Changes between Version 3 and Version 4 of TBR/UserManual/Example_Application_Compiling
Ignore:
Timestamp:
Jul 2, 2009, 10:41:06 PM (10 years ago)
Author:
JoelSherrill
Comment:
Add PATH hint as root
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserManual/Example_Application_Compiling
    v3 v4
    3838{{{
    3939# If the INSTALL_POINT requires root access, you will have to perform this step.
     40# NOTE: If the install as root fails due to not having RTEMS tools in your PATH,
     41#       you will have to "export PATH=/opt/rtems-4.10/bin:$PATH" as well.
    4042su -
    4143
