Changes between Version 76 and Version 77 of TBR/UserManual/MinGW_Tools_for_Windows
Ignore:
Timestamp:
Feb 24, 2012, 3:22:23 PM (8 years ago)
Author:
ChrisJohns
Comment:
/* Trouble Shooting */
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserManual/MinGW_Tools_for_Windows
    v76 v77
    150150
    151151If you experience, that the shell crashes sometimes, resulting in a stack dump, you might want to check whether you have a Logitech webcam (or similar) installed on your system.  Killing the process <tt>lvprcsrv.exe</tt> in the ''Windows Task Manager'' might help in these situations.
    152
    153 If you encounter an error like this
    154
    155  Couldn't reserve space for cygwin's heap, Win32 error 6
    156
    157 try to use a 1.0.11 version of the MSYS DLL and base files.
    158
    159 An outdated version of M4 causes a problem during the RTEMS Autotools installation.  You notices this if a window like this pops up:
    160 <center>[[Image(msys-m4.jpg)]]</center>
    161 Pressing any key will continue but the installation of the Autotools will not be correct.  You should exit the installer and install the required M4 program, see also [wiki:#MSYS_-_M4 MSYS - M4].
    162152= Compiling in Emacs =
    163153
