Changes between Version 34 and Version 35 of TBR/UserManual/Quick_Start
Ignore:
Timestamp:
Dec 10, 2018, 2:05:12 PM (6 weeks ago)
Author:
Karox693
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserManual/Quick_Start
    v34 v35
    2121Note, the following is for RTEMS 4.11 and assumes you have a valid sparc-rtems4.11-toolchain in your PATH.
    2222
    23 WARNING: Replace 4.11 with the proper version. Also for 4.11 and older, use the erc32 BSP. For 5.1 and newer, use the erc32 BSP.
     23WARNING: Replace 4.11 with the proper version. Also, for 4.11 and older, use the erc32 BSP. For 5.1 and newer, use the erc32 BSP.
    2424
    2525{{{
    3535}}}
    3636
    37 WARNING: It is absolutely critical that the target name provided to the RTEMS configure command be that same as that used to build binutils, gcc, newlib, and gdb.  The binaries provided by the RTEMS Project will use a target name of the form `CPU-rtemsVERSION` where CPU is `sparc` in the above example and VERSION is 4.11.
     37WARNING: It is absolutely critical that the target name provided to the RTEMS configure command be the same as that used to build binutils, gcc, newlib, and gdb.  The binaries provided by the RTEMS Project will use a target name of the form `CPU-rtemsVERSION` where CPU is `sparc` in the above example and VERSION is 4.11.
    3838
    3939= Running =
    9191= Example Library Compiling =
    9292
    93 Below is a link to how to build libraries for use with more complex packages
     93There is a link provided below on how to build libraries for use with more complex packages
    9494
    9595http://www.rtems.org/wiki/index.php/RTEMS_Add-On_Packages
