| 1 | = Milkymist = |
| 2 | |
| 3 | |
| 4 | This is a tutorial on how to build and run RTEMS on the Milkymist One board. |
| 5 | |
| 6 | Questions about the Milkymist BSP for RTEMS ? |
| 7 | |
| 8 | GO ask them on irc.freenode.net on #milkymist |
| 9 | |
| 10 | I (Yann Sionneau aka Fallenou on IRC) or lekernel or mwalle will try to answer :) |
| 11 | = Build an RTEMS toolchain = |
| 12 | |
| 13 | |
| 14 | * You can follow the following tutorial on RTEMS's wiki : [http://www.rtems.org/wiki/index.php/Building_the_RTEMS_toolset_on_Ubuntu http://www.rtems.org/wiki/index.php/Building_the_RTEMS_toolset_on_Ubuntu] |
| 15 | * If you are under ubuntu 10.04 i guess you do not need to compile autoconf and automake from sources, the version provided by ubuntu is recent enough. |
| 16 | * So basically doing the following should be ok : |
| 17 | |
| 18 | # aptitude install m4 patch build-essential texinfo cvs libncurses5-dev libgmp3-dev libmpfr-dev libmpc-dev autoconf autotools-dev |
| 19 | |
| 20 | * Then download the sources of gcc-core, newlib, gdb, g++ and binutils and the corresponding patches (.diff files) on this page : [http://ftp.rtems.org/ftp/pub/rtems/SOURCES/4.11/ http://ftp.rtems.org/ftp/pub/rtems/SOURCES/4.11/] |
| 21 | |
| 22 | * Follow the steps of the "Phase 2." of RTEMS' wiki page to configure and build the toolchain. |
| 23 | * Do not forget that you are building the toolchain for RTEMS 4.11 and not 4.9 |
| 24 | * Your target is not powerpc-rtems4.9 but lm32-rtems4.11 |
| 25 | * Do not forget to apply the patches, and follow the build order indicated in the RTEMS wiki, you must build gcc against newlib. |
| 26 | = Checkout the RTEMS port to Milkymist = |
| 27 | |
| 28 | |
| 29 | Yann Sionneau developped as part of a Google Summer of Code (2010) a Board Support Package (BSP) for the Milkymist One board which makes it possible to run RTEMS on Milkymist One board using Milkymist SoC ! |
| 30 | |
| 31 | The BSP is available on his git repository hosted on github : [http://github.com/fallen/rtems-milkymist http://github.com/fallen/rtems-milkymist] |
| 32 | |
| 33 | |
| 34 | * Be sure to have the git tool installed in your computer |
| 35 | |
| 36 | * Git can be installed this way under debian (and ubuntu) : |
| 37 | |
| 38 | # aptitude update && aptitude install git-core |
| 39 | |
| 40 | * Clone the git repository of the RTEMS port to Milkymist : |
| 41 | |
| 42 | ~$ git clone git://github.com/fallen/rtems-milkymist.git |
| 43 | = Building RTEMS port to Milkymist = |
| 44 | |
| 45 | |
| 46 | * Go to the root of the source tree : |
| 47 | |
| 48 | ~$ cd rtems |
| 49 | |
| 50 | * Put your lm32-rtems4.11 toolchain in your PATH environment variable : |
| 51 | |
| 52 | ~$ export PATH=/opt/rtems-4.11/bin:$PATH |
| 53 | |
| 54 | * Run bootstrap (to generate the Makefile.in and other autotools related files) : |
| 55 | |
| 56 | ~/rtems$ ./bootstrap |
| 57 | |
| 58 | * Go make some coffee, drink the coffee, refill your mug and drink again ... ok you're done ! |
| 59 | |
| 60 | * Create a directory to host the binaries you're going to create : |
| 61 | |
| 62 | $ cd ~/ |
| 63 | ~$ mkdir bsp-milkymist |
| 64 | |
| 65 | * Do configure and make ! |
| 66 | |
| 67 | ~$ cd bsp-milkymist |
| 68 | ~/bsp-milkymist$ ../rtems/configure --target=lm32-rtems4.11 --enable-rtemsbsp=milkymist \ |
| 69 | --enable-testsuites=samples --enable-posix --disable-itron --enable-networking --disable-multiprocessing |
| 70 | ~/bsp-milkymist$ make all |
| 71 | ~/bsp-milkymist$ sudo -s (or simply su in debian) |
| 72 | ~/bsp-milkymist# export PATH=$PATH:/opt/rtems-4.11/bin |
| 73 | ~/bsp-milkymist# make install |
| 74 | |
| 75 | * You can go drink some more coffee ! |
| 76 | = Run the sample applications on the Milkymist One board = |
| 77 | |
| 78 | |
| 79 | Go to the bsp-milkymist directory, say we wanna test the "hello world" sample : |
| 80 | |
| 81 | ~$ cd bsp-milkymist/ |
| 82 | ~/bsp-milkymist$ cd lm32-rtems4.11/c/milkymist/testsuites/samples/hello |
| 83 | ~/bsp-milkymist/lm32-rtems4.11/c/milkymist/testsuites/samples/hello$ lm32-rtems4.11-objcopy -Obinary hello.exe |
| 84 | |
| 85 | * Plug your RS-232 serial usb wire to your computer and to the Serial port of the board |
| 86 | |
| 87 | * Install flterm (the software for uploading the application into on-board Flash through RS-232 line) : |
| 88 | * This software is available in milkymist's debian repository (works for ubuntu too), just do : |
| 89 | |
| 90 | # echo "deb http://www.milkymist.org/debian ./" >> /etc/apt/sources.list |
| 91 | # aptitude update && aptitude install flterm |
| 92 | |
| 93 | * Power-on the board |
| 94 | |
| 95 | * Then upload the sample application hello.exe to the board : |
| 96 | |
| 97 | ~/bsp-milkymist/lm32-rtems4.11/c/milkymist/testsuites/samples/hello$ flterm --kernel hello.exe --port /dev/ttyUSB0 |
| 98 | |
| 99 | * If nothing is uploading then push two push-buttons, then push the third and release it, then release the two others. (in this order) |
| 100 | = Run Genode-FX on the Milkymist One board = |
| 101 | |
| 102 | |
| 103 | Genode-FX is a graphic toolkit for embedded systems like FPGA based ones, just like Milkymist :) |
| 104 | |
| 105 | * Checkout the git repository of the Genode-FX port |
| 106 | |
| 107 | ~$ git clone git://github.com/lekernel/genode-fx.git |
| 108 | |
| 109 | * Compile Genode-FX against RTEMS kernel |
| 110 | |
| 111 | ~$ cd genode-fx/dope-embedded |
| 112 | ~/genode-fx/dope-embedded$ RTEMS_MAKEFILE_PATH=/opt/rtems-4.11/lm32-rtems4.11/milkymist make milkymist |
| 113 | |
| 114 | * Put the binary into the correct format to be sent to the board |
| 115 | |
| 116 | ~/genode-fx/dope-embedded$ cd test/milkymist |
| 117 | ~/genode-fx/dope-embedded/test/milkymist$ lm32-rtems4.11-objcopy -Obinary dopetest |
| 118 | |
| 119 | * Upload the binary (dopetest) to the board, using the procedure as described in the previous section named "Run the sample applications on the Milkymist One board" |
| 120 | = Another example of application built against RTEMS : tftpclient = |
| 121 | |
| 122 | |
| 123 | tftpclient is an example application that you can build against RTEMS kernel. |
| 124 | |
| 125 | This application downloads a file from a tftp server and prints it's content to the serial console. |
| 126 | |
| 127 | This application has been added to the network-demos provided by RTEMS as a CVS module, it is available on Yann's github |
| 128 | |
| 129 | * Checkout the github repo of network-demos : |
| 130 | |
| 131 | ~$ git clone git://github.com/fallen/network-demos.git |
| 132 | |
| 133 | * Compile the applications against RTEMS kernel : |
| 134 | |
| 135 | ~$ cd network-demos |
| 136 | ~$ export PATH=$PATH:/opt/rtems-4.11/bin |
| 137 | ~/network-demos$ RTEMS_MAKEFILE_PATH=/opt/rtems-4.11/lm32-rtems4.11/milkymist make all |
| 138 | |
| 139 | * Install a tftpd server on your computer : |
| 140 | |
| 141 | ~# aptitude install tftpd |
| 142 | |
| 143 | * Configure it : |
| 144 | |
| 145 | ~# touch /etc/xinetd.d/tftp |
| 146 | ~# vim /etc/xinetd.d/tftp |
| 147 | |
| 148 | * Put this in the file : |
| 149 | |
| 150 | service tftp |
| 151 | { |
| 152 | protocol = udp |
| 153 | port = 69 |
| 154 | socket_type = dgram |
| 155 | wait = yes |
| 156 | user = nobody |
| 157 | server = /usr/sbin/in.tftpd |
| 158 | server_args = /tftpboot |
| 159 | disable = no |
| 160 | } |
| 161 | |
| 162 | * Create the tftp root directory and put your file in it |
| 163 | |
| 164 | ~# mkdir /tftpboot |
| 165 | ~# cp yourfile /tftpboot/sample.data |
| 166 | ~# chown -R nobody /tftpboot |
| 167 | ~# chmod -R 777 /tftpboot |
| 168 | |
| 169 | * Restart xinetd : |
| 170 | |
| 171 | ~# /etc/init.d/xinetd restart |
| 172 | |
| 173 | * Upload the file to the board using the procedure described previously : |
| 174 | |
| 175 | ~/network-demos$ cd tftpclient/o-optimize |
| 176 | ~/network-demos/tftpclient/o-optimize$ lm32-rtems4.11-objcopy -Obinary tftpclient.exe |
| 177 | ~/network-demos/tftpclient/o-optimize$ flterm --kernel tftpclient.exe --port /dev/ttyUSB0 |
| 178 | |
| 179 | * While uploading the binary into the board, set-up your network configuration : |
| 180 | |
| 181 | ~# ifconfig eth0 192.168.101.254 netmask 255.255.255.0 |
| 182 | |
| 183 | You can change the ip address taken by the board, the ip address of the gateway it's supposed to use, the ip address of the tftp server, the port of the tftp server and the name of the file tftpclient is supposed to download and print in the network-demos/networkconfig.h and directly into network-demos/tftpclient/init.c |
