137 | | But now, any BSP/cpukit that determines whether the CPU has hardware floating point by using a preprocessor definition automatically set by the compiler as a result of {{{-msoft-float</code> (or equivalent), as many of them currently do (RTEMS 4.8.1), will because of this completely disable the RTEMS library floating point support. So a user application that would like to use floating point will not be able to - RTEMS will not save the floating point context, etc. In fact, RTEMS will probably not enable the floating point unit, likely resulting in "exception conditions" as noted above. All user code in this condition must also be compiled and linked with {{{-msoft-float</code> (or equivalent). |
| 137 | But now, any cpukit/BSP that determines whether the CPU has hardware floating point by using a preprocessor definition automatically set by the compiler as a result of {{{-msoft-float</code> (or equivalent), as many of them currently do (RTEMS 4.8.1), will because of this completely disable the RTEMS library floating point support. So a user application that would like to use floating point will not be able to - RTEMS will not save the floating point context, etc. In fact, RTEMS will probably not enable the floating point unit, likely resulting in "exception conditions" as noted above. All user code in this condition must also be compiled and linked with {{{-msoft-float</code> (or equivalent). |
| 138 | = Escaping Disaster = |
| 139 | |
| 140 | |
| 141 | There are several options at this point: |
| 142 | |
| 143 | * Just live with it and do not use floating point. Many embedded systems can accept this. |
| 144 | * Do not base the setting of {{{CPU_HARDWARE_FP</code> ultimately on a compiler definition based on {{{-msoft-float</code> (or equivalent). For example, the {{{cpukit/score/cpu/sparc/rtems/score/sparc.h</code> code shown above could be changed to: |
| 145 | |
| 146 | <strike>#if defined(_SOFT_FLOAT) |
| 147 | #define SPARC_HAS_FPU 0 |
| 148 | #else</strike> |
| 149 | #define SPARC_HAS_FPU 1 |
| 150 | <strike>#endif</strike> |
| 151 | |
| 152 | This would result in the RTEMS compilation not generating any floating point usage internally (since {{{-msoft-float</code> (or equivalent) is still set), but because {{{CPU_HARDWARE_FP</code> will be set TRUE, the RTEMS kernel will be built containing the code needed to support floating point tasks in user applications. The user applications do not need to be built with {{{-msoft-float</code> (or equivalent). |
| 153 | |
| 154 | * Get GCC to provide a specific named optimization option to enable/disable the storage of integer variables in FPU registers. Then instead of deleting all hardware floating point, we could allow it but only for actual floating point activities. Any GCC developers out there? |
