- Timestamp:
09/20/07 02:51:29 (17 years ago)
- Author:
ChrisJohns
- Comment:
Change to build-16.
Legend:
- Unmodified
- Added
- Removed
- Modified
v36
v37
10 | 10 | <blockquote> |
11 | 11 | <blockquote> |
12 | | [http://www.rtems.org/ftp/pub/rtems/windows/4.8/build-15/rtems4.8-tools-15.exe RTEMS Tool Installer (rtems4.8-tools-15.exe)] |
| 12 | [http://www.rtems.org/ftp/pub/rtems/windows/4.8/build-15/rtems4.8-tools-16.exe RTEMS Tool Installer (rtems4.8-tools-16.exe)] |
13 | 13 | </blockquote> |
14 | 14 | </blockquote> |
18 | 18 | For a detailed walk through of the installer take a look at [wiki:TBR/Delete/Installing_MinGW_RTEMS_Tools Installing MinGW RTEMS Tools]. |
19 | 19 | |
20 | | The source code for the tools is under the GNU GPL and can be found here http://www.rtems.org/ftp/pub/rtems/windows/4.8/build-15/source. The installers and tools are built and packaged on a Linux Fedora (FC7) computer and the scripts are all provided in the RTEMS source code using the [wiki:Building/MingwTools Building MinGW Tools] instructions. |
| 20 | The source code for the tools is under the GNU GPL and can be found here http://www.rtems.org/ftp/pub/rtems/windows/4.8/build-16/source. The installers and tools are built and packaged on a Linux Fedora (FC7) computer and the scripts are all provided in the RTEMS source code using the [wiki:Building/MingwTools Building MinGW Tools] instructions. |
21 | 21 | |
22 | 22 | The RTEMS are all installed into the default path of <tt>c:\opt\rtems-4.8</tt>. To test the tools run the <tt>rtems.bat</tt> file. This will open a Windows Command prompt (cmd) with a valid path to the installed tools. You can find the <tt>rtems.bat</tt> where you installed the tools or under the '''RTEMS 4.8''' menu in the '''Start Menu'''. Enter the GCC command for your tool set. For example the ARM GCC command is: |
