Changes between Version 31 and Version 32 of TBR/UserManual/Quick_Start
Ignore:
Timestamp:
Oct 26, 2018, 8:40:36 AM (6 months ago)
Author:
Amaan Cheval
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserManual/Quick_Start
    v31 v32
    3737WARNING: It is absolutely critical that the target name provided to the RTEMS configure command be that same as that used to build binutils, gcc, newlib, and gdb.  The binaries provided by the RTEMS Project will use a target name of the form `CPU-rtemsVERSION` where CPU is `sparc` in the above example and VERSION is 4.11.
    3838
    39 When this completes, you should have a few sample test executables in the build tree.   This shows how to run the ticker.exe example in gdb:
     39= Running =
     40
     41When this completes, you should have a few sample test executables in the build tree.   This shows how to run the ticker.exe example in gdb (you can do the same for hello.exe or any of the other tests):
    4042
    4143{{{
