- Timestamp:
08/19/07 11:40:18 (17 years ago)
- Author:
ChrisJohns
- Comment:
/* Setting Up MinGW */
Legend:
- Unmodified
- Added
- Removed
- Modified
v32
v33
42 | 42 | |
43 | 43 | <blockquote> |
44 | | '''WARNING:''' ''If you uninstall the MinGW package it currently deletes everything under the install prefix. It is recommended you use the standard install point and do not place any files you need to keep under that directory.'' |
| 44 | '''WARNING:''' ''If you uninstall the MinGW package it currently deletes everything under the install directory. It is recommended you use the standard install point and do not place any files you need to keep under that directory.'' |
45 | 45 | </blockquote> |
46 | 46 | |
