Changes between Version 54 and Version 55 of TBR/UserManual/MinGW_Tools_for_Windows
Ignore:
Timestamp:
Sep 26, 2008, 5:08:11 AM (12 years ago)
Author:
ChrisJohns
Comment:
Minor change to 4.9.
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserManual/MinGW_Tools_for_Windows
    v54 v55
    8989If you wish to modify RTEMS and/or need to run autoconf, automake or any of the autotools you will need to install the ''MinGW MSYS Developers Tool kit''.
    9090
    91 The RTEMS installer checks to see if the MSYS <tt>/etc/fstab</tt> is present and appends the install path the tools are built with as a mount to the install point you set in the installer. The <tt>/etc/fstab</tt> will have the following entry (rtems4.8) for the default install point:
     91The RTEMS installer checks to see if the MSYS <tt>/etc/fstab</tt> is present and appends the install path the tools are built with as a mount to the install point you set in the installer. The <tt>/etc/fstab</tt> will have the following entry (rtems4.9) for the default install point:
    9292
    93  C:/opt/rtems-4.8 /opt/rtems-4.8
     93 C:/opt/rtems-4.9 /opt/rtems-4.9
    9494
    9595The install tries hard to locate MSYS. If it does not find it please let us know.
