Changes between Initial Version and Version 1 of TracBatchModify
Ignore:
Timestamp:
11/05/14 17:03:51 (9 years ago)
Author:
trac
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TracBatchModify
    v1 v1
     1= Trac Ticket Batch Modification =
     2[[TracGuideToc]]
     3
     4From [TracQuery custom query] results Trac provides support for modifying a batch of tickets in one request.
     5
     6To perform a batch modification select the tickets you wish to modify and set the new field values using the section underneath the query results.
     7
     8== List fields
     9
     10The `Keywords` and `Cc` fields are treated as lists, where list items can be added and/or removed in addition of replacing the entire list value. All list field controls accept multiple items (i.e. multiple keywords or cc addresses).
     11
     12== Excluded fields
     13
     14Multi-line text fields are not supported, because no valid use-case has been presented for syncing them across several tickets. That restriction applies to the `Description` field as well as to any [TracTicketsCustomFields#AvailableFieldTypesandOptions custom field] of type 'textarea'. However in conjunction with more suitable actions like 'prepend', 'append' or search & replace ([http://trac-hacks.org/ticket/2415 th:#2415]) this could change in future Trac versions.
