@02279d6
11/12/15 12:01:12 |
Sebastian Huber |
USB: Update to FreeBSD trunk 2015-11-10
55-freebsd-126-freebsd-12freebsd-9.3
@c164446
11/10/15 09:19:04 |
Sebastian Huber |
Rename kernel space log() to _bsd_log()
This avoids a conflict with …
@b168f69
09/29/15 09:00:58 |
Sebastian Huber |
BUS_SPACE(9): Use FreeBSD files for i386 arch
@45eb88b
07/31/15 11:55:44 |
Sebastian Huber |
nexus-devices: Add pc386 nexus device and drivers
@07ff2c1
07/24/15 08:42:35 |
Sebastian Huber |
rtems-bsd-mutex: Update due to API changes
@3cb5e9e
07/23/15 13:38:50 |
Sebastian Huber |
Update due to header guard changes
4.1155-freebsd-126-freebsd-12freebsd-9.3
@b22ad9f
06/23/15 06:58:58 |
Sebastian Huber |
rtems-bsd-mutex: Fix resource count updates
@59bc7c1
06/19/15 06:07:32 |
Chris Johns |
Remove #undefs and fix formatting.
@cff7846
06/16/15 03:17:56 |
Chris Johns |
Add the TCPDUMP command.
@b5aca58
06/16/15 03:16:37 |
Chris Johns |
Add error() to the BSD program support.
@8440506
06/15/15 07:42:23 |
Chris Johns |
Add tcpdump and libpcap.
- Update the file builder generator to …
@0768880
05/21/15 07:01:34 |
Chris Johns |
waf: Add install support.
Install to the --prefix path passed to …
@b45c75c
05/20/15 08:13:16 |
Sebastian Huber |
sys/time.h: Add missing define and declaration
@8eaa39f
05/15/15 12:29:57 |
Sebastian Huber |
Update due to API changes (timecounters)
@b3ff71e
04/30/15 08:41:34 |
Sebastian Huber |
rtems-bsd-mutex: Use standard thread queues
@165dd8e
04/08/15 13:37:49 |
Sebastian Huber |
Update to FreeBSD Stable/9 2015-04-08
@c0b0b3e
04/23/15 12:55:42 |
Sebastian Huber |
@f6894a8
04/01/15 07:44:31 |
Sebastian Huber |
The <sys/_stdint.h> is now available in Newlib
@aee6864
03/26/15 14:39:18 |
Sebastian Huber |
if_dwc: Add Altera Cyclone V support
@710d2a1
03/27/15 10:13:25 |
Sebastian Huber |
mii: Add phy devices
@49b9c5e
03/30/15 21:01:09 |
Sebastian Huber |
LAGG(4): Enable and test
@012c263
03/30/15 19:28:26 |
Sebastian Huber |
VLAN(4): Enable and test
@fc9e83b
03/16/15 21:10:36 |
Sebastian Huber |
mmc: Import MMC/SDCard support from libusb
@024e064
03/17/15 07:55:47 |
Sebastian Huber |
nexus-devices: Fix for QorIQ T variants
@9bfcb86
03/24/15 08:42:28 |
Sebastian Huber |
rtems-bsd-mutex: Support priority changes
@8475e7a
03/24/15 09:02:45 |
Sebastian Huber |
SLEEPQUEUE(9): Port to RTEMS
@53b03a1
03/24/15 09:09:43 |
Sebastian Huber |
SLEEP(9): Port to RTEMS
@20b7d3d
03/15/15 09:01:25 |
Sebastian Huber |
Update due to Newlib <sys/time.h> etc. changes
@e5724f7
03/09/15 13:20:20 |
Sebastian Huber |
atomic.h: Fix for GCC version 5 and later
@8ed1b18
02/17/15 19:49:10 |
Sebastian Huber |
rtems_bsd_mutex: SMP support via ISR locks
@e5a0175
02/13/15 15:30:47 |
Sebastian Huber |
atomic.h: Use <stdatomic.h> or <atomic> for SMP
@9a50734
02/13/15 15:45:12 |
Sebastian Huber |
atomic.h: Format changes
@e684326
02/13/15 11:49:57 |
Sebastian Huber |
Change license to BSD
@dd9e4ef
02/13/15 11:47:21 |
Sebastian Huber |
Mark header files as empty
@be2e60c
02/13/15 10:51:35 |
Sebastian Huber |
Delete unused files
@5c0aa97
02/12/15 12:34:09 |
Sebastian Huber |
Add zerocopy sendto
@7eeb079
02/02/15 13:27:13 |
Sebastian Huber |
Update to FreeBSD 9.3
@8fe59fe
11/18/13 11:46:27 |
Sebastian Huber |
if_tsec: Add Nexus support
@5383ed4
02/13/15 09:31:27 |
Sebastian Huber |
Add and use rtems_bsd_get_allocator_domain_size()
@3c302b6
01/27/15 07:26:53 |
Sebastian Huber |
Add a simple page allocator
@5071600
01/20/15 10:04:39 |
Sebastian Huber |
Add Xilinx Zynq BSP support
@8cdd142
01/21/15 13:24:38 |
Sebastian Huber |
Add rtems_bsd_get_mac_address()
@33a15c3
01/20/15 07:57:36 |
Sebastian Huber |
Add and use rtems_bsd_get_task_stack_size()
@91ea7ea
01/20/15 07:39:06 |
Sebastian Huber |
Add and use rtems_bsd_get_task_priority()
@026abfb
11/10/14 07:27:32 |
Sebastian Huber |
Add rtems_mdns_gethostname()
@0bed8d9
11/06/14 07:59:37 |
Sebastian Huber |
Fix spelling
@7a3fe8e
11/06/14 07:28:06 |
Sebastian Huber |
Add rtems_mdns_sethostname()
Use it to set the multi-cast hostname of …
@50e82a6
11/05/14 13:27:18 |
Sebastian Huber |
HOSTNAME(1): Import from FreeBSD
@7ba9b7f
11/03/14 14:53:46 |
Sebastian Huber |
Add mDNS support for name service dispatcher
@ffbee8a
11/03/14 08:18:14 |
Sebastian Huber |
Add rtems_bsd_force_select_timeout()
@a736dda
10/31/14 09:37:34 |
Sebastian Huber |
nexus-devices: Only register fec0
This makes testing of IPv4LL a bit …
@573b4cd6
10/08/14 06:04:59 |
Sebastian Huber |
ppp: Port to new stack
@70fa95a
09/30/14 12:46:12 |
Sebastian Huber |
ppp: Import from RTEMS sources
@6cfc98d
10/01/14 12:20:42 |
Sebastian Huber |
nexus: Use a linker set for the devices
@454d682
10/01/14 11:41:57 |
Sebastian Huber |
Delete obsolete _bsd_nexus_devices
@6604dc8
09/25/14 08:48:14 |
Sebastian Huber |
Delete rtems_bsd_thread_chain
Rely on RTEMS object registration for …
@ccbc70d
09/24/14 14:28:25 |
Sebastian Huber |
BSD_ASSERT(): Optimize
@8176af1
09/24/14 13:41:16 |
Sebastian Huber |
rtems_bsd_mutex: Optimize
@be43b79
09/22/14 11:42:26 |
Sebastian Huber |
Replace RTEMS objects with custom implementation
Performance analysis …
@9a937f4
09/22/14 13:06:55 |
Sebastian Huber |
Disable IPsec
IPsec has a significant performance impact. Disable it …
@dce8247
09/22/14 14:24:34 |
Sebastian Huber |
Import and use subr_lock.c
@a197a48
09/18/14 07:49:32 |
Sebastian Huber |
telnetd: Import from RTEMS sources
@917a78b
12/12/13 08:11:00 |
Sebastian Huber |
DHCPCD(8): Add basic support
@7831313
01/20/14 14:27:13 |
Sebastian Huber |
Add and use RTEMS_BSD_ARGC()
@f8c3d6e
01/20/14 14:01:35 |
Sebastian Huber |
Add an ARP packet processor
@c50f1b4
01/20/14 12:09:13 |
Sebastian Huber |
Add rtems_bsd_get_ethernet_addr()
@c1bdbab
01/20/14 12:08:28 |
Sebastian Huber |
Add <rtems/bsd/util.h>
@164c5f5
01/15/14 11:46:22 |
Sebastian Huber |
UNIX(4): Import from FreeBSD
@e51bc97
12/20/13 12:26:03 |
Sebastian Huber |
Delete rtems_bsd_initialize_with_interrupt_server
Move interrupt …
@8d4bab3
12/20/13 09:17:32 |
Sebastian Huber |
Use integer-only printf in kernel space
@5315d35
12/20/13 09:14:26 |
Sebastian Huber |
Always enable IPv6
@e10d1cd
12/13/13 09:57:03 |
Sebastian Huber |
BPF(4): Add support
@1fea8c4
12/12/13 15:52:24 |
Sebastian Huber |
Add support for boottimebin and getbinuptime()
@e48f6038
12/12/13 09:38:22 |
Sebastian Huber |
Move FreeBSD define to header files
@90916f1
12/11/13 15:40:41 |
Sebastian Huber |
Move <sys/_cpuset.h>
@410e305
12/06/13 08:57:59 |
Sebastian Huber |
Add RTEMS legacy MII support
@d73edee
12/04/13 14:37:27 |
Sebastian Huber |
Add support for M68K
@57bfdf7
11/14/13 12:48:43 |
Sebastian Huber |
ftpd01: New test
@2815cdb
12/02/13 14:36:31 |
Sebastian Huber |
Changes due to <sys/cpuset.h> from latest Newlib
@24947b7
11/18/13 11:45:47 |
Sebastian Huber |
Delete unused file
@e2ab984
11/15/13 14:21:45 |
Sebastian Huber |
machine/bus.h: Support for PowerPC
@162d615
11/15/13 14:15:36 |
Sebastian Huber |
rtems-bsd-endian.h: Fix warning on PowerPC
@70bb42b
11/13/13 09:24:18 |
Sebastian Huber |
if_tsec: Add from FreeBSD
@369e2c4
11/13/13 11:51:17 |
Sebastian Huber |
nexus: Add table based Nexus device initialization
@66659ff
11/06/13 15:20:21 |
Sebastian Huber |
Update to FreeBSD 9.2
@ce96623
11/06/13 15:14:38 |
Sebastian Huber |
Define GLOBL1() and GLOBL()
@ef0c275
11/06/13 15:13:07 |
Sebastian Huber |
Move option defines to corresponding header files
@0a57e1d
11/06/13 08:35:05 |
Sebastian Huber |
Reduce divergence from FreeBSD sources
@c4c34f3
11/06/13 08:59:23 |
Sebastian Huber |
Make usable in user space.
@b84c04e
11/06/13 08:11:47 |
Sebastian Huber |
Move content to <machine/rtems-bsd-user-space.h>
@d48955b
11/06/13 08:02:16 |
Sebastian Huber |
Add and use <machine/rtems-bsd-user-space.h>
@f244de9
11/06/13 07:56:38 |
Sebastian Huber |
Rename rtems-bsd-config.h
Rename rtems-bsd-config.h in …
@af5333e
11/04/13 10:33:00 |
Sebastian Huber |
Update to FreeBSD 8.4
@6779ce5
11/04/13 10:55:19 |
Sebastian Huber |
BUS_SPACE(9): Use simple memory model for ARM
@241fc32
11/04/13 08:12:59 |
Sebastian Huber |
Use a local MSIZE of 256
@89761ed
10/29/13 14:22:58 |
Sebastian Huber |
Do not use FreeBSD time control
@0c9f27b
10/28/13 14:40:53 |
Sebastian Huber |
Use kqueue() and kevent() from FreeBSD
@08264c8
10/28/13 08:54:33 |
Sebastian Huber |
Use poll() from FreeBSD
@3e29388
10/25/13 13:09:17 |
Sebastian Huber |
ZONE(9): Add and use red-black tree chunk alloc
@2208c40
10/24/13 09:50:40 |
Sebastian Huber |
Remove includes in <machine/rtems-bsd-config.h>
