Changes between Version 10 and Version 11 of TBR/UserManual/Floating_Point_Support
Ignore:
Timestamp:
Jul 12, 2009, 8:47:44 AM (11 years ago)
Author:
Kptrs
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserManual/Floating_Point_Support
    v10 v11
    150150 <strike>#endif</strike>
    151151
    152 This would result in the RTEMS compilation not generating any floating point usage internally (since {{{-msoft-float</code> (or equivalent) is still set), but because {{{CPU_HARDWARE_FP</code> will be set TRUE, the RTEMS kernel will be built containing the code needed to support floating point tasks in user applications. The user applications do not need to be built with {{{-msoft-float</code> (or equivalent).
     152This would result in the RTEMS compilation not generating any floating point usage internally (since {{{-msoft-float</code> (or equivalent) is still set), but because {{{CPU_HARDWARE_FP</code> will be set TRUE, the RTEMS kernel will be built containing the code needed to support floating point tasks in user applications. The user applications do not need to have {{{-msoft-float</code> (or equivalent) applied to code used in floating point tasks. Any code that is (or might be) used in non-floating-point tasks will still need to be compiled with {{{-msoft-float</code> (or equivalent). The linker step needs that option also (to bring in the needed software floating point library code, for the RTEMS kernel even if nothing else).
    153153
    154154 *  Get GCC to provide a specific named optimization option to enable/disable the storage of integer variables in FPU registers. Then instead of deleting all hardware floating point, we could allow it but only for actual floating point activities. Any GCC developers out there?
