| 39 | |
| 40 | The MVME147S is a double-high VMEmodule and is best utilized in a 32-bit VMEbus system with both P1 and P2 backplanes. The module has high functionality with large onboard shared RAM, serial ports, and Centronics printer port. The module provides a SCSI bus controller with DMA, floating-point coprocessor, tick timer, watchdog timer, and time-of-day clock/calendar with battery backup, 2KB of static RAM with battery backup, four ROM sockets, and A32/D32 VMEbus interface with system controller functions are also provided. The MVME147S can be operated as part of a VMEbus system with other VMEmodules such as RAM modules, CPU modules, graphics modules, and analog I/O modules. |
| 41 | |
| 42 | |
| 43 | The manual can be found at www.ing.iac.es/~docs/external/vme/147s_d3.pdf |
| 44 | = Board Setup = |
| 45 | |
| 46 | |
| 47 | To select the desired configuration and ensure proper operation of the MVME147S module, certain changes may be made before installation. These changes are made through jumper arrangements on the headers. The module has been factory tested and is shipped with factory-installed jumper configurations. The module is operational with the factory-installed jumpers. The module is configured to provide the system functions required for a VMEbus system. It is necessary to make changes in the jumper arrangements for the following conditions: |
| 48 | |
| 49 | System controller select (J3) |
| 50 | Factory use only (J5, J6) |
| 51 | ROM configuration select (J1, J2) |
| 52 | Serial port 4 clock configuration select (J8, J9) |
| 53 | |
| 54 | |
| 55 | See manual for further information |
| 56 | = Downloading and Executing = |
| 57 | |
| 58 | |
| 59 | There are various ways to enter a user program into system |
| 60 | memory for execution. One way is to create the program using the |
| 61 | Memory Modify (MM) command with the assembler/disassembler |
| 62 | option. You enter the program one source line at a time. After each |
| 63 | source line is entered, it is assembled and the object code loads into |
| 64 | memory. Refer to the MVME147 BUG 147Bug Debugging Package |
| 65 | User's Manual for complete details of the 147Bug Assembler/ |
| 66 | Disassembler. |
| 67 | Another way to enter a program is to download an object file from |
| 68 | a host system. The program must be in S-record format (described |
| 69 | in the MVME147BUG 147Bug Debugging Package User's Manual) and |
| 70 | may have been assembled or compiled on the host system. |
| 71 | Alternately, the program may have been previously created using |
| 72 | the 147Bug MM command as outlined above and stored to the host |
| 73 | using the Dump (DU) command. A communication link must exist |
| 74 | between the host system and the MVME147. The file is downloaded |
| 75 | from the host to MVME147 memory by the Load (LO) command. |
| 76 | = Debugging = |
| 77 | |
| 78 | |
| 79 | MVME147Bug package. Facilities are available for loading and executing |
| 80 | user programs under complete operator control for system |
| 81 | evaluation. See manual for further information |
| 82 | |
| 83 | = References = |
| 84 | |
| 85 | |
| 86 | * www.ing.iac.es/~docs/external/vme/147s_d3.pdf |
| 87 | |
| 88 | {{Navbox_BSPs}} |
