Changes between Version 54 and Version 55 of TBR/UserManual/RTEMS_Coverage_Analysis
- Timestamp:
- 09/17/09 22:24:22 (15 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v54 v55 88 88 89 89 90 As mentioned above, the ''covmerge'' script produces reports that contain several metrics used to measure progress. The first is the number of uncovered object code ranges. The second is the percent of untested object code as a percentage of the total object code size under analysis. Together the metrics provide useful information about the status or progress of the Object Code Coverage.90 As mentioned above, the ''covmerge'' script produces reports that contain several metrics that can be used to measure progress. The first is the number of uncovered object code ranges. The second is the percent of untested object code as a percentage of the total object code size under analysis. Together the metrics provide useful information about the status or progress of the Object Code Coverage. 91 91 = Coverage Profiles = 92 92
