Changes between Version 1 and Version 2 of TBR/UserApp/Fault_Recorder
Ignore:
Timestamp:
Jan 26, 2007, 4:25:15 PM (13 years ago)
Author:
Logiclabsrl
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserApp/Fault_Recorder
    v1 v2
    22
    33
    4 '''Power supply'''
     4=  '''Power supply'''  =
     5
     6
    57Power Supply (Vaux):  110V DC ± 20% (more options available)
    68Power request:  40W
    810        Insensitive to 100% of Vaux for 50 ms (min)
    911        Insensitive to 50% of Vaux for 100ms (min)
    10 '''
    11 Dimensions'''
     12
     13=  '''Dimensions'''  =
     14
     15
    1216Height:  9HE
    1317Width:  19"
    1418Depth:  31 cm
    1519
    16 '''Current inputs'''
     20=  '''Current inputs'''  =
     21
     22
    172324 isolated noise-free channels
    1824Isolation on single channel at 3000V DC (1 min)
    3541Cross-over:  <  -92 dB
    3642
    37 '''Voltage inputs'''
     43=  '''Voltage inputs'''  =
     44
     45
    38468 isolated noise-free channels
    39 Isolation on single channel at 3000V D=  Headline text  =
    40
    41 C (1 min)
     47Isolation on single channel at 3000V DC (1 min)
    4248Sampling frequency:  7,2 KHz
    4349Bandwidth (-3 dB): DC (0 Hz) ÷ 3,5 KHz
    5662signal-noise ratio:  92 dB
    5763Cross-over:  <-86 dB
     64=  '''Digital inputs'''  =
    5865
    59 '''Digital inputs'''
     66
    6067128 isolated channels
    6168Isolation on single channel at 3000V DC (1 min)
    6471Time resolution:  1 ms
    6572
    66 '''Communication'''
     73=  '''Communication'''  =
     74
     75
    6776Ethernet 10/100 Mbit/ses
    6877Configurable as knot of a net LAN/WAN
    7483        (Ethernet: 1500 Vrms  Serials:  2500 Vrms)
    7584Connector for satellite antenna
     85=  '''Signal relay'''  =
    7686
    77 '''Signal relay'''
     87
    7888Out of order
    7989Recording in progress
    8090
    8191
    82 '''Elaboration'''
     92=  '''Elaboration'''  =
     93
     94
    839532 bit multiprocessor (4 ColdFire MCF5272processor) system
    8496Realtime operating system RTEMS
    8799RTC with GPS synchronization
    88100
    89 '''Fault Recording'''
     101=  '''Fault Recording'''  =
     102
     103
    90104Recording in flash memory
    91105Recording maximum time:  250 s
    102116  Resolution:  1 ms
    103117
    104 '''Normative conformity'''
     118=  '''Normative conformity'''  =
     119
     120
    105121IEC 61000 – 4 – 2 (Level 3)
    106122IEC 61000 – 4 – 3 (Level 3)
