Changes between Version 7 and Version 8 of TBR/BSP/Mvme2700
Ignore:
Timestamp:
Jan 27, 2009, 5:26:59 AM (11 years ago)
Author:
Mrippa
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TBR/BSP/Mvme2700
    v7 v8
    4343Tests performed:
    4444
    45 1. I set bit 1 port 0x92 and removed the vmeUniverseBusReset call. I verified that exit did (at least) a board reset. That works.
     451. I set bit 1 port 0x92 and removed the keyboard call. I verified that exit did (at least) a board reset. That works.
    4646
    47472. I also performed an exit with the board SYSCON disabled (J20). I again verified the exit performed a board reset, but it did not affect any peripheral boards.
    51514. I verified pushing the RST on the 2700 that my 5588 fail light transition from OFF->fail, implying this is what I should see during a VME bus reset.
    5252
    53 So I think this is a sufficient test indicating the board reset works independently of resetting the VME bus, which has also been verified with vmeUniverseResetBus().
     53So I think this is a sufficient test indicating the board reset works and is independent of resetting the VME bus, which has also been verified with vmeUniverseResetBus().
    5454
    5555Patch:
