Changes between Version 13 and Version 14 of TBR/BSP/STM32F105
Ignore:
Timestamp:
Feb 14, 2015, 6:44:13 PM (5 years ago)
Author:
JM Friedt
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TBR/BSP/STM32F105
    v13 v14
    6868For modifying the default UART used by the console, either edit the RTEMS BSP defined in the rtems/c/src/lib/libbsp/arm/stm32f4/configure.ac file and modify {{{RTEMS_BSPOPTS_SET([STM32F4_ENABLE_USART_3],[*],[1])}}} for disabling UART3 (remove [1] and replace with []) and activating UART1 (replace [] with [1]). Alternatively, before
    6969the configuration step, export variables {{{STM32F4_ENABLE_USART_3=""}}} and {{{STM32F4_ENABLE_USART_1="1"}}} for the same
    70 effect. Following this modification, the hello.exe example was run successfuly on a STM32F103RCT microcontroller.
     70effect. Following this modification, the hello.exe example was run successfuly on a STM32F103RCT microcontroller. It is also known
     71'''not''' to run on the STM32F100 value line evaluation board.
    7172
    7273Notice that at the moment, the STM32 support for QEmu does not include (yet) the A/D converters: requesting a sample with a loop testing the conversion completion will hang since the conversion never occurs.
