1 | | = Syntax Coloring of Source Code = |
2 | | Trac supports language-specific syntax highlighting of source code within wiki formatted text in [WikiProcessors#CodeHighlightingSupport wiki processors] blocks and in the [TracBrowser repository browser]. |
3 | | |
4 | | To do this, Trac uses external libraries with support for a great number of programming languages. |
5 | | |
6 | | Currently Trac supports syntax coloring using one or more of the following packages: |
7 | | |
8 | | * [http://pygments.pocoo.org/ Pygments], by far the preferred system, as it covers a wide range of programming languages and other structured texts and is actively supported |
9 | | * [http://www.codento.com/people/mtr/genscript/ GNU Enscript], commonly available on Unix but somewhat unsupported on Windows //(use is deprecated)// |
10 | | * [http://silvercity.sourceforge.net/ SilverCity], legacy system, some versions can be problematic //(use is deprecated)// |
| 1 | = Syntax Coloring of Source Code |
| 2 | Trac supports language-specific syntax highlighting of source code within wiki formatted text in [WikiProcessors#CodeHighlightingSupport wiki processors] blocks and in the [TracBrowser repository browser]. Syntax coloring is provided using [http://pygments.org/ Pygments], which covers a wide range of programming languages and other structured texts, and is actively supported. If Pygments is not available, Trac will display the content as plain text. |
28 | | === Known MIME Types |
| 21 | If a mimetype property such as `svn:mime-type` is set to `text/plain`, there is no coloring even if file is known type like `java`. |
| 22 | |
| 23 | === Direct Rendering |
| 24 | |
| 25 | Rich content may be directly //rendered// instead of syntax highlighted. This usually depends on which auxiliary packages are installed and on which components are activated in your setup. For example a `text/x-rst` document will be rendered via `docutils` if it is installed and the `trac.mimeview.rst.ReStructuredTextRenderer` is not disabled, and will be syntax highlighted otherwise. |
| 26 | |
| 27 | Similarly, a document with the mimetype `text/x-trac-wiki` is rendered using the Trac wiki formatter, unless the `trac.mimeview.api.WikiTextRenderer` component is disabled. |
| 28 | |
| 29 | HTML documents are directly rendered only if the `render_unsafe_html` settings are enabled in your TracIni file. Those settings are present in multiple sections, as there are different security concerns depending where the document comes from. If you want to ensure that an HTML document gets syntax highlighted and not rendered, use the `text/xml` mimetype. |
| 30 | |
| 31 | === Known MIME types |
32 | | Note that the rich content may be directly //rendered// instead of syntax highlighted. This usually depends on which auxiliary packages are installed and on which components are activated in your setup. For example a `text/x-rst` document will be rendered via `docutils` if it is installed and the `trac.mimeview.rst.ReStructuredTextRenderer` is not disabled, and will be syntax highlighted otherwise. |
33 | | |
34 | | In a similar way, a document with the mimetype `text/x-trac-wiki` is rendered using the Trac wiki formatter, unless the `trac.mimeview.api.WikiTextRenderer` component is disabled. |
35 | | |
36 | | HTML documents are directly rendered only if the `render_unsafe_html` settings are enabled in the TracIni (those settings are present in multiple sections, as there are different security concerns depending where the document comes from). If you want to ensure that an HTML document gets syntax highlighted and not rendered, use the `text/xml` mimetype. |
37 | | |
38 | | If a mimetype property such as 'svn:mime-type' is set to 'text/plain', there is no coloring even if file is known type like 'java'. |
39 | | |
40 | | === List of Languages Supported, by Highlighter #language-supported |
41 | | |
42 | | This list is only indicative. |
43 | | |
44 | | || ||= !SilverCity =||= Enscript =||= Pygments =|| |
45 | | || Ada || || ✓ || || |
46 | | || Asm || || ✓ || || |
47 | | || Apache Conf || || || ✓ || |
48 | | || ASP || ✓ || ✓ || || |
49 | | || C || ✓ || ✓ || ✓ || |
50 | | || C# || || ✓ ^[#a1 (1)]^ || ✓ || |
51 | | || C++ || ✓ || ✓ || ✓ || |
52 | | || CMake || ? || ? || ✓ || |
53 | | || Java || ✓ ^[#a2 (2)]^ || ✓ || ✓ || |
54 | | || Awk || || ✓ || || |
55 | | || Boo || || || ✓ || |
56 | | || CSS || ✓ || || ✓ || |
57 | | || Python Doctests || || || ✓ || |
58 | | || Diff || || ✓ || ✓ || |
59 | | || Eiffel || || ✓ || || |
60 | | || Elisp || || ✓ || || |
61 | | || Fortran || || ✓ ^[#a1 (1)]^ || ✓ || |
62 | | || Haskell || || ✓ || ✓ || |
63 | | || Genshi || || || ✓ || |
64 | | || HTML || ✓ || ✓ || ✓ || |
65 | | || IDL || || ✓ || || |
66 | | || INI || || || ✓ || |
67 | | || Javascript || ✓ || ✓ || ✓ || |
68 | | || Lua || || || ✓ || |
69 | | || m4 || || ✓ || || |
70 | | || Makefile || || ✓ || ✓ || |
71 | | || Mako || || || ✓ || |
72 | | || Matlab ^[#a3 (3)]^ || || ✓ || ✓ || |
73 | | || Mygthy || || || ✓ || |
74 | | || Objective-C || || ✓ || ✓ || |
75 | | || OCaml || || || ✓ || |
76 | | || Pascal || || ✓ || ✓ || |
77 | | || Perl || ✓ || ✓ || ✓ || |
78 | | || PHP || ✓ || || ✓ || |
79 | | || PSP || ✓ || || || |
80 | | || Pyrex || || ✓ || || |
81 | | || Python || ✓ || ✓ || ✓ || |
82 | | || Ruby || ✓ || ✓ ^[#a1 (1)]^ || ✓ || |
83 | | || Scheme || || ✓ || ✓ || |
84 | | || Shell || || ✓ || ✓ || |
85 | | || Smarty || || || ✓ || |
86 | | || SQL || ✓ || ✓ || ✓ || |
87 | | || Troff || || ✓ || ✓ || |
88 | | || TCL || || ✓ || || |
89 | | || Tex || || ✓ || ✓ || |
90 | | || Verilog || ✓ ^[#a2 (2)]^ || ✓ || || |
91 | | || VHDL || || ✓ || || |
92 | | || Visual Basic || || ✓ || ✓ || |
93 | | || VRML || || ✓ || || |
94 | | || XML || ✓ || || ✓ || |
95 | | |
96 | | |
97 | | |
98 | | ''[=#a1 (1)] Not included in the Enscript distribution. Additional highlighting rules can be obtained for |
99 | | [http://neugierig.org/software/ruby/ Ruby], |
100 | | [http://wiki.hasno.info/index.php/Csharp.st C#], |
101 | | [http://wiki.hasno.info/index.php/F90.st Fortran 90x/2003] |
102 | | |
103 | | ''[=#a2 (2)] since Silvercity 0.9.7 released on 2006-11-23 |
104 | | |
105 | | ''[=#a3 (3)] By default `.m` files are considered Objective-C files. In order to treat `.m` files as MATLAB files, add "text/matlab:m" to the "mime_map" setting in the [wiki:TracIni#mimeviewer-section "[mimeviewer] section of trac.ini"]. |
106 | | |
107 | | == Extra Software == |
108 | | * GNU Enscript — http://directory.fsf.org/GNU/enscript.html |
109 | | * GNU Enscript for Windows — http://gnuwin32.sourceforge.net/packages/enscript.htm |
110 | | * !SilverCity — http://silvercity.sf.net/ |
111 | | * **Pygments — http://pygments.org/** |
112 | | |
