Changes between Version 81 and Version 82 of TBR/UserManual/MinGW_Tools_for_Windows
Ignore:
Timestamp:
May 29, 2015, 3:16:35 PM (4 years ago)
Author:
Gedare Bloom
Comment:
Fix ftp links.
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserManual/MinGW_Tools_for_Windows
    v81 v82
    3333The tools for all RTEMS releases can be found here:
    3434
    35  *http://www.rtems.org/ftp/pub/rtems/mingw32/
     35 *http://ftp.rtems.org/pub/rtems/mingw32/
    3636
    3737Under this directory you will find the version of tools that match the version of RTEMS you are working with. For RTEMS 4.10:
    3838
    39  *http://www.rtems.org/ftp/pub/rtems/mingw32/4.10/
     39 *http://ftp.rtems.org/pub/rtems/mingw32/4.10/
    4040
    4141and for RTEMS 4.11:
    4242
    43  *http://www.rtems.org/ftp/pub/rtems/people/chrisj/source-builder/4.11/mingw32/
    44  *http://www.rtems.org/ftp/pub/rtems/mingw32/4.11/
     43 *http://ftp.rtems.org/pub/rtems/people/chrisj/source-builder/4.11/mingw32/
     44 *http://ftp.rtems.org/pub/rtems/mingw32/4.11/
    4545
    4646These directories contain the binary executable files as well as the complete patched source code used to build the tools. You can identify the source code files as they end with "src.tar.bz2". You do not need to download the source files unless you wish to review it, change it or archive the source.
    5050There are specific files for each target. You need to download the files for the specific architecture are working with. To download the required files for the SPARC architecture you need to enter the follow directories and download all the tar.bz2 files that do not end in "src.tar.bz2" unless you wish to have the source as well:
    5151
    52  *http://www.rtems.org/ftp/pub/rtems/mingw32/4.11/rtems-4.11-sparc-rtems4.11-binutils/
    53  *http://www.rtems.org/ftp/pub/rtems/mingw32/4.11/rtems-4.11-sparc-rtems4.11-gcc/
    54  *http://www.rtems.org/ftp/pub/rtems/mingw32/4.11/rtems-4.11-sparc-rtems4.11-gdb/
     52 *http://ftp.rtems.org/pub/rtems/mingw32/4.11/rtems-4.11-sparc-rtems4.11-binutils/
     53 *http://ftp.rtems.org/pub/rtems/mingw32/4.11/rtems-4.11-sparc-rtems4.11-gcc/
     54 *http://ftp.rtems.org/pub/rtems/mingw32/4.11/rtems-4.11-sparc-rtems4.11-gdb/
    5555
    5656The exact file name changes as the tools are updated. For example the current binutils file is "rtems-4.11-sparc-rtems4.11-binutils-2.22-1.tar.bz2" where the binutils version is 2.22 and this is our 1st patch release. Download all the files to a single directory on your Windows machine. For example download to "C:\opt\rtems\packages" and opening a MSYS shell we would have:
    186186THIS NEEDS UPDATING. Someone please update ? Thanks Chris.
    187187
    188 We will use the [http://www.rtems.org/ftp/pub/rtems/4.10.2/rtems-4.10.2.tar.bz2 RTEMS 4.10.2] release here and assume that all tools from above are installed in their correct version (for this release use the RTEMS-4.10 tools). If you use a GIT version make sure that the Unix to DOS line endings conversion was switched off during the checkout and do not forget the bootstrap.
     188We will use the [http://ftp.rtems.org/pub/rtems/4.10.2/rtems-4.10.2.tar.bz2 RTEMS 4.10.2] release here and assume that all tools from above are installed in their correct version (for this release use the RTEMS-4.10 tools). If you use a GIT version make sure that the Unix to DOS line endings conversion was switched off during the checkout and do not forget the bootstrap.
    189189
    190190The build will be done in a Windows command shell (''cmd.exe'').  Execute the following commands within a Windows command shell to build for example the PSIM board support package (the '>' prompt indicates the Windows command shell):
