@a293ddc
01/18/18 02:38:52 |
Chris Johns |
sb: Disable a log file for the check command.
Fix a minor issue in …
5
@3ddbd79
01/18/18 02:16:47 |
Chris Johns |
sb: Add an orphan check to sb-check.
The orphans check lets you see …
5
@ea15753
11/22/17 15:33:04 |
joel |
source-builder/sb/bootstrap.py: Do not reference bsp_specs to find …
5
@089327b
11/08/17 12:19:02 |
Sebastian Huber |
Change RSB version from 4.12 to 5
Update #3220.
5
@4dc9bf3
10/31/17 00:57:21 |
Chris Johns |
sb: Add platform reporting for better host reviewing in posted email …
5
@4e7fdaf
10/31/17 00:56:23 |
Chris Johns |
sb: Make a to_addr comma list a Python list for sending.
5
@e274bdf
10/28/17 05:04:14 |
Hesham Almatary |
RSB - RISC-V: Add scripts to build RISC-V's simulator
Update #3109
5
@8cdc8e4
10/27/17 06:36:06 |
Chris Johns |
sb: Remove debug print left in by mistake.
5
@70e3e5e
10/27/17 06:34:00 |
Chris Johns |
sb: Set the to email address to build@….
- Fix a minor bug in …
5
@0f97375
10/27/17 06:25:45 |
Chris Johns |
sb: Provide a more detail email message.
Close #3210.
5
@910196d
10/27/17 06:24:50 |
Chris Johns |
sb: Add a call to get the post processed report output.
Update #3210.
5
@723b638
10/27/17 06:23:25 |
Chris Johns |
sb: Add a log capture interface to capture the console output.
5
@9b54dd8
10/27/17 06:22:12 |
Chris Johns |
sb: Add a defined check.
Updates #3210.
5
@34d7e0c
10/23/17 04:32:12 |
Chris Johns |
darwin: Allow xz to live anywhere.
5
@4021c28
10/14/17 14:18:44 |
Chris Johns |
sb: Fix the interface to all path function to be shell paths.
- Add …
5
@7c0c0ba
10/12/17 03:06:43 |
Chris Johns |
sb: Fix the log after breaking adding --without-log
5
@f79eaf36
10/12/17 02:45:54 |
Chris Johns |
sb: Remove MD5 and SHA1 as they not secure.
Updates #2536.
5
@7b68249
10/12/17 02:42:40 |
Chris Johns |
sb: Add --source-only-download to make download source simple.
This …
5
@6dc551c
10/12/17 02:40:12 |
Chris Johns |
sb: Move the option check for reporting errors to the error reporter.
5
@c4b6bf0
10/11/17 12:07:23 |
Joel Sherrill |
Enable 64-bit BFD support. Needed on 32bit hosts
Closes #3157.
5
@55f2d69
09/22/17 01:54:06 |
Chris Johns |
sb: Allow checking if '.' exists as a path.
5
@1519d11
09/22/17 01:55:10 |
Chris Johns |
sb: Ignore untracked files or detached HEAD in the dirty repo check.
5
@630e658c
08/22/17 05:23:23 |
Sebastian Huber |
4.12: Update to GCC 7.2
5
@71c76d0
08/08/17 10:25:23 |
Chris Johns |
gcc: Disable makeinfo cause newer versions do not build gcc-4.8 docs.
5
@4578e0a
08/08/17 10:16:03 |
Chris Johns |
sb: Fix long path support in copy_tree and removeall path support.
5
@8b96e17
08/06/17 23:59:49 |
Chris Johns |
doc: Remove in source documentation and the asciidoc package
The RSB …
5
@4f3b8da
07/10/17 01:44:32 |
Chris Johns |
sb/download: Fix --rsb-file options with released sources.
The …
5
@d413d7e
07/01/17 16:01:20 |
andreas.koelbl |
Fix GDB build on ArchLinux?
Archlinux provides both, libguile v2.0 and …
5
@e02139d
06/25/17 23:27:55 |
Chris Johns |
sb: Fix 'bare' builds with --trace.
5
@cb3fac1
06/14/17 08:09:48 |
Sebastian Huber |
sb: Make error messages unique
Enable traceability from the error …
5
@0a0d1c8
06/08/17 05:21:07 |
Sebastian Huber |
sb: Restrict file name length
5
@2c13f00
06/08/17 05:07:27 |
Sebastian Huber |
Reduce file name length to make Windows happy
5
@94083b0
06/06/17 04:46:43 |
Sebastian Huber |
Add GCC 7 base configuration
5
@7c121ca
06/02/17 12:07:45 |
Sebastian Huber |
Fix for GCC 4.9 while building with GCC 6+
See also:
5
@e1257d4
06/02/17 12:38:13 |
Sebastian Huber |
sb: Create hopefully more valid file names
5
@f99c37e
05/10/17 00:41:19 |
Chris Johns |
bootstrap: Do not create a log file by default.
5
@1ad33b0
03/31/17 07:55:08 |
Sebastian Huber |
Always use GCC provided zlib
Always use the GCC provided zlib to make …
5
@902119e
03/21/17 03:08:45 |
Chris Johns |
freebsd: Update makeinfo and install-info paths on FreeBSD 11.0
Close …
5
@78e7f6a
03/26/17 02:19:18 |
Chris Johns |
sb: Add the release_path key to the version section in the VERSION …
5
@4f72b95
03/01/17 07:18:07 |
Sebastian Huber |
sb: Bail out only if hash definitions conflict
5
@b43c7d7
01/09/17 18:43:29 |
ralf.ramsauer |
Add distro aliases for Gentoo hosts
Gentoo stores most of the basic …
5
@534332f
09/12/16 02:31:33 |
Chris Johns |
binutils,gcc: Add support to control LTO and Gold.
5
@6843e47
04/12/16 23:13:55 |
Chris Johns |
gdb: Build with system readline and use MinGW compilers.
Select MinGW …
4.104.95
@f5e724f
04/15/16 01:56:36 |
Chris Johns |
graphics: Add 3rd party graphics support back to the master branch.
4.104.95
@383f7e6
04/15/16 01:44:27 |
Chris Johns |
sb: Add --rsb-file options to %source and %patch to set a file name.
4.104.95
@c98555c
04/15/16 01:43:21 |
Chris Johns |
sb: Do not filter -f options from a BSP.
4.104.95
@29819a2
03/19/16 06:23:50 |
Chris Johns |
sb: fix the if logic to handle directives in if statements.
4.104.95
@721fbe0
03/18/16 03:30:27 |
Chris Johns |
sb: Fix vairable type in _if.
Updates #2655.
4.104.95
@eb25206
03/18/16 03:24:17 |
Chris Johns |
sb: Fix op parsing bug where the string was not created.
Updates #2655.
4.104.95
@d44b4d2
03/18/16 02:34:26 |
Chris Johns |
sb: Make the URL output truncate on long long URLs.
4.104.95
@8bde727
03/17/16 23:45:28 |
Chris Johns |
sb: Fix %if logical OP parsing.
Updates #2655.
4.104.95
@db8ec8c
03/17/16 07:27:47 |
Chris Johns |
bare: Update qemu package source hashes that are missing.
Add support …
4.104.95
@89a94d0
03/17/16 07:26:37 |
Chris Johns |
sb: Fix the sensible url printer on Python3.
Updates #2656.
4.104.95
@38ed59a
03/17/16 05:39:57 |
Chris Johns |
sb: Support --dry-run --with-download for 3rd party RTEMS BSP …
4.104.95
@1bbb766
03/17/16 05:47:31 |
Chris Johns |
sb: Change urlib to urllib2 on Python2 and add user agent support.
4.104.95
@ed86b4b
03/16/16 06:14:45 |
Chris Johns |
bare/devel/qemu: Fix the release URL logic and pkconfig python3 …
4.104.95
@52561d9
03/11/16 01:39:34 |
Chris Johns |
sb: Do not expand the package name in a bset file.
If the package …
4.104.95
@33308d1
03/14/16 23:55:23 |
Chris Johns |
sb: Make cvs optional.
Ignore RSB generated files to keep the git …
4.104.95
@8d0e377
03/14/16 06:42:51 |
Chris Johns |
sb: Fix the --without-error-report parsing of the label.
Update #2526.
4.104.95
@6e490ae
03/14/16 05:23:19 |
Chris Johns |
sb: Update download to check the config file for release URL control.
4.104.95
@e8f3519
03/14/16 04:19:29 |
Chris Johns |
sb: Fix build's --with-error-report handling.
This reflects changes …
4.104.95
@84238b9
03/10/16 05:48:38 |
Chris Johns |
sb: Fix --without-release-url logic.
Updates #2636.
4.104.95
@d3fa158
03/10/16 05:19:58 |
Chris Johns |
sb: Add a download option --with-release-url/--without-release-url.
4.104.95
@62f76d98
03/10/16 04:06:32 |
Chris Johns |
sb: Fix typo on the urlparse name in download.py
Updates #2619.
4.104.95
@d78a63f
03/10/16 04:00:29 |
Chris Johns |
sb: Download's urllib_parse should point to urlparse on Python2.
4.104.95
@29f23e0
03/10/16 03:52:25 |
Chris Johns |
sb: Fix configparser import on Python2 in version.py.
Updates #2619.
4.104.95
@334c22c
03/08/16 11:23:01 |
Chris Johns |
sb: Add support to GDB to select a specific Python.
Detect a suitable …
4.104.95
@9bae339
03/08/16 11:17:09 |
Chris Johns |
sb: Report platform import errors.
4.104.95
@e645642
03/07/16 00:59:51 |
Chris Johns |
qemu: Add a package name to create a tarball.
4.104.95
@3a972f6
03/07/16 00:56:02 |
Chris Johns |
sb: Update code base to support Python3 and Python2.
Fix Windows …
4.104.95
@b537e55
03/01/16 03:33:22 |
Chris Johns |
Clean up 4.9 build issues.
Add support so 4.9 builds on a recent …
4.104.95
@8dbb3a0
02/28/16 23:41:17 |
Chris Johns |
sb: Remove http query flags from the file name if present.
The query …
4.104.95
@23191a3
02/28/16 23:13:11 |
Chris Johns |
sb: bootstrap.py clearing of environ var 'ACLOCAL_PATH' on MSYS2 …
4.104.95
@056e601
02/25/16 03:29:00 |
Chris Johns |
Wrap the tar command in double quotes for Windows cmd.exe.
Windows …
4.104.95
@d897e93
02/24/16 03:18:42 |
Chris Johns |
Fix sb-bootrap to run on Windows using MSYS2.
Prepend 'sh' to the …
4.104.95
@7c0ded8
09/21/15 23:01:28 |
Chris Johns |
Fix pkgconfig for MSYS to allow QEMU to build.
4.104.95
@610ae57
02/22/16 06:37:37 |
Chris Johns |
Fix sb-build to reference the opts correctly.
4.104.95
@14b00ff
01/24/16 19:24:19 |
joel |
source-builder/config/qemu-1-1.cfg: Add --disable-smartcard-nss
4.104.95
@7a9ec6e
11/28/15 20:55:12 |
yangqiao0505 |
fix nanox patch url
4.104.95
@3dfedc9
11/28/15 20:55:11 |
yangqiao0505 |
fix t1lib patch url
4.104.95
@dc1cd68
12/14/15 05:09:27 |
Chris Johns |
Download source from RTEMS if a release.
Download source from …
4.104.95
@9c68438
12/11/15 07:28:26 |
Chris Johns |
A VERSION file may have no hashes.
4.104.95
@7dddcc2
12/11/15 05:22:00 |
Chris Johns |
VERSION is an INI format file.
VERSION is an INI format file with 2 …
4.104.95
@0661e90
12/11/15 05:21:44 |
Chris Johns |
Return after an error as a dry-run carries on.
4.104.95
@e8ed687
12/11/15 05:21:09 |
Chris Johns |
Generate an error if there is no hash when released.
4.104.95
@27a934e
12/11/15 03:21:29 |
Chris Johns |
Remove the warning when undefining an undefined macro.
4.104.95
@dfc4a4f
12/10/15 06:30:27 |
Chris Johns |
Make CVS optional. We should avoid using it.
4.104.95
@40e4222
12/10/15 05:54:40 |
Chris Johns |
Support released downloading of the RTEMS Tools and RTEMS Kernel.
Add …
4.104.95
@47d703fd
12/03/15 11:22:17 |
Chris Johns |
sb. Add VERSION support for releasing the RSB.
Add support to release …
4.104.95
@7164e61
11/06/15 15:18:20 |
Sebastian Huber |
Add RTEMS 4.12 build set
4.104.95
@824f57c
10/26/15 04:38:39 |
Chris Johns |
sb: Only use /usr/local/bin/unzip on FreeBSD.
The base package …
4.104.95
@3a3069e
08/09/15 09:43:43 |
ragunath3252 |
lwIP configuration & build files
Patch to build lwip with RTEMS …
4.104.95
@01f8d0c
08/10/15 12:48:27 |
yangqiao0505 |
fix libjpeg conf
4.104.95
@68e81c7
08/10/15 12:48:26 |
yangqiao0505 |
add nxlib bset
4.104.95
@a7d2db0
08/10/15 12:48:25 |
yangqiao0505 |
add nanoX bset
4.104.95
@457c7ec
08/10/15 12:48:24 |
yangqiao0505 |
add t1lib bset (patch url should be changed after it is merged into …
4.104.95
@d9ee8ae
08/10/15 12:48:23 |
yangqiao0505 |
add freetype2 bset
4.104.95
@d2ee14c
08/10/15 12:48:22 |
yangqiao0505 |
add tiff-4.0.2 bset
4.104.95
@0b80ff5
08/10/15 12:48:21 |
yangqiao0505 |
add libpng bset
4.104.95
@f936478
07/20/15 04:09:24 |
Chris Johns |
rtems/netsnmp: Disable SMP builds.
NetSNMP breaks building with extra …
4.104.95
