@6dbbd277
02/23/17 23:51:05 |
david |
libfdt: Remove undefined behaviour setting empty properties
The …
5
@8cd96f47
11/03/16 15:47:42 |
b-fair |
libfdt: add missing errors to fdt_strerror()
Some error values were …
5
@d8c856b
10/17/16 06:08:24 |
yamada.masahiro |
libfdt: fix fdt_stringlist_search()
If fdt_getprop() fails, negative …
5
@aa9389f
10/17/16 06:08:23 |
yamada.masahiro |
libfdt: fix fdt_stringlist_count()
5
@c753d9d
10/11/16 08:10:31 |
maxime.ripard |
fdt: strerr: Remove spurious BADOVERLAY
There's one …
5
@4f7c3ac9
10/06/16 11:39:56 |
maxime.ripard |
libfdt: Add BADPHANDLE error string
The BADPHANDLE error was missing …
5
@e879a98d
09/30/16 13:57:16 |
maxime.ripard |
libfdt: Add overlay application function
The device tree overlays are …
5
@b0ceda54
09/30/16 13:57:15 |
maxime.ripard |
libfdt: Extend the reach of FDT_ERR_BADPHANDLE
So far, the BADPHANDLE …
5
@2679534b
09/30/16 13:57:14 |
maxime.ripard |
libfdt: Add new errors for the overlay code
Add a few new error codes …
5
@f670acbf
09/26/16 16:12:26 |
thuth |
Fix some typing errors in libfdt.h and livetree.c
Correct some typos …
5
@607b70f
08/22/16 09:55:49 |
yamada.masahiro |
libfdt: simplify fdt_del_mem_rsv()
The variable "err" is unneeded.
5
@6112fb0b
07/29/16 09:55:48 |
maxime.ripard |
libfdt: Add fdt_setprop_inplace_namelen_partial
Add a function to …
5
@2086bbc8
07/27/16 12:55:56 |
maxime.ripard |
libfdt: Add fdt_getprop_namelen_w
Add a function to retrieve a …
5
@220cde8
07/27/16 12:55:55 |
maxime.ripard |
libfdt: Add max phandle retrieval function
Add a function to retrieve …
5
@eda76d4
07/27/16 12:55:54 |
maxime.ripard |
libfdt: Add iterator over properties
Implement a macro based on …
5
@da8eff99
07/27/16 12:55:53 |
treding |
libfdt: Add a subnodes iterator macro
The fdt_for_each_subnode() …
5
@8bbd8c7
03/07/16 03:12:48 |
sjg |
Correct a missing space in a fdt_header cast
The code style here is …
5
@8f6fb28c
03/07/16 03:12:47 |
sjg |
Correct line lengths in libfdt.h
There are a few lines that are over …
5
@34e6ae62
03/07/16 03:12:46 |
sjg |
Correct space-after-tab in libfdt.h
There are a few places with a …
5
@0ddfe029
02/12/16 05:45:12 |
yamada.masahiro |
libfdt: simplify fdt_node_check_compatible()
Because …
5
@87acb61e
12/17/15 06:19:11 |
david |
libfdt: Fix undefined behaviour in fdt_offset_ptr()
Using pointer …
5
@b41cd6c
12/02/15 00:43:10 |
courtney.cavin |
libfdt: check for potential overrun in _fdt_splice()
This patch …
5
@bda8f80
07/18/18 06:54:57 |
Sebastian Huber |
score: Add a FALLTHROUGH comment to kvprintf()
This change was added …
5
@ffd4617
07/17/18 13:33:49 |
Sebastian Huber |
score: Fix _Scheduler_EDF_SMP_Set_affinity()
Commit …
5
@1b57b75
07/18/18 05:14:41 |
Sebastian Huber |
bsp/realview-pbx-a9: Support unassigned processors
5
@da0cbef2
07/16/18 06:22:57 |
Sebastian Huber |
score: Avoid structurally dead code
This was spotted by Coverity Scan.
5
@6ec7f21
07/16/18 06:31:05 |
Sebastian Huber |
posix: Fix rwlock auto initialization
Add more test cases.
5
@00a19d6
07/05/18 07:06:56 |
Sebastian Huber |
jffs2: Add README
Add README to document the corrspending Linux …
5
@682ecda
02/12/18 21:03:10 |
boris.brezillon |
mtd: Unconditionally update ->fail_addr and ->addr in part_erase()
5
@808c092
02/12/18 21:03:09 |
boris.brezillon |
mtd: Stop assuming mtd_erase() is asynchronous
None of the …
5
@638948c
02/23/17 00:34:00 |
colin.king |
jffs2: fix spelling mistake: "requestied" -> "requested"
trivial fix …
5
@63c5c53e
02/02/17 18:15:33 |
mingo |
sched/headers: Prepare to move signal wakeup & sigpending methods from …
5
@976af92
09/29/16 15:48:31 |
agruenba |
jffs2: Remove jffs2_{get,set,remove}xattr macros
When …
5
@0ec9bbc
06/10/16 14:51:30 |
torvalds |
vfs: make the string hashes salt the hash
We always mixed in the …
5
@fb5bc64d
04/01/16 12:29:47 |
kirill.shutemov |
mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macros
5
@0f5030d
02/01/16 12:00:25 |
David.Woodhouse |
jffs2: Improve post-mount CRC scan efficiency
We need to finish doing …
5
@e4fa3ad
02/01/16 14:04:46 |
David.Woodhouse |
Fix directory hardlinks from deleted directories
When a directory is …
5
@1e6d56e
02/01/16 12:37:20 |
David.Woodhouse |
jffs2: Fix page lock / f->sem deadlock
With this fix, all code paths …
5
@c9670dd1
01/22/16 23:11:02 |
penguin-kernel |
tree wide: use kvfree() than conditional kfree()/vfree()
There are …
5
@410dd26
09/29/15 03:23:55 |
fangwei1 |
jffs2: fix a memleak in read_direntry()
Need to free the memory …
5
@4dc16ea
02/26/14 02:27:40 |
computersforpeace |
jffs2: fix unbalanced locking
Li Zefan reported an unbalanced locking …
5
@8e55f0d
02/10/15 20:49:48 |
chenjie6 |
jffs2: fix handling of corrupted summary length
sm->offset maybe …
5
@8bcd5a22
01/11/15 16:36:48 |
rickard_strandqvist |
jffs2: compr_rubin: Remove unused function
Remove the function …
5
@2c5980f
11/27/14 11:05:46 |
geert+renesas |
jffs2: Drop bogus if in comment
Signed-off-by: Geert Uytterhoeven …
5
@e315b460
08/01/14 19:13:40 |
viro |
kill wbuf_queued/wbuf_dwork_lock
schedule_delayed_work() happening …
5
@9da567b2
08/08/14 21:23:14 |
yinghai |
initramfs: support initramfs that is bigger than 2GiB
Now with 64bit …
5
@a60ac5ca
01/06/14 13:36:55 |
ajesh |
jffs2: Fix crash due to truncation of csize
mounting JFFS2 partition …
5
@03cba49d
01/06/14 13:36:54 |
kamlakant.patel |
jffs2: Fix segmentation fault found in stress test
Creating a large …
5
@d60c1665
02/12/14 20:44:56 |
lizefan |
jffs2: avoid soft-lockup in jffs2_reserve_space_gc()
We triggered …
5
@52c50c78
02/12/14 20:44:57 |
lizefan |
jffs2: remove from wait queue after schedule()
@wait is a local …
5
@e650f4fc
12/20/13 13:16:47 |
hch |
jffs2: use generic posix ACL infrastructure
Also don't bother to set …
5
@1465e70c
01/23/14 23:56:11 |
cody |
fs/jffs2: use rbtree postorder iteration helper instead of opencoding
5
@22d9575
07/04/18 14:12:14 |
Sebastian Huber |
linux: Add rbtree_postorder_for_each_entry_safe()
Update #3465.
5
@0cb4257
07/03/18 18:32:31 |
Sebastian Huber |
linux: Simplify <linux/rbtree.h>
Remove the placeholder struct …
5
@877aeab
07/04/18 14:14:35 |
Sebastian Huber |
linux: Install <linux/rbtree.h>
This makes it possible to test this …
5
@6539bea
06/29/18 18:00:28 |
Sebastian Huber |
score: Add postorder tree iteration support
Update #3465.
5
@cf811a4
07/09/18 11:12:57 |
amaan.cheval |
x86_64/console: Add NS16550 polled console driver
This addition …
5
@76c03152
07/09/18 11:12:56 |
amaan.cheval |
bsp/x86_64: Minimal bootable BSP
Current state:
- Basic context …
5
@1a19239
07/06/18 09:20:31 |
Sebastian Huber |
bsp/riscv: Add console support for NS16550 devices
Update #3433.
5
@31f90a2
07/06/18 11:52:22 |
Sebastian Huber |
bsp/riscv: Simplify printk() support
This is a prepartion to add …
5
@bca36d9
07/06/18 09:07:20 |
Sebastian Huber |
riscv: Add LADDR assembler define
An address must be loaded to a …
5
@dd32e2b2
07/06/18 06:12:40 |
Sebastian Huber |
riscv: Implement CPU counter
Update #3433.
5
@6418c91d
07/06/18 07:25:57 |
Sebastian Huber |
Update config.guess and config.sub
Update via:
wget -O config.guess …
5
@fc5cc9a
07/05/18 06:54:34 |
Sebastian Huber |
bsps/arm: Include missing header file
5
@d3dff40
07/04/18 14:15:22 |
Sebastian Huber |
bsps: Update headers.am
5
@e755782
07/03/18 07:54:47 |
Sebastian Huber |
riscv: Clear reservations
See also RISC-V User-Level ISA V2.3, …
5
@77fbbd6
07/03/18 09:50:53 |
Sebastian Huber |
posix: Check for new <pthread.h> prototypes
Update #3342.
Update #3343.
5
@e07b51a7
07/02/18 13:21:36 |
Sebastian Huber |
riscv: Fix fcsr initialization
Update #3433.
5
@b36bf5b
06/29/18 10:55:28 |
Sebastian Huber |
score: Increase PER_CPU_CONTROL_SIZE_APPROX
Increase the …
5
@79d69ae
06/29/18 10:08:01 |
Sebastian Huber |
riscv: Fix SMP context switch support
Update #3433.
5
@109bc1c7
06/29/18 06:07:02 |
Sebastian Huber |
riscv: Add SMP context switch support
Update #3433.
5
@52352387
06/28/18 07:32:26 |
Sebastian Huber |
riscv: Add floating-point support
Update #3433.
5
@995e91e8
06/28/18 06:21:44 |
Sebastian Huber |
riscv: Fix global construction
Update #3433.
5
@694e79a0
06/28/18 06:20:47 |
Sebastian Huber |
riscv: Add TLS support
Update #3433.
5
@afb60eb
06/27/18 12:46:06 |
Sebastian Huber |
riscv: Remove dead code
Update #3433.
5
@e43994d
06/27/18 08:05:50 |
Sebastian Huber |
riscv: Optimize context switch and interrupts
Save/restore …
5
@a8188730
06/27/18 07:43:39 |
Sebastian Huber |
riscv: Fix _CPU_Context_Initialize() prototype
Update #3433.
5
@dffc08c
06/28/18 11:55:29 |
Sebastian Huber |
riscv: Fix interrupt save/restore
Update #3433.
5
@40f81ce6
06/27/18 10:18:09 |
Sebastian Huber |
riscv: Implement _CPU_Context_validate()
Update #3433.
5
@71af1a4
06/27/18 10:17:21 |
Sebastian Huber |
riscv: Make some CPU port defines visible to asm
Move SREG and LREG …
5
@8f035cb
06/27/18 06:57:08 |
Sebastian Huber |
riscv: Implement _CPU_Context_volatile_clobber()
Update #3433.
5
@b706b4a
06/27/18 06:54:13 |
Sebastian Huber |
riscv: Remove mstatus from thread context
The mstatus register …
5
@2987c4f
06/27/18 06:43:25 |
Sebastian Huber |
riscv: Remove x8 initialization
The RISC-V psABI
5
@04698eb
06/27/18 06:42:48 |
Sebastian Huber |
riscv: Properly align the thread stack
Update #3433.
5
@a49a3c8e
06/27/18 06:37:34 |
Sebastian Huber |
riscv: Do not clear thread context
Do not clear the complete thread …
5
@9510742
06/27/18 06:35:13 |
Sebastian Huber |
riscv: Fix CPU_STACK_ALIGNMENT
According to the RISC-V psABI
5
@98f051e
06/27/18 06:08:10 |
Sebastian Huber |
riscv: Remove RISCV_GCC_RED_ZONE_SIZE
The current ABI says that there …
5
@9704d86f
06/26/18 06:53:28 |
Sebastian Huber |
riscv: Enable interrupts during dispatch after ISR
The code sequence …
5
@0fd8287
06/26/18 05:15:28 |
Sebastian Huber |
riscv: Add _CPU_Get_current_per_CPU_control()
Update #3433.
5
@3be4478f
06/26/18 05:13:28 |
Sebastian Huber |
riscv: Avoid namespace pollution
Remove <rtems/score/riscv-utility.h> …
5
@bc3bdf2
06/28/18 12:59:38 |
Sebastian Huber |
riscv: Optimize and fix interrupt disable/enable
Use the atomic read …
5
@ff7b104
06/27/18 05:47:33 |
Sebastian Huber |
bsp/riscv: Remove bsp_interrupt_handler_default()
It duplicated the …
5
@cdfed94f
06/25/18 09:12:24 |
Sebastian Huber |
bsp/riscv: Rework clock driver
Use device tree provided timebase …
5
@1232cd46
06/25/18 06:44:16 |
Sebastian Huber |
bsp/riscv: Add device tree support for console
Update #3433.
5
@c558cc4
06/28/18 11:04:58 |
Sebastian Huber |
bsp/riscv: Fix vector table for lp64
Update #3433.
5
@5f5c450
06/22/18 11:58:11 |
Sebastian Huber |
bsp/riscv: Add SMP startup synchronization
Update #3433.
5
@fe2cd01b
06/22/18 06:01:48 |
Sebastian Huber |
Update #3433.
5
@2086948a
05/11/18 04:54:59 |
Sebastian Huber |
riscv: Add dummy SMP support
Update #3433.
5
@853c5ef
05/11/18 04:25:47 |
Sebastian Huber |
build: Enable RISC-V SMP build
Update #3433.
5
@7c3b0df1
06/22/18 11:30:49 |
Sebastian Huber |
riscv: Implement ISR set/get level
Fix prototypes.
Update #3433.
5
