds.base
Updates #3520.
5
@ff281a6f
03/07/18 09:31:10 |
Sebastian Huber |
smptests: Fix obsolete FIXME comments/code
5
@337a186
02/21/18 11:40:18 |
Sebastian Huber |
Add a simple task console driver
Close #3320.
5
@4899759
03/06/18 06:23:07 |
Thanassis.Tsiodras |
bsps/sparc: Fix global construction/destruction
The
KEEP …
5
@8b2d5b8
02/28/18 12:02:55 |
Sebastian Huber |
spglobalcon02: New test
Update #3319.
5
@0d44e251
02/22/18 15:37:26 |
Sebastian Huber |
ada/sp04: Fix test failure due to compiler opti
The SPTEST.RUN_COUNT …
5
@5618997d
02/22/18 14:34:48 |
Sebastian Huber |
termios: Fix use of uninitialized variable
Update #2840.
5
@40c623a8
09/21/17 20:20:29 |
joel |
powerpc/shared/startup/linkcmds.base: Add wildcards on some sections
5
@c232b37
02/19/18 19:05:57 |
joel |
confdefs.h: Minor rework to avoid warnings when …
5
@dad79bb9
02/07/18 17:18:38 |
joel |
unhex.c: Remove unnecessary extern of errno
Closes #2610.
5
@b2e26b7
02/12/18 13:07:36 |
dev/sc16is752: Check return values.
Escalate a failed installation of …
5
@bf70702
02/09/18 07:59:27 |
dev/sc16is752: Add GPIO access via ioctl.
5
@6878519
02/06/18 15:28:28 |
bsp/atsam: Fix cache / DMA handling in SPI.
This patch fixes the …
5
@538a0a8
02/02/18 06:06:16 |
bsp/atsam: Allow to use a decoder for SPI CS.
The SPI controller …
5
@03fecae
01/11/18 07:54:27 |
Christian.Mauderer |
bsp/atsam: Add option to disable 32kHz XTAL.
5
@a3eec5c
02/09/18 12:17:45 |
Sebastian Huber |
fsclose01: Fix task mode, use attribute
Update #1971.
5
@48aa4b5d
02/09/18 12:14:18 |
Sebastian Huber |
fsclose01: Use floating-point task
The tmpfile() uses sprintf().
5
@dc8fd01
02/09/18 07:56:20 |
Sebastian Huber |
tests: Support %g print format specifier
5
@ed24ed4e
02/08/18 09:47:16 |
Sebastian Huber |
Use _Thread_Dispatch_direct()
Use _Thread_Dispatch_direct() for …
5
@a49dfb1
02/08/18 09:46:11 |
Sebastian Huber |
rtems: Use _Per_CPU_Get_executing()
5
@9ace2648
02/08/18 08:37:25 |
Sebastian Huber |
fdt: Use self-contained mutex
Update #2843.
5
@abc2164
02/07/18 08:23:49 |
Sebastian Huber |
bsps/powerpc: Fix redefinitions
5
@18f285c
02/07/18 08:23:26 |
Sebastian Huber |
bsps/sparc64: Fix redefinitions
5
@0f7913b
02/07/18 08:23:08 |
Sebastian Huber |
network: Fix integer types
5
@2fd31117
01/09/18 05:13:32 |
Sebastian Huber |
stdio-redirector: Use self-contained mutex
Update #2843.
5
@2aa5b98
01/03/18 15:20:57 |
Sebastian Huber |
syslog: Use self-contained recursive mutex
Update #2843.
5
@3535439f
01/03/18 15:17:21 |
Sebastian Huber |
tftpfs: Use self-contained mutex
Update #2843.
5
@71a8446
01/03/18 15:09:05 |
Sebastian Huber |
libdl: Fix potential overwrite of dest buffer
Update #2843.
5
@87b7117f
01/03/18 15:07:38 |
Sebastian Huber |
libdl: Use self-contained mutex for RAP
Update #2843.
5
@d9800ac
01/03/18 05:36:10 |
Sebastian Huber |
libdl: Use self-contained recursive mutex
Update #2843.
5
@0a593c2d
01/03/18 05:24:59 |
Sebastian Huber |
ftpd: Use self-contained synchronization objects
Update #2843.
5
@a59a6182
01/02/18 15:47:14 |
Sebastian Huber |
libblock: Use self-contained mutex for media
Update #2843.
5
@868ca746
01/02/18 15:40:21 |
Sebastian Huber |
libblock: Use self-contained mutex for sparse disk
Update #2843.
5
@f9027ccf
01/02/18 15:34:54 |
Sebastian Huber |
libblock: Use self-contained mutex for flashdisk
Update #2843.
5
@c8d5bed
01/02/18 15:31:08 |
Sebastian Huber |
libblock: Use self-contained mutex for nvdisk
Update #2843.
5
@e16111b2
02/07/18 07:57:18 |
Sebastian Huber |
NFS: Fix use of self-contained objects
Update #2843.
5
@ea7f4a0c
01/30/18 23:25:20 |
joel |
sparc/*/linkcmds*: Move ENTRY() from linkcmds.base to top linkcmds
5
@3454179
02/05/18 12:54:48 |
Sebastian Huber |
bsp/altera-cyclone-v: Add device tree support
Update #3290.
5
@0f4a7391
02/05/18 10:45:17 |
Sebastian Huber |
bsps/powerpc: Remove support for mpc505
Close #3270.
5
@53b6484
02/05/18 08:57:45 |
Sebastian Huber |
termios: Remove obsolete configuration options
Update #2843.
5
