Changes between Version 4 and Version 5 of TBR/UserManual/Using_the_RTEMS_DOS_File_System
Ignore:
Timestamp:
Sep 12, 2008, 12:19:10 PM (11 years ago)
Author:
ChrisJohns
Comment:
/* ATA Disk */
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserManual/Using_the_RTEMS_DOS_File_System
    v4 v5
    6161Note, the examples given the ATA driver is a higher priority than the cache swap out task. This will make the ATA more responsive to the low levels. It does not have to be configured this way.
    6262
    63 Some where in the initialization phase of your application you need to read the IDE disk partition table. The code is:
     63Some where in the initialization phase of your application you need to read the IDE disk partition table. You need to provide the path to the IDE block driver. The code is:
    6464
    6565 extern rtems_status_code rtems_ide_part_table_initialize (const char* );
    7171  */
    7272 printf ("Read IDE Disk Partition Table: ");
    73  sc = rtems_ide_part_table_initialize (path);
     73 sc = rtems_ide_part_table_initialize ("/dev/ide0");
    7474 if (sc != RTEMS_SUCCESSFUL)
    7575 {
