Changes between Initial Version and Version 1 of TBR/BSP/Mcf52235
Ignore:
Timestamp:
06/13/08 02:54:07 (16 years ago)
Author:
Mriek
Comment:
New page: This BSP was heavily based on the mcf5235 BSP. The MCF52235EVB is a Motorola evaluation board that is based on the Coldfire MCF52235 32-bit micro-controller. The uC has 32K ram, 256k fla...
Legend:
Unmodified
Added
Removed
Modified
  • TBR/BSP/Mcf52235
    v1 v1
     1= Mcf52235 =
     2
     3
     4This BSP was heavily based on the mcf5235 BSP.
     5
     6The MCF52235EVB is a Motorola evaluation board that is based on the Coldfire MCF52235 32-bit micro-controller.  The uC has 32K ram, 256k flash with a core frequency of 60MHz.  It has onboard FEC, 3 uarts, CAN bus, QSPI, I2C etc.
     7
     8Because this uC ahs a very small SRAM footprint, this BSP will only run from flash and currently does not compile (link fails) with some RTEMS samples and tests.  Work is being done (both with tiny RTEMS, and on this BSP) to reduce the smallest application SRAM footprint to allow this BSP to eventually work with LWIP (well, that is the goal at least).
     9
     10This BSP should also work with the Freescale 52233 Demo board, but has not yet been tested.
