Changes between Version 1 and Version 2 of TBR/UserApp/Automatic_Load_Shed
Ignore:
Timestamp:
Jan 19, 2009, 3:45:05 PM (11 years ago)
Author:
Logiclab
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TBR/UserApp/Automatic_Load_Shed
    v1 v2
    4646  * 0,02 Hz @ V<0,3Vn
    4747  * Frequency rate: ±0,002 Hz/s
    48 = Alarms (digital outputs)***
     48= Alarms (digital outputs) =
     49
    4950 * 15 Relays
    5051  * Out of order
    6869 * Maximum Switching Capacity (L/R=40ms): 0,5A @110V
    6970 * Endurance (mechanical): ?10e7
    70
    71  =Digital inputs===
     71= Digital inputs =
    7272
    7373 * 2 isolated inputs
    140140 * CEI 70-1 IP30 (front) IP20 (case)
    141141 * COMTRADE standard IEEE Std C37.111-1991
     142= Software technical data =
     143= Parameterization and device management software - SpyEAC =
     144
     145 * Communication interface selection (RS232, UDP, TCP, modem setup)
     146 * Software access configuration and folder management
     147 * Voltage input full scales setup
     148 * Device, Substation, voltage input labelling
     149 * Full TCP/IP Ethernet configuration parameters
     150 * Backside RS232 throughput configuration
     151 * Operating mode selection (M1/M2)
     152 * Trip and stop protection threshold setup
     153 * Output current setup
     154 * Digital input, relay output, protection status
     155 * Recording time setup (Pre-trigger time, fault time, post-fault time)
     156 * Memory configuration setup (circular buffer or full-fill buffer)
     157 * Recording extension setup (disable, on fault time, on  post-fault time)
     158 * Self-diagnostic device state
     159 * Reset and trigger command from PC
     160 * Realtime viewing tools (analog and measure waveform, rms measure, statistic)
     161 * Automatic download scheduler
     162 * Firmware update wizard
     163 * Recording management (Id, Date and time, Length, Trigger condition with user label)
     164 * Easy-To-Use Recording management (single, selected, all recordings)
     165 * Device parameterization file management tools (off-line editing, default file, download file)
     166
     167 * Threshold M1 mode
     168  * Trip threshold - frequency (ANSI 81)
     169 ::Threshold available: 4
     170 ::Range: 45÷55Hz @50Hz rated frequency - 55÷65Hz @60Hz rated frequency
     171 ::Step: 50mHz
     172 ::Enable: included/excluded
     173 ::Periods of measurement: 4÷16
     174 ::Periods selection: software
     175 ::Trip delay time: ?100ms
     176 ::User trip delay time: 0,1÷60s
     177 ::Step: 50ms
     178
     179  * Trip threshold - Frequency rate (ANSI 81R)
     180 ::Threshold available: 4
     181 ::Range: -5Hz/s ÷ +5Hz/s
     182 ::Step: 100mHz/s
     183 ::Logical operator with 81: AND/OR
     184 ::Enable: included/excluded
     185 ::Periods of measurement: 4÷16
     186 ::Periods selection: software
     187 ::Trip delay time: ?250ms
     188 ::User trip delay time: 0,1÷60s
     189 ::Step: 50ms
     190
     191  * Stop threshold - Min/Max voltage
     192 ::Threshold available: 3
     193 ::Range: 0,1÷1,4Vn
     194 ::Step: 0,01Vn
     195 ::Enable: included/excluded
     196 ::Min/Max selection: software
     197 ::Stop delay time: ?50ms
     198 ::User hold time: 0,1÷60s
     199 ::Step: 50ms
     200
     201 * Threshold M2 mode
     202  * Trip threshold - frequency (ANSI 81)
     203 ::Threshold available: 4
     204 ::Range: 45÷55Hz @50Hz rated frequency - 55÷65Hz @60Hz rated frequency
     205 ::Step: 50mHz
     206 ::Enable: included/excluded
     207 ::Periods of measurement: 4÷16
     208 ::Periods selection: software
     209 ::Trip delay time: ?100ms
     210 ::User trip delay time: 0,1÷60s
     211 ::Step: 50ms
     212
     213  * Trip threshold - Frequency rate (ANSI 81R)
     214 ::Threshold available: 4
     215 ::Range: -5Hz/s ÷ +5Hz/s
     216 ::Step: 100mHz/s
     217 ::Logical operator with 81: AND/OR
     218 ::Enable: included/excluded
     219 ::Periods of measurement: 4÷16
     220 ::Periods selection: software
     221 ::Trip delay time: ?250ms
     222 ::User trip delay time: 0,1÷60s
     223 ::Step: 50ms
     224
     225  * Trip threshold - Voltage (ANSI 27/59)
     226 ::Threshold available: 2
     227 ::Range: 0,5÷1Vn
     228 ::Step: 0,01Vn
     229 ::Enable: included/excluded
     230 ::Trip delay time: ?50ms
     231 ::User trip delay time: 0,1÷60s
     232 ::Step: 50ms
     233
     234  * Trip threshold - Voltage rate (ANSI 27R)
     235 ::Threshold available: 2
     236 ::Range: -0,2V/s ÷ +0,2V/s
     237 ::Step: 0,0005Vn/s
     238 ::Logical operator with 27: AND/OR
     239 ::Enable: included/excluded
     240 ::Time of measurement: 80÷200ms
     241 ::Time setup: software
     242 ::Trip delay time: ?120ms
     243 ::User trip delay time: 0,1÷60s
     244 ::Step: 50ms
     245
     246  * Stop threshold - Min/Max voltage
     247 ::Threshold available: 3
     248 ::Range: 0,1÷1,4Vn
     249 ::Step: 0,01Vn
     250 ::Enable: included/excluded
     251 ::Min/Max selection: software
     252 ::Stop delay time: ?50ms
     253 ::User hold time: 0,1÷60s
     254 ::Step: 50ms
     255
     256  * Stop threshold - Voltage imbalance
     257 :::? = max[(V4 – ?), (V8 – ?), (V12 – ?)] / ?
     258 :::with ? = (V4 +  V8 + V12) / 3
     259 ::Threshold available: 1
     260 ::Range: 0,05÷1
     261 ::Step: 0,05
     262 ::Enable: included/excluded
     263 ::Stop delay time: ?50ms
     264 ::User hold time: 0,1÷60s
     265 ::Step: 50ms
     266
     267  * Stop threshold - Maximum frequency difference
     268 :::? = max[(fV4 – fV8), (fV8 – fV12), (fV12 – fV4)]
     269 ::Threshold available: 1
     270 ::Range: 10÷100mHz
     271
     272            Step: 10mHz
     273
     274            Enable: inclusa/esclusa
     275
     276            Stop delay time: ?100ms
     277
     278            User hold time: 0,1÷60s
     279
     280            Step: 50ms
     281
     282
     283
     284Recordings analysis software
     285
     286    LogOscilloEAC
     287
     288    Waveform selection wizard with colours assignment
     289
     290    Automatic selection filters for analog and digital inputs
     291
     292    Decimation value for waveform preview
     293
     294    Dual time cursor
     295
     296    Time and amplitude value in time cursor position
     297
     298    Cursor time difference
     299
     300    Time and amplitude value in mouse cursor position
     301
     302    Windows and vertical zoom tool
     303
     304    Drag-and-Drop capability for waveform overlapping
     305
     306    Signal processing and rms waveform visualization
     307
     308    Signal processing and true rms waveform visualization
     309
     310    Signal processing and spectrum visualization
     311
     312    Spectrum analysis with THD
     313
     314    Waveform export tool for image (JPG, BMP, MetaFile, PCX, PostScript, SVG)
     315
     316    Waveform export tool for Acrobat Reader (pdf)
     317
     318    Samples waveform export tool for Excel
