Changes between Version 6 and Version 7 of TBR/BSP/Mvme5500
- Timestamp:
- 11/27/10 00:11:35 (13 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
TBR/BSP/Mvme5500
v6 v7 41 41 * Single VME slot even when fully configured with two PMC modules or one PMC module and an add-on memory mezzanine 42 42 43 44 43 = Board Setup = 45 44 46 45 47 Additionally, the MVME5500 is user-configurable by setting on-board46 The MVME5500 is user-configurable by setting on-board 48 47 jumpers. Two I/O modes are possible: PMC mode or SBC mode (also 49 48 called 761 or IPMC mode). The SBC mode uses the IPMC712 I/O PMC … … 55 54 IPMC761 PMC in PMC slot 1. Secondary Ethernet is configured to the 56 55 rear. 56 57 57 PMC mode is backwards compatible with the MVME5100 and is 58 58 accomplished by configuring the on-board jumpers. 59 59 60 TBD - RTEMS specific setup instructions 60 61 = Downloading and Executing = 61 62 62 63 63 [http://www.bnl.gov/cad/sns/documents/vme/MVME5500.pdf MVME5500 data sheet] 64 65 [http://npg.dl.ac.uk/documents/edoc249/installation.pdf Installation and use guide] 64 TBD - RTEMS specific download and program execution instructions 66 65 67 66 = Software Support = … … 75 74 extensive diagnostics with new scripting capability. And of course, MotLoad provides a debugger interface similar to 76 75 the time proven "BUG" interface on previous VMEbus boards from Motorola. 77 = Operating Systems and Kernels =78 79 80 WindRiver Systems VxWorks and MontaVista Linux Professional Edition will be available for the MVME5500.81 76 = Libraries = 82 77 … … 98 93 inclusion of software designed to test custom hardware and/or system components. A comprehensive user’s manual 99 94 with software development guidelines is available. 95 = References = 96 97 * [http://www.bnl.gov/cad/sns/documents/vme/MVME5500.pdf MVME5500 data sheet] 98 99 * [http://npg.dl.ac.uk/documents/edoc249/installation.pdf Installation and use guide] 100 100 101 101 102
