Changes between Version 44 and Version 45 of TBR/UserManual/RTEMS_Coverage_Analysis
Ignore:
Timestamp:
Sep 17, 2009, 12:01:26 AM (10 years ago)
Author:
GlennHumphrey
Comment:
/* What was Discovered */ Added a code fragment example
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserManual/RTEMS_Coverage_Analysis
    v44 v45
    5656
    5757
    58 When we began the RTEMS Code Coverage effort, we performed coverage analysis on the development head of RTEMS 4.8 using the POSIX Enabled Profile.  Some of our initial observations were interesting.  First, we were a little surprised at the incompleteness of the test suite.  We knew that there were some areas of the RTEMS code that were not tested at all, but we also found that areas we thought were tested were only partially tested.  We also observed some interesting things about the code we were analyzing.  We noticed that the use of inlining sometimes caused significant branch explosion.  This generated a lot of uncovered ranges that really mapped back to the same source code.  We also found that coding habits and coding style generated a lot of unreachable object code.  Also, the use of a case statement instead of an if statement sometimes lead to unreachable code.
    59
    60 Some of our observations were related to the performance of the ''covmerge'' tool.  Of particular interest was the handling of NOP instructions.  Compilers can use NOP instructions to force alignment between functions or to fill delay-slots required by the processor.  Of course the NOP instructions are not executed and thus had a negative impact on the coverage.  The first attempt at dealing with NOP instructions was to mark them all as EXECUTED.  This was correct for the NOPs used for function alignment, but not for NOPs used for delay-slots.  Marking delay-slot NOPs as EXECUTED produced an unwanted side effect of occasionally spliting an uncovered range into two ranges.  We finally settled on an improved method for dealing with NOPs where NOPs were marked as EXECUTED unless they were between two un-EXECUTED instructions.
    61
    62 SHOW SAMPLE CODE
    63
    64 Creates more uncovered case to examine.
     58When we began the RTEMS Code Coverage effort, we performed coverage analysis on the development head of RTEMS 4.8 using the POSIX Enabled Profile.  Some of our initial observations were interesting.  First, we were a little surprised at the incompleteness of the test suite.  We knew that there were some areas of the RTEMS code that were not tested at all, but we also found that areas we thought were tested were only partially tested.  We also observed some interesting things about the code we were analyzing.  We noticed that the use of inlining sometimes caused significant branch explosion.  This generated a lot of uncovered ranges that really mapped back to the same source code.  We also found that some defensive coding habits and coding style idioms could generate unreachable object code.  Also, the use of a case statement that includes all values of an enumerated type instead of an if statement sometimes lead to unreachable code.
     59
     60Other observations were related to the performance of the ''covmerge'' tool.  Of particular interest was the handling of NOP instructions.  Compilers can use NOP instructions to force alignment between functions or to fill delay-slots required by the processor.  Of course the NOP instructions are not executed and thus had a negative impact on the coverage.  The first attempt at dealing with NOP instructions was to mark them all as EXECUTED.  This was correct for the NOPs used for function alignment, but not for NOPs used for delay-slots.  Marking delay-slot NOPs as EXECUTED produced an unwanted side effect of occasionally spliting an uncovered range into two ranges thus falsely increasing the number of uncovered ranges.  We finally settled on an improved method for dealing with NOPs where NOPs were marked as EXECUTED unless they were between two NOT EXECUTED instructions.  An example is shown below:
     61
     62{{{
     632003ee8:  80 a6 20 00   cmp  %i0, 0                            <== NOT EXECUTED
     642003eec:  02 80 00 06   be  2003f04 <IMFS_fifo_write+0x60>     <== NOT EXECUTED
     652003ef0:  01 00 00 00   nop                                    <== NOT EXECUTED
     662003ef4:  40 00 78 fb   call  20222e0 <__errno>                <== NOT EXECUTED
     672003ef8:  b0 20 00 18   neg  %i0                               <== NOT EXECUTED
     68}}}
     69
     70The NOP issue was important because it falsely increased the number of uncovered ranges.  This created an unnecessary explosion of the reports and increased the uncovered ranges to examine.
    6571= Resolving Uncovered Code =
    6672
    184190
    185191 *  pc386
    186 = =SPARC ==
     192= SPARC =
    187193
    188194
    192198 *  LEON2
    193199 *  LEON3
    194 =  =References==
    195
    196
    197 ===General Coverage Testing===
     200= References =
     201
     202=  ==General Coverage Testing===
    198203
    199204
