- Timestamp:
01/26/07 17:17:30 (17 years ago)
- Author:
Logiclabsrl
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v22
v23
16 | 16 | * Width: 19" |
17 | 17 | * Depth: 31 cm= Current inputs = |
18 | | |
19 | 18 | |
20 | 19 | * 24 isolated noise-free channels |
36 | 35 | * Resolution (ENOB): 16 bit noise-free |
37 | 36 | * signal-noise ratio: 92 dB |
38 | | * Cross-over: < -92 dB |
| 37 | * Cross-over: < -92 dB= Voltage inputs = |
39 | 38 | |
40 | | |
41 | | '''Voltage inputs''' |
42 | | |
43 | 39 | * 8 isolated noise-free channels |
44 | 40 | * Isolation on single channel at 3000V DC (1 min) |
58 | 54 | * Resolution (ENOB): 16 bit noise-free |
59 | 55 | * signal-noise ratio: 92 dB |
60 | | * Cross-over: <-86 dB |
61 | | |
62 | | |
63 | | '''Digital inputs''' |
| 56 | * Cross-over: <-86 dB= Digital inputs = |
64 | 57 | |
65 | 58 | * 128 isolated channels |
67 | 60 | * Input voltage (min): 18V |
68 | 61 | * Input voltage (max): 140V |
69 | | * Time resolution: 1 ms |
70 | | |
71 | | |
72 | | '''Communication''' |
| 62 | * Time resolution: 1 ms= Communication = |
73 | 63 | |
74 | 64 | * Ethernet 10/100 Mbit/s |
81 | 71 | Ethernet: 1500 Vrms |
82 | 72 | Serials: 2500 Vrms) |
83 | | * Connector for satellite antenna |
84 | | |
85 | | |
86 | | '''Signal relay''' |
| 73 | * Connector for satellite antenna= Signal relay = |
87 | 74 | |
88 | 75 | * Out of order |
89 | | * Recording in progress |
90 | | |
91 | | |
92 | | '''Elaboration''' |
| 76 | * Recording in progress= Elaboration = |
93 | 77 | |
94 | 78 | * 32 bit multiprocessor (4 ColdFire MCF5272processor) system |
96 | 80 | * 32 MByte Flash memory |
97 | 81 | * 128 Mbyte DRAM |
98 | | * RTC with GPS synchronization |
| 82 | * RTC with GPS synchronization = Fault Recording = |
99 | 83 | |
100 | | |
101 | | '''Fault Recording''' |
102 | | |
103 | 84 | * Recording in flash memory |
104 | 85 | * Recording maximum time: 250 s |
111 | 92 | * Analog Trigger on threshold (max, min, gradient) |
112 | 93 | * Trigger on digital transitions |
113 | | * GPS based time tag events (Precision: 1 µs - Resolution: 1 ms) |
114 | | |
115 | | |
116 | | '''Normative conformity''' |
| 94 | * GPS based time tag events (Precision: 1 µs - Resolution: 1 ms)= Normative conformity = |
117 | 95 | |
118 | 96 | * IEC 61000 – 4 – 2 (Level 3) |
140 | 118 | * CEI 70-1 IP30 (front) IP20 (case) |
141 | 119 | * COMTRADE standard IEEE Std C37.111-1991 |
| 120 | |
142 | 121 | = Firmware Architecture = |
143 | 122 | |
| 123 | ''In progress...'' |
144 | 124 | |
145 | | ''In progress...'' |
146 | | = Link = |
| 125 | = =Link== |
147 | 126 | |
148 | 127 | |
151 | 130 | [Italian: http://www.logiclab.it/DV947_file/BrochureOscilloperturbografo.pdf] |
152 | 131 | |
153 | | |
154 | 132 | Italian site: |
155 | 133 | [LogicLab: http://www.logiclab.it] |
156 | 134 | [PowerProbe: http://www.logiclab.it/it/DV947.htm] |
157 | 135 | |
158 | | |
159 | 136 | RTEMS related page: |
160 | 137 | [wiki:TBR/UserApp/LogicLab_S.r.l. LogicLab S.r.l.] |
