Changes between Version 5 and Version 6 of TBR/BSP/Rtl22xx
Ignore:
Timestamp:
Apr 29, 2007, 9:07:07 AM (14 years ago)
Author:
Rayx
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TBR/BSP/Rtl22xx
    v5 v6
    22
    33
    4 RTEMS bsp for Philips's ARM processor
     4RTEMS bsp for Philips(NXP)'s ARM7 processor
    55
    6 This BSP is design for Philips's LPC2210/LPC2212/LPC2214/LPC2290/LPC2294 (LPC22xx) serial ARM processor.
     6This BSP is design for Philips's LPC2210/LPC2212/LPC2214/LPC2290/LPC2294 (LPC22xx) serial ARM processor. And it can be ported to LPC21xx ARM MCU.
    77
    88Philip's LPC22xx ARM processor has an ARM7TDMI-S core, and can run at 60MHz. It has an external memory bus, and
    99peripherals like UART, I2C, SPI, ADC and etc. Some of them got on chip flash (256k) and CAN.
    1010
    11 The board used to develop the board is compatible with LPC-E2214/LPC-E2294 boards from http://www.olimex.com.  The board use to develop the BSP has a 256K SRAM( No ROM, program runs in RAM via a JTAG-ICE) and two serial ports.
     11The board used to develop the board is compatible with LPC-E2214/LPC-E2294 boards from http://www.olimex.com.  The board use to develop the BSP has a 512K SRAM( No ROM, program runs in RAM via a JTAG-ICE) and two serial ports. Base address is set to 0x81000000.
    1212
    1313The license and distribution terms for this file may be found in the file LICENSE in this distribution or at
