Changes between Version 90 and Version 91 of TBR/UserManual/RTEMSAda
Ignore:
Timestamp:
Nov 28, 2018, 9:27:54 AM (5 months ago)
Author:
Pritish Jain
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserManual/RTEMSAda
    v90 v91
    3737
    3838
    39 These instructions assume the following strings in the instructions are replaced with values appropriate for you.  These ''may'' not work if you use these as environment variables, do so at your own risk.
     39These instructions assume the following strings in the instructions are replaced with values appropriate for you.  These ''may'' not work if you use these as environment variables, so do this at your own risk.
    4040
    4141 *  INSTALL_DIR is the prefix (installation directory) for the toolchain installation
