Changes between Version 22 and Version 23 of TBR/UserManual/Quick_Start
Ignore:
Timestamp:
Jan 1, 2016, 5:37:45 AM (4 years ago)
Author:
Nick Withers
Comment:
Note that RTEMS autotools must be found before any locally installed tools when running ./bootstrap
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserManual/Quick_Start
    v22 v23
    88 * You may also like the GSoC/GettingStarted tutorial.
    99
    10  *  Installing the Tools. You can get the tools from [wiki:Developer/Tools/RSB  RTEMS Source Builder (RSB)]. Select the ''sparc'' CPU toolset since that is the sample BSP we will be building.  Don't worry, you can easily remove the tools later if you decide you don't want a simulator environment to play with.
    1111
    12  *  Download RTEMS.  Use either a release image or checkout from [wiki:Developer/Git Git].  Either way, make sure you get the right toolset for your RTEMS version. The RSB will help you here.
    1313
    14  *  If you chose Git, then make sure you installed the RTEMS autoconf and automake. Then run bootstrap script from the top level of the RTEMS source tree.  It may take a few minutes to complete.
     14 * If you chose Git, then make sure you installed the RTEMS autoconf and automake and that they are found before any installed local tools in your ''PATH'' environment variable. Then run the `bootstrap` script from the top level of the RTEMS source tree.  It may take a few minutes to complete.
    1515
    16  *  RTEMS is designed to be compiled outside the source tree.  Assuming you used the 4.11 head, you would need to do something like the following to configure and compile RTEMS.  Be sure to watch versions and install points:
    1717
    1818Note, the following is for RTEMS 4.11.
