Changes between Version 8 and Version 9 of TBR/BSP/Mcf5235
Ignore:
Timestamp:
11/16/06 21:01:44 (17 years ago)
Author:
WorthBurruss
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TBR/BSP/Mcf5235
    v8 v9
    66The MCF5235EVB is a Motorola evaluation board that is based on the Coldfire MCF5235 32-bit processor. The board includes 32 Mbytes of SDRAM, 2Mbytes of flash, the MCF5235 processor with a max core frequency of 150MHz, Ethernet support, and CAN bus support.
    77
    8 This BSP has also been tested work with the newer Freescale M5235BCC evaluation board.
     8This BSP has also been tested to work with the newer Freescale M5235BCC evaluation board.
     9
     10This BSP has also been tested to work with the Axiom Manufacturing CMM-5235 Board
    911
    1012The BSP provides support to run applications from both RAM when debugging and from Flash when the application is complete.  The RAM mode, which relies on either the dBug monitor or GDB configuration of the boards hardware, is the default.  An alternate linker script is available for stand alone operation from Flash by adding the following line to the applications Makefile:
