Changes between Version 90 and Version 91 of TBR/UserManual/RTEMS_Coverage_Analysis
Ignore:
Timestamp:
Jul 19, 2010, 8:35:44 AM (11 years ago)
Author:
Bharath
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserManual/RTEMS_Coverage_Analysis
    v90 v91
    168168With the instruction level coverage of core of RTEMS (e.g. score, rtems, posix, and sapi directories) near 100%, we have expanded our attention to to include other non-networking portions of the cpukit.  The following areas have been identified as good candidates for writing tests which improve the current coverage.
    169169
    170  *  FIFO/Pipe
    171170 *  Untar
    172  *  error/panic reporting
    173  *  User database/password related routines
     171 *  termios
    174172
    175173If you are interested in writing some simple parameter check error cases, then take a look at the branch taken/not taken coverage reports for the "core configuration". Some of these are a simple matter of adding missing test cases for bad parameter path.  Other cases are more difficult.  So if you run into trouble with the analysis, ask or skip it. A common pattern is this:
