Changes between Version 13 and Version 14 of TBR/BSP/UC5282
- Timestamp:
- 11/27/10 00:11:23 (13 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
TBR/BSP/UC5282
v13 v14 11 11 |CPU_model = MCF5282 Freescale ColdFire 12 12 |Monitor = uBoot, uMon 13 |Simulator = Well?13 |Simulator = N/A 14 14 |Aliases = No 15 15 |RAM = 8/16 MB SDRAM, 64 KB SRAM 16 16 |NVMEM = 4/8/16 MB Flash, 16 KB EEPROM 17 |Serial = RS232 x 2 UARTs17 |Serial = 2 x RS232 UARTs (one available as TTL also), QSPI with four chip selects 18 18 |NICs = 10/100 Ethernet controller Auto MDI/MDX PHY 19 19 |Other = RoHS and FCC Compliant … … 22 22 23 23 24 The uCdimm ColdFire 5282 is compact, easily integrated embedded hardware module designed to help product developers get their product to market fast. The uCdimm is based on the Motorola ColdFire RISC MCF5282 (64 MHz) and includes 8/16 MB RAM, 4/8/16 MB Flash, Ethernet and CAN bus support making it suitable for various applications in the networking, industrial control and home automation space. This BSP uses the 64K of SRAM for FEC network buffer descriptors to increase performance. 24 The uC5282 is a compact, embedded microprocessor module ideal for networked control and communication applications. The device is available in a standard 144pin soDIMM edge connector format to allow fast integration into products. The module is based on the Freescale® ColdFire® MCF5282 microprocessor and includes all required system memory and physical terminations to enable most applications without the need for external circuitry. The uC5282 features Ethernet, CAN and serial communications systems as well as standard peripheral device connectivity using I2C, QSPI or data/address logic. 25 25 26 [wiki:File:UC5282_Module_Block_Diagram.jpg center]= Board Setup = 26 27
