@94cf67c
06/19/21 10:48:27 |
Sebastian Huber |
bsps/irq: Remove BSP_INTERRUPT_VECTOR_MAX
This define is no longer …
@3fee6620
06/19/21 10:51:58 |
Sebastian Huber |
bsps/irq: Use BSP_INTERRUPT_VECTOR_COUNT
Use …
@049e2b6
06/19/21 10:53:27 |
Sebastian Huber |
bsps/irq: Remove BSP_INTERRUPT_VECTOR_NUMBER
Replace it with …
@cd5573c
06/19/21 10:40:57 |
Sebastian Huber |
bsps/irq: Add BSP_INTERRUPT_VECTOR_COUNT
Assert …
@900a84c5
06/19/21 10:58:21 |
Sebastian Huber |
smpcapture02: Fix use of BSP_INTERRUPT_VECTOR_MAX
This define …
@af73b7b6
06/18/21 05:37:18 |
Sebastian Huber |
bsps/irq: Remove BSP_INTERRUPT_VECTOR_MIN
Remove …
@f3acb8b
06/19/21 09:31:12 |
Sebastian Huber |
bsps/irq: Assert BSP_INTERRUPT_VECTOR_MIN == 0
After building all …
@5210c7c
06/19/21 09:25:34 |
Sebastian Huber |
bsp/generic_or1k: Remove incomplete IRQ support
Update #3269.
@4146d39
06/19/21 09:20:02 |
Sebastian Huber |
bsp/genmcf548x: Change BSP_INTERRUPT_VECTOR_MIN
This BSP uses a …
@61d0be72
06/17/21 15:35:12 |
Sebastian Huber |
bsps/irq: Remove BSP_INTERRUPT_NO_HEAP_USAGE
Remove the support for …
@499a89b
06/24/21 06:26:02 |
Sebastian Huber |
grlib: Register system console as /dev/console
Close #4461.
@8416e7c
06/23/21 19:20:19 |
vijay |
bsps/powerpc, bsps/shared: Move remaining legacy networking header files
@a0a8262
06/23/21 06:11:49 |
Sebastian Huber |
bsp/leon3: Fix compile error
Fix compile error with …
@5bb5e01
05/26/21 14:33:40 |
christian.mauderer |
i2c: Add non blocking read / write
This adds the possibility to open …
@b47dbbc5
06/21/21 18:12:19 |
ryan.long |
cpukit: Add timespecisnonnegative to Makefile.am
@8476715a
06/01/21 09:25:24 |
cpu/armv7m: Fix initialization of MPU regions
The write to RBAR …
@5ad17be9
05/28/21 14:58:49 |
cpu/armv7m: Avoid regions with negative size
Don't initialze regions …
@93f96455
06/11/21 07:35:30 |
jan.sommer |
bsps/i386: Update calibration of TSC to be more accurate
Closes #4455
@3ee19b7a
06/17/21 14:01:48 |
Sebastian Huber |
bsps/irq: Change license to BSD-2-Clause
Change license to …
@abe2d15
06/16/21 10:37:18 |
Sebastian Huber |
rtems: Fix rtems_task_set_affinity() docs
@11cf6ae3
06/10/21 13:14:37 |
Sebastian Huber |
grlib: Simplify apbuart_inbyte_nonblocking()
@3af1e5e
06/10/21 13:02:36 |
Sebastian Huber |
grlib: Fix apbuart_outbyte_polled() prototype
Callers usually want to …
@af69a869
06/10/21 13:01:49 |
Sebastian Huber |
grlib: Add apbuart_outbyte_wait()
@85febe7b
06/10/21 12:51:38 |
Sebastian Huber |
grlib: Remove NL -> CR in apbuart_outbyte_polled()
This is already …
@634a2c06
06/10/21 11:42:18 |
Sebastian Huber |
bsps/leon3: Auto initialization for printk()
Get rid of the hack to …
@2c07f24
06/10/21 11:04:13 |
Sebastian Huber |
grlib: Add ambapp_plb()
Replace the global variable ambapp_plb with a …
@c4c8d3fd
06/10/21 11:25:26 |
Sebastian Huber |
grlib: Customizable allocation in ambapp_scan()
Make the memory …
@f89a527
06/15/21 09:37:22 |
Sebastian Huber |
arm: Fix parameter use in AARCH32_PMSA_MEM_ATTR()
Update #4202.
@98cef40
06/15/21 10:28:25 |
Sebastian Huber |
score: Comment _Thread_queue_Surrender_sticky()
The change also helps …
@6abdd89
06/14/21 07:57:51 |
Sebastian Huber |
Use a common phrase for pointer parameters
Mention the type of the …
@fad01e6c
06/10/21 07:55:42 |
Sebastian Huber |
score: Add PER_CPU_DATA_NEED_INITIALIZATION()
Make the initialization …
@27695542
06/10/21 06:41:05 |
Sebastian Huber |
splinkersets01: Test linker sets in library
Make sure that the linker …
@93afcff7
06/08/21 07:21:30 |
Sebastian Huber |
bsps/sparc: Simplify memory initialization
Directly initialize the …
@ef5a53b
06/08/21 06:53:35 |
Sebastian Huber |
bsps/sparc: Simplify stack initialization
Initialize the stacks for …
@b823c98
06/08/21 06:08:43 |
Sebastian Huber |
bsps/sparc: Unify stack initialization
Initialize the stacks in …
@07f6a61d
06/08/21 06:13:54 |
Sebastian Huber |
bsps/sparc: Remove support to load data section
Remove the support to …
@7b8119a
06/08/21 07:32:08 |
Sebastian Huber |
bsps/sparc: Remove unused bsp_mem_init symbol
@6641cc8
06/10/21 05:44:45 |
Sebastian Huber |
score: Fix initialization of thread queue context
Set …
@f83676d
04/30/21 20:01:44 |
ryan.long |
sysconf: Remove sysconf(515)
GCC originally needed this 20 years ago. …
@4127a6c
06/08/21 15:03:53 |
ryan.long |
main_edit.c: get rid of malloc warning
A warning was present when …
@8299b79
06/08/21 19:59:35 |
Gedare Bloom |
aarch64: add qemu bsps for cortex-a72
The a72 BSPs are identical to …
@7a723293
06/09/21 15:36:06 |
joel |
futimens.c, utime.c: Remove unnecessary include of <sys/stat.h>.
@dbe355b
06/08/21 18:14:53 |
joel |
fsnofs01/init.c: Check for ENOENT from utime().
The addition of the …
@34b45b1
06/08/21 07:08:43 |
Sebastian Huber |
score: Remove unused _Per_CPU_Initialize() decl
@55ce66ca
06/07/21 07:37:51 |
Sebastian Huber |
arm/fvp: Fix integer from pointer without a cast
Update #4202.
@2d1c494f
06/07/21 07:03:43 |
Sebastian Huber |
arm/fvp: Remove unused GICv2 BSP option
Update #4202.
@9429115c
06/01/21 18:05:54 |
gerberhe11 |
cpukit/libdebugger: Fix for sockaddr_in not being initialized
See …
@6a56fd9
05/28/21 00:31:53 |
gerberhe11 |
cpukit/libmisc/monitor: Fix src/dest overlap of strcpy in mon-editor.c …
@ea41722c
04/30/21 17:14:48 |
ryan.long |
Change filesystem utime_h handler to utimens_h
Also updated licenses. …
@6171a88
04/28/21 17:40:32 |
ryan.long |
psx13: Added tests for utimensat() and futimens()
Improved tests for …
@ea881bf
04/28/21 16:44:29 |
ryan.long |
libcsupport: Implement utimes() in terms of utimensat()
utimes() now …
@bb704123
04/28/21 16:42:50 |
ryan.long |
libcsupport: Implement utime() in terms of utimensat()
utime() now …
@335f705
04/28/21 16:40:56 |
ryan.long |
libcsupport: Added futimens() and utimensat()
Created futimens.c and …
@2deba02
03/30/21 15:04:07 |
ryan.long |
main_help.c: Do not care what char is returned by getchar()
CID …
@f29b312e
03/25/21 14:10:39 |
ryan.long |
main_cp.c: Ignore return value from stat()
CID 26051: Unchecked …
@a187b09
03/25/21 13:59:26 |
ryan.long |
gen_uuid.c: Ignore return values from fcntl()
CID 1049146: Unchecked …
@1568965
05/26/21 09:26:59 |
thread-API: Add rtems_*mutex_try_lock
This adds a …
@023a2709
05/26/21 07:39:13 |
cpukit: Add description of release version numbers
The release …
@bf36f5de
05/28/21 05:47:52 |
Sebastian Huber |
score: Add RTEMS_UNREACHABLE() to a group
@d0eaf3ec
01/08/21 23:07:34 |
kinsey.moore |
spec/aarch64: Add BSPs for real ZynqMP hardware
Add the BSPs for …
@5fe49a08
05/18/21 19:51:46 |
kinsey.moore |
bsps/aarch64: Add MMU driver to relax alignment
Currently, the …
@ae5e1d9
05/21/21 13:56:13 |
kinsey.moore |
bsps/a53: Increase available RAM
The default available RAM on the A53 …
@8810e08
05/18/21 19:49:20 |
kinsey.moore |
bsps/aarch64: Advertise cache function support
Ensure that cache …
@12ec459
05/18/21 12:56:54 |
kinsey.moore |
bsps/aarch64: Align MVAs consistently
This fixes a bug where …
@25ca2ec
05/18/21 12:55:11 |
kinsey.moore |
bsps/aarch64: Break out system registers
Break out system register …
@2fdd00fc
05/27/21 05:11:36 |
Sebastian Huber |
rtems: Document new rtems_task_delete() error
Update #4414.
@e2011dc
05/26/21 22:25:45 |
gerberhe11 |
cpukit/libpci: fix potential buffer overflow in pci_cfg_print_code.c
@342fe198
03/12/21 15:57:59 |
kinsey.moore |
score/aarch64: Align context validation frame
Ensure the stack …
@de694b75
05/21/21 14:52:54 |
Sebastian Huber |
score: Direct thread dispatch in a self restart
Commit …
@ce6319a
05/20/21 15:15:53 |
Sebastian Huber |
score: Fix _Thread_Cancel()
The _Thread_Cancel() (in contrast to …
@29187be
05/17/21 12:51:45 |
Sebastian Huber |
posix: Allow pthread_cancel() from within ISRs
Close #4413.
@3cef3198
05/17/21 12:46:02 |
Sebastian Huber |
score: Simplify calling _Thread_Exit()
Move common code into …
@b81d1ffd
05/14/21 16:53:55 |
Sebastian Huber |
rtems: Return RTEMS_CALLED_FROM_ISR
If rtems_task_delete() is called …
@76d5722b
05/21/21 21:30:20 |
joel |
sysinit: Do not open console when just referencing reentrancy …
@402a206a
05/21/21 21:29:42 |
joel |
powerpc/.../sbrk.c: Do not reference errno.
Closes #4r37.
@f9d59075
05/21/21 21:29:00 |
joel |
ppc-irq-legacy.c: Use rtems_malloc() instead of malloc().
Closes #4438.
@71521ff2
04/13/21 18:45:56 |
vijay |
telnetd.c: Remove RTEMS_NETWORKING check
Set the priority manually to …
@a5fd293
04/14/21 05:43:40 |
vijay |
testsuites: Remove telnetd01
telnetd01 test cannot be run without a …
@a89ecaa1
05/18/21 10:50:41 |
Sebastian Huber |
score: Simplify thread queue timeout handling
Add …
@24c62932
05/18/21 09:28:08 |
Sebastian Huber |
posix: Fix use of clock for relative times
Close #4426.
@d45f87cf
05/17/21 11:35:42 |
Sebastian Huber |
score: Add _CPU_Context_switch_no_return()
The …
@80b3c938
05/17/21 14:55:15 |
Sebastian Huber |
score: Move _Thread_queue_Queue_get_name_and_id()
Move this …
@9918735
05/17/21 14:46:12 |
Sebastian Huber |
posix: Use RTEMS_POSIX_API in clock_nanosleep()
It is only possible …
@815a943
05/17/21 14:39:52 |
Sebastian Huber |
posix: Move clock_nanosleep()
Move clock_nanosleep() to a separate …
@15e26f4
05/12/21 09:34:52 |
bsps/imxrt: Enable DMA clock
The EDMA is intialized so make sure the …
@691fec40
05/11/21 11:46:56 |
bsps/imxrt: Fix OCRAM, ITCM and DTCM sizes
The sizes are configurable …
@988cc1a
04/12/21 14:53:43 |
bsps/imxrt: Add addresses and interrupts to dts
Add addresses and …
@c3056666
05/12/21 06:46:30 |
bsps/imxrt: Reduce devicetree size
Remove symbols that would be …
@08e4e6f2
04/07/21 13:05:26 |
bsps/imxrt: Fix documentation error
Update #4180
@2cc25cf
05/14/21 15:33:24 |
Sebastian Huber |
score: Add and use _Per_CPU_Is_ISR_in_progress()
Add …
@6f2c8f3
05/14/21 15:02:57 |
Sebastian Huber |
score: Improve parameters in _Thread_Change_life()
@98cb84e
05/17/21 06:04:07 |
Sebastian Huber |
arm/altera-cyclone-v: Fix compile error
Update #4406.
@73ebf9a
05/14/21 12:54:42 |
Sebastian Huber |
rtems: Fix task restart within interrupt context
rtems_task_restart() …
@b9083c55
05/14/21 12:53:19 |
Sebastian Huber |
rtems: Always set the real priority during restart
Unconditionally …
@57be57c7
05/14/21 07:31:47 |
Sebastian Huber |
score: Return status in _Thread_Restart_other()
This simplifies …
@b87d2a6
05/14/21 07:14:11 |
Sebastian Huber |
rtems: Check entry point in rtems_task_start()
Close #4410.
@410317a
05/12/21 05:11:48 |
Sebastian Huber |
validation: Add INVALID_ID to tx-support.h
@bc29c7c
04/12/21 04:58:44 |
Sebastian Huber |
validation: Add support library
Add a library for support functions …
@45a34953
05/14/21 06:09:34 |
Sebastian Huber |
rtems: Add TOD_Ticks_validation
Replace defines with an enum.
Update …
@523867d
05/11/21 15:27:20 |
Sebastian Huber |
rtems: Constify rtems_task_wake_when()
Add a parameter to …
