@96265c8
06/17/21 11:40:02 |
Sebastian Huber |
rtems: Add rtems_interrupt_vector_enable()
Add …
@5e33aec
06/17/21 11:37:26 |
Sebastian Huber |
rtems: Add rtems_interrupt_get_attributes()
Add a directive to query …
@c4eafae2
06/17/21 11:17:27 |
Sebastian Huber |
rtems: Generate <rtems/irq-extension.h>
Use <rtems/score/chain.h> …
@ba937459
06/16/21 06:50:02 |
Sebastian Huber |
rtems: Add rtems_interrupt_raise()
Add rtems_interrupt_raise_on(). …
@04c2c08
06/25/21 09:06:39 |
Sebastian Huber |
bsps/irq: Move handler iterate to separate file
Update #3269.
@1b3b5b84
07/06/21 06:39:01 |
Sebastian Huber |
bsps/irq: Canonicalize get/set affinity errors
Bring the error …
@efb3fc2
06/25/21 08:20:29 |
Sebastian Huber |
bsps/irq: Move get/set affinity to separate file
Update #3269.
@cc0bd08
07/25/21 15:08:04 |
Sebastian Huber |
build: Bring Item.link() in line with waf link
The LDFLAGS are placed …
@827c6ca
07/25/21 15:09:23 |
Sebastian Huber |
build: Remove superfluous library from rcxx01
@78b83601
07/23/21 14:00:10 |
Sebastian Huber |
bsps: Fix bsp_fatal_extension()
The heap protection is conditional.
@350f501a
07/21/21 05:16:22 |
Chris Johns |
bsp: Remove fatal from exit(0). Add extended heap error output
@217bf7be
07/21/21 19:20:11 |
Sebastian Huber |
build: Add "bsps/" prefix to BSP family enable
BSP family and BSP …
@5cc1695
04/19/21 08:55:33 |
robin.mueller.m |
Fixes for TMS570 BSP
When compiling the lwIP port for the TMS570, …
@b24e8142
07/16/21 12:32:03 |
robin.mueller.m |
STM32H7 ethernet pin corrections
These patches were submitted a few …
@1577a48
07/19/21 13:43:11 |
Sebastian Huber |
bsp/leon3: Remove <leon.h> include form <bsp.h>
The <leon.h> header …
@36655b8
07/16/21 11:27:00 |
Sebastian Huber |
cpukit: occured -> occurred
@b177cfc1
07/12/21 16:05:19 |
Sebastian Huber |
sparc: Prefer RTEMS_FATAL_SOURCE_EXCEPTION
Prefer …
@19e4a3d2
07/15/21 11:42:07 |
Sebastian Huber |
build: Use objects of build context for programs
@394efd4
07/15/21 10:46:54 |
Sebastian Huber |
rtems: Fix Doxygen comment
@90f250e2
07/15/21 06:15:31 |
Sebastian Huber |
build: Add the BSP family to the enable set
This makes it possible to …
@8bfc208
07/15/21 06:15:05 |
Sebastian Huber |
build: Fix format
@6c1928c
07/15/21 06:06:26 |
Sebastian Huber |
build: Prefer variant default value over family
Update #4468.
@b6092cb
07/15/21 06:05:30 |
Sebastian Huber |
build: Fix bsp_defaults command
Update #4468.
@6107148
07/15/21 06:04:32 |
Sebastian Huber |
build: Add missing default-by-family
Update #4468.
@aeaf623
07/14/21 13:00:12 |
Sebastian Huber |
spcoverage: Remove test program
This program contained an optional …
@87609ba
07/14/21 08:55:28 |
Chris Johns |
build: Fix the motorola_powerpc default baudrate
@6f2aa8ad
07/14/21 06:47:08 |
Chris Johns |
build: Use BSP family for options
- Optionally add support for …
@c7b3df3f
07/02/21 08:00:08 |
Sebastian Huber |
bsps/sparc: Improve interrupt affinity support
Fully support the …
@7b2d569
07/09/21 08:39:01 |
Sebastian Huber |
bsp/imx: Fix SMP start
Flush imx_gic_dist_base so that secondary …
@a398909
07/09/21 08:40:35 |
Sebastian Huber |
bsps/arm: Fix SMP start
Skip the data cache initialization if we are …
@89b652a5
07/07/21 14:37:27 |
christian.mauderer |
bsps/imxrt: Fix undefined symbol
@8b0e3334
07/06/21 15:53:12 |
dangipranav |
bsps/arm: Add start up support for ARMv6 RPi Models
@b28c0c66
07/07/21 12:38:40 |
Sebastian Huber |
bsp/raspberrypi: Fix <bsp/irq.h> header guard
@1b560731
07/07/21 07:52:56 |
Sebastian Huber |
bsp/imx: Fix pointer from integer warning
@c9e0445
07/06/21 05:48:46 |
Sebastian Huber |
build: Add option to customize the LINKFLAGS
@3dcfdc3b
06/29/21 07:05:06 |
richidubey |
Update test smpstrongapa01
Update smpstrongapa01 to account for task …
@b5f8504
07/05/21 16:15:27 |
richidubey |
Fix compiler warnings for schedulerstrongapa.c
@0d3453a4
05/28/21 14:54:00 |
bsps/imxrt: Simplify linkcmds and make it flexible
Calling the memory …
@95a38dd
05/28/21 13:50:31 |
bsps/imxrt: Allow different ARM PLL setting
Update #4180
@24e8ddc
07/01/21 18:32:57 |
Gedare Bloom |
m68k/uC5282: linkcmds KEEP and SORT sections
Fixes a problem with bad …
@97d5fd9
06/30/21 12:42:13 |
kinsey.moore |
Revert "bsps/zynqmp: Allow any or all CGEMs to be enabled"
This …
@cb7d268
07/01/21 14:40:01 |
Sebastian Huber |
bsp/leon3: Move bsp_interrupt_is_valid_vector()
This function is not …
@52fb74c
07/01/21 14:32:41 |
Sebastian Huber |
bsp/leon3: Fix bsp_interrupt_is_valid_vector()
The fix to address CID …
@737e18d
07/01/21 11:20:51 |
Sebastian Huber |
rtems: Do not broadcast to signal a condition var
Close #4463.
@f2b0877
06/30/21 13:22:57 |
Sebastian Huber |
bsps: Fix GICv3 support for AArch32
The GICv3 support is shared …
@c18b041b
06/28/21 13:03:22 |
kinsey.moore |
bsps/cadence-spi: Fix moduleid offset
Move the moduleid register to …
@26d61c86
06/23/21 16:57:18 |
kinsey.moore |
bsps/zynq-uart: Make post baud change kick global
The existing fix …
@4515ccf
06/29/21 16:04:03 |
Gedare Bloom |
spec/aarch64: fix abi flags for xilinx_versal_ilp32_vck190
@bb9a4b8
06/24/21 10:20:32 |
Sebastian Huber |
arm: For AArch32 use non-shareable memory
The Cortex-R52 does not …
@9b84adb
06/24/21 11:11:21 |
Sebastian Huber |
arm: Fix AARCH32_PMSA_ATTR_XN value
Update #4202.
@b357680
06/24/21 10:15:24 |
Sebastian Huber |
arm: Fix AArch32 memory attribute defines
Update #4202.
@13b18d12
06/22/21 06:13:36 |
Sebastian Huber |
arm: Disable alignment check in PMSA init
Disable the alignment check …
@10041a4c
06/08/21 19:25:47 |
kinsey.moore |
Provide the options …
@17a9103
06/24/21 16:02:53 |
Gedare Bloom |
aarch64: whitespace fixes in start.S
@93088fb8
06/24/21 15:33:22 |
Gedare Bloom |
bsps/aarch64: replace boot options with asm switch code
@76c6caad
06/23/21 02:01:17 |
Gedare Bloom |
bsps/aarch64: add non-secure mode and versal support
@2076129
06/23/21 01:57:08 |
Gedare Bloom |
bsps/aarch64: add physical secure timer
@bcad0aae
06/23/21 01:55:39 |
Gedare Bloom |
bsps/aarch64: add mnemonic for ICC_IGRPEN1_EL3
@fedd279f
06/23/21 01:52:28 |
Gedare Bloom |
bsps/dev/irq: make icspicfgr an indexable array
@e613068e
06/17/21 20:02:30 |
kinsey.moore |
aarch64: add support to drop EL3 to EL2
@3705962
06/10/21 23:03:03 |
Gedare Bloom |
aarch64/xilinx-versal: new BSPs for qemu and vck190
@6c23252
06/16/21 06:00:16 |
richidubey |
Update Strong APA Scheduler
This change allows for the migration of …
@be96cb43
06/18/21 14:44:11 |
Sebastian Huber |
sparc: Simplify trap table initialization
Move _ISR_Handler() to a …
@005c79be
06/23/21 06:24:49 |
Sebastian Huber |
bsps: bsp_interrupt_handler_dispatch_unchecked()
Add …
@b9d5f516
06/22/21 14:26:20 |
Sebastian Huber |
sparc: Move FP frame offset defines to cpuimpl.h
This makes them …
@5c30e3d3
06/22/21 13:40:39 |
Sebastian Huber |
bsps/sparc: Use rtems_interrupt_handler_install()
Avoid using …
@d73e657e
06/21/21 09:24:27 |
Sebastian Huber |
sparc: More reliable bad trap handling
Statically initialize the trap …
@955c045b
06/22/21 13:28:13 |
Sebastian Huber |
sparc: Move ISR handler install routines
Move …
@7a140e2e
06/18/21 17:28:28 |
Sebastian Huber |
bsps/sparc: Add a symbol for each trap table entry
This makes it …
@89c1e879
06/22/21 13:15:02 |
Sebastian Huber |
score: Move _ISR_Vector_table[] to separate file
The …
@8d999f30
06/22/21 13:11:27 |
Sebastian Huber |
score: Remove bogus _ISR_Nest_level setting
This variable is actually …
@26a09f2c
06/22/21 13:08:37 |
Sebastian Huber |
score: Remove _CPU_Initialize_vectors()
This CPU port macro was not …
@6b7a3858
06/19/21 12:24:26 |
Sebastian Huber |
bsp/atsam: Fix BSP_INTERRUPT_VECTOR_COUNT
Fix an off by one error.
@fdf2ee7
06/19/21 12:15:27 |
Sebastian Huber |
bsps/irq: Default BSP_INTERRUPT_VECTOR_COUNT == 0
Change the default …
@94cf67c
06/19/21 10:48:27 |
Sebastian Huber |
bsps/irq: Remove BSP_INTERRUPT_VECTOR_MAX
This define is no longer …
@3fee6620
06/19/21 10:51:58 |
Sebastian Huber |
bsps/irq: Use BSP_INTERRUPT_VECTOR_COUNT
Use …
@049e2b6
06/19/21 10:53:27 |
Sebastian Huber |
bsps/irq: Remove BSP_INTERRUPT_VECTOR_NUMBER
Replace it with …
@cd5573c
06/19/21 10:40:57 |
Sebastian Huber |
bsps/irq: Add BSP_INTERRUPT_VECTOR_COUNT
Assert …
@900a84c5
06/19/21 10:58:21 |
Sebastian Huber |
smpcapture02: Fix use of BSP_INTERRUPT_VECTOR_MAX
This define …
@af73b7b6
06/18/21 05:37:18 |
Sebastian Huber |
bsps/irq: Remove BSP_INTERRUPT_VECTOR_MIN
Remove …
@f3acb8b
06/19/21 09:31:12 |
Sebastian Huber |
bsps/irq: Assert BSP_INTERRUPT_VECTOR_MIN == 0
After building all …
@5210c7c
06/19/21 09:25:34 |
Sebastian Huber |
bsp/generic_or1k: Remove incomplete IRQ support
Update #3269.
@4146d39
06/19/21 09:20:02 |
Sebastian Huber |
bsp/genmcf548x: Change BSP_INTERRUPT_VECTOR_MIN
This BSP uses a …
@61d0be72
06/17/21 15:35:12 |
Sebastian Huber |
bsps/irq: Remove BSP_INTERRUPT_NO_HEAP_USAGE
Remove the support for …
@499a89b
06/24/21 06:26:02 |
Sebastian Huber |
grlib: Register system console as /dev/console
Close #4461.
@8416e7c
06/23/21 19:20:19 |
vijay |
bsps/powerpc, bsps/shared: Move remaining legacy networking header files
@a0a8262
06/23/21 06:11:49 |
Sebastian Huber |
bsp/leon3: Fix compile error
Fix compile error with …
@5bb5e01
05/26/21 14:33:40 |
i2c: Add non blocking read / write
This adds the possibility to open …
@b47dbbc5
06/21/21 18:12:19 |
ryan.long |
cpukit: Add timespecisnonnegative to Makefile.am
@8476715a
06/01/21 09:25:24 |
cpu/armv7m: Fix initialization of MPU regions
The write to RBAR …
@5ad17be9
05/28/21 14:58:49 |
cpu/armv7m: Avoid regions with negative size
Don't initialze regions …
@93f96455
06/11/21 07:35:30 |
jan.sommer |
bsps/i386: Update calibration of TSC to be more accurate
Closes #4455
@3ee19b7a
06/17/21 14:01:48 |
Sebastian Huber |
bsps/irq: Change license to BSD-2-Clause
Change license to …
@abe2d15
06/16/21 10:37:18 |
Sebastian Huber |
rtems: Fix rtems_task_set_affinity() docs
@11cf6ae3
06/10/21 13:14:37 |
Sebastian Huber |
grlib: Simplify apbuart_inbyte_nonblocking()
@3af1e5e
06/10/21 13:02:36 |
Sebastian Huber |
grlib: Fix apbuart_outbyte_polled() prototype
Callers usually want to …
@af69a869
06/10/21 13:01:49 |
Sebastian Huber |
grlib: Add apbuart_outbyte_wait()
@85febe7b
06/10/21 12:51:38 |
Sebastian Huber |
grlib: Remove NL -> CR in apbuart_outbyte_polled()
This is already …
@634a2c06
06/10/21 11:42:18 |
Sebastian Huber |
bsps/leon3: Auto initialization for printk()
Get rid of the hack to …
@2c07f24
06/10/21 11:04:13 |
Sebastian Huber |
grlib: Add ambapp_plb()
Replace the global variable ambapp_plb with a …
