Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems-tools/tester
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @b4b61b5   10/11/17 11:50:52 Chris Johns testing: Add a PC BSP configuration. 5
(edit) @2d6d1c5   10/11/17 11:50:16 Chris Johns testing: Update BSP configurations. 5
(edit) @4b76b8e   10/11/17 11:49:17 Chris Johns testing: Generate console message on a second TFTP exe request. 5
(edit) @0eb8400   10/11/17 11:48:46 Chris Johns testing: Print the output after the result. Easier to find and review … 5
(edit) @5df7c3c   10/10/17 18:07:15 Sebastian Huber Install missing files 5
(edit) @662e1f7   10/10/17 02:30:31 Chris Johns tester: Add a tester off to turn the target off when finished. … 5
(edit) @9580804   10/07/17 07:57:24 Chris Johns Add a target start and target reset to manage boards that do not boot … 5
(edit) @68cbfc3   10/05/17 03:24:11 Chris Johns tester: Add Zedboard. 5
(edit) @2ae9b6d   10/05/17 03:21:33 Chris Johns tester: Telnet console reopens the connection if it fails or closes. … 5
(edit) @0737b46   10/05/17 03:21:01 Chris Johns tester: Add a target reset regular expression to detect a reset. 5
(edit) @3c7cd05   09/21/17 11:34:34 Chris Johns tester: Fix the TFTP ok to kill deadlock. 5
(edit) @3ed65c0   09/21/17 11:33:56 Chris Johns Lower the step size for the TFTP timeout. 5
(edit) @3a867a4   09/21/17 08:26:20 Chris Johns Add TFTP as a back end option for testing. Add telnet as a console … 5
(edit) @f4378ea   09/14/17 23:04:55 joel tester/covoar/DesiredSymbols.cc: Now compiles on Cygwin 5
(edit) @f4773ac   09/13/17 15:45:30 cpodonnell8 covoar: Add function defs to fix Windows build errors. Closes #3129 5
(edit) @cb0677b   09/10/17 21:11:19 Chris Johns Add Windows includes so the rtemstoolkit builds. Closes #3128. 5
(edit) @f9a4b2c   08/26/17 08:15:58 cpodonnell8 covoar: Remove config file and test critical options are valid. 5
(edit) @4600903   08/26/17 08:15:57 cpodonnell8 covoar/CoverageReaderQEMU.cc: Remove trace block matching check. This … 5
(edit) @6a4859e   08/26/17 08:15:56 cpodonnell8 covoar: Use rld tempfile and add signals to clean up in event of … 5
(edit) @4cee5c3   08/26/17 08:15:55 Krzysztof Miesowicz covoar/wscript: Add paths to rtemstoolkit to build. Co-Author: … 5
(edit) @9534157   08/26/17 08:15:54 cpodonnell8 covoar/ObjdumpProcessor.cc: Remove jump tables from the end of … 5
(edit) @cb018bc   08/26/17 08:15:53 hermann19829 covoar: Add information to improve diagnostics. 5
(edit) @b857151   08/26/17 08:15:52 hermann19829 covoar: Fix buffer overflow and fix br tag in html report. Co-Author: … 5
(edit) @05b4cfb   08/26/17 08:15:51 chouteau covoar/qemu-traces.h: Change to match current couverture-qemu file. 5
(edit) @fd0bcc5   08/22/17 14:54:48 Sebastian Huber tester: Add qoriq_e6500_64 Update #3082. 5
(edit) @0ea1c27   08/07/17 06:01:59 Sebastian Huber tester: Add imx7 5
(edit) @581b071   07/31/17 14:29:48 joel rtems-bsps-i386.ini: Remove Edison 5
(edit) @738716d   07/31/17 05:33:56 Sebastian Huber tester: Update BSP names 5
(edit) @9f72ea6   07/17/17 08:42:42 Jiri Gaisler Added test scripts for standalone sis 5
(edit) @d67c20a   05/31/17 12:15:59 Chris Johns rtems-bsp-builder: Use the profile's architecture's BSP lists. 5
(edit) @37a0843   05/24/17 02:27:38 Chris Johns rtems-bsp-builder: Refactor to add jobs. This change adds job support … 5
(edit) @52cfa18   05/24/17 02:12:55 Chris Johns rtems-bsp-builder: Fix the powerpc configuration. 5
(edit) @61ddcfc   05/18/17 05:22:43 Chris Johns rtems-bsp-builder: Add as a build type. 5
(edit) @ef38b5d   05/15/17 01:48:44 Chris Johns rtemstoolkit: Add Python INI configuration support. 5
(edit) @9a8a03c   05/15/17 01:29:46 Chris Johns rtems-bsp-builder: Add all architectures and BSPs. - Add support to … 5
(edit) @85e14e0   05/10/17 11:09:02 Chris Johns rtems-bsp-builder: Fix excluding builds. Excluding builds was not … 5
(edit) @ad15f6b   04/27/17 20:49:23 Chris Johns rtems-bsp-builder: Fix passes report alignment. 5
(edit) @096c95e   04/27/17 20:36:32 Chris Johns rtems-bsp-tester: Make the failure and pass report more compact. 5
(edit) @fc22d2a   04/26/17 12:07:15 Chris Johns rtems-bsp-builder: Fix time in warnings report, wrapping in reports. … 5
(edit) @c2df65b   04/26/17 10:01:23 Chris Johns rtems-bsp-builder: Fix access when there are no messages. 5
(edit) @ab57e79   04/24/17 23:32:18 Chris Johns rtems-test: Fix gdb bug. 5
(edit) @b89a7e4b   04/24/17 22:40:19 Chris Johns rtems-bsp-builder: Fix the build sets excludes. 5
(edit) @5d1edd5   04/24/17 16:39:56 Chris Johns rtems-bsp-builder: Refactor for better config format, warnings and … 5
(edit) @7d3350d   04/24/17 14:31:44 Chris Johns rtemstoolkit: Move host support access into a separate module. Moving … 5
(edit) @15a3e06   04/04/17 03:32:03 Chris Johns tester: Add support for expected-fail, user-input, and benchmarks. … 5
(edit) @bce090b   03/27/17 23:20:14 Chris Johns rtems-bsp-builder: Fix the counts to accumulate. 5
(edit) @056bd4b   03/15/17 04:23:40 Chris Johns rtems-bsp-builder: Fix profile error message. 5
(edit) @a72a462a   12/12/16 22:56:25 Chris Johns bsp-builder: Fix final output errors. 5
(edit) @d3d771e   11/30/16 23:21:13 Chris Johns bsp-builder: Add support for builds. Add build support where a build … 5
(edit) @8a7be63   11/29/16 21:13:33 Chris Johns bsp-bulder: Get the end time when building an architecture. 5
(edit) @a252faf   08/30/16 08:10:17 Chris Johns bsp-builder: Results format fixes. 4.105
(edit) @06c3ccd   08/29/16 01:47:04 Chris Johns bsp-builder: Fix bugs. 4.105
(edit) @e9fb4c5   08/25/16 06:14:57 Chris Johns bsp-builder: Add lm3s6965_qemu to ARM bsp list. Fix network-debug options. 4.105
(edit) @f7f0704   08/25/16 06:13:18 Chris Johns bsp-builder: Fix column printing of the arch/bsp. 4.105
(edit) @8e13939   08/19/16 01:56:09 Chris Johns bsp-builder: Print one results report only. 4.105
(edit) @9a1daba   08/18/16 23:55:03 Chris Johns bsp-builder: Fix results report columns. 4.105
(edit) @3a92a54   08/18/16 11:00:50 Chris Johns bsp-builder: Add ARM bsps. 4.105
(edit) @51e19af   08/18/16 11:00:29 Chris Johns bsp-builder: Support per BSP excludes. 4.105
(edit) @57e4172   08/18/16 04:24:45 Chris Johns tester: handle compile argument warnings. 4.105
(edit) @3e14594   07/06/16 07:58:56 Chris Johns Add rtems-bsp-builder. This is a testing tool that builds BSPs with a … 4.105
(edit) @dfa2468   03/16/16 10:39:39 Chris Johns tester: Fix reraising an exception with Python2 and Python3. Updates … 4.105
(edit) @4bcf18b   03/16/16 05:22:35 Chris Johns tester/sis: Provide the -nouartrx to avoid blocking on stdin. 4.105
(edit) @1845e91   03/16/16 05:21:57 Chris Johns tester: Provide a gdb kill method to aid clean ups on ctrl-C. 4.105
(edit) @6f8b07c   03/14/16 03:59:11 Chris Johns rtemstoolkit: Fix execute's writer thread to not eval() the input. … 4.105
(edit) @c9ed248   03/09/16 03:34:26 Chris Johns Remove exception test code left in. Updates #2619. 4.105
(edit) @6fa359c   03/09/16 03:29:14 Chris Johns Master branch version is 4.12. 4.105
(edit) @b7a9c81   03/09/16 03:28:57 Chris Johns sis: Option not present with SPARC sim. 4.105
(edit) @2de37f3   03/09/16 03:27:42 Chris Johns Python 2 and python 3 refactor fixes. Updates #2619. 4.105
(edit) @a5d243d   03/04/16 01:10:09 Chris Johns tester: Remove the RT version.py and use the toolkit's version. 4.105
(edit) @b0fa2ae   03/03/16 05:46:18 Chris Johns Update rtems-tool to support Python 2 and 3. Add solaris and netbsd. … 4.105
(edit) @7148cae   02/19/16 03:46:15 Chris Johns Add Windows specific waf support for MSYS2. Limit the compilers used … 4.105
(edit) @de1beea   02/19/16 00:26:51 Chris Johns Disable installing PYO and PYC. Fix install paths. Installing PYO and … 4.105
(edit) @f775869   12/15/15 21:37:10 Chris Johns Fix running rtems-test from inside the git clone. 4.105
(edit) @2df531a   12/11/15 00:56:12 admin bsps/m32rsim*: Remove closes #2447. 4.105
(edit) @ea51d2a   12/14/15 00:49:25 admin bsps/h8sim*: Remove closes #2453. 4.105
(edit) @a6f5f18   12/11/15 06:15:34 Chris Johns Fix how to use the waf py feature to get py source and pyo file … 4.105
(edit) @efc4f09   12/09/15 09:08:19 Chris Johns Add release versioning support. Support a top level VERSION file that … 4.105
(edit) @04a5204   11/12/15 10:15:23 Sebastian Huber Python 3 compatibility 4.105
(edit) @baa798a   10/18/15 22:14:57 Chris Johns Update the versions strings. 4.105
(edit) @0382b68   10/18/15 08:19:08 Chris Johns Fix Windows build issues. Fix biulding the mmap Windows code. Fix … 4.105
(edit) @92935ed   07/22/15 11:38:46 Ric Claus qemu.cfg: Options changed to capture test output 4.105
(edit) @9d266e8   07/22/15 10:11:32 Ric Claus xilinx_zynq_a9_qemu_smp.mc: Change realview_pbx_a9_qemu reference to … 4.105
(edit) @3f3582f   04/19/15 11:04:36 Hesham Almatary Rename or1ksim BSP to generic_or1k 4.104.115
(edit) @a68557d   04/14/15 23:03:28 Joel Sherrill bf537Stamp: Add configuration files 4.104.115
(edit) @d2d91f5   04/04/15 14:24:36 Joel Sherrill leon3-tsim*: First attempt at LEON3 on tsim support The rtems-tester … 4.104.115
(edit) @c0449d5   04/04/15 14:24:24 Joel Sherrill lm32_evr_gdbsim: Add configuration files 4.104.115
(edit) @7d784d2   04/04/15 14:24:02 Joel Sherrill psim*.mc: Fix typo 4.104.115
(edit) @e98d5fa   03/29/15 16:35:59 Joel Sherrill Add configurations for erc32, leon2, and leon3 in GDB SIS These … 4.104.115
(edit) @f5b639b   03/27/15 03:21:56 Chris Johns rtems-tester: Remove repeated install line in wscript. Fixes #2312. 4.104.115
(edit) @20feafb   03/26/15 18:20:15 Joel Sherrill Add rtems-tester configurations for simsh family of BSPs 4.104.115
(edit) @a30ec56   03/12/15 22:29:37 Joel Sherrill Add configurations for all h8 GDB simulator BSP variants 4.104.115
(edit) @8abbe80   03/12/15 22:17:56 Joel Sherrill Add configurations for all arm GDB simulator BSP variants 4.104.115
(edit) @ab5e0c5   03/12/15 21:55:43 Joel Sherrill Add configuration for m32csim BSP for simulator in GDB 4.104.115
(edit) @b938414   03/12/15 18:51:32 Joel Sherrill Add configuration for m32rsim BSP for simulator in GDB 4.104.115
(edit) @71fb99b   03/12/15 17:47:13 Joel Sherrill Add configurations for all v850 GDB simulator BSP variants 4.104.115
(edit) @01a4192   02/22/15 06:07:10 asahasra Modified waf scripts to have a minimum python version requirement of … 4.104.115
(edit) @e143a62   02/16/15 00:27:18 Chris Johns Fix the chmod octal value to use the correct Python syntax. 4.104.115
(edit) @a8c4f3f   02/16/15 00:25:22 Chris Johns Update the Windows header to direct.h for _mkdir per the MSDN. 4.104.115
(edit) @05fe73d   02/08/15 07:40:35 Chris Johns Fix the tester wscript. 4.104.115
(edit) @9600c39   02/08/15 07:14:16 Chris Johns Fixes to the run the waf built tests when installed. 4.104.115
