- Timestamp:
11/29/10 21:26:24 (14 years ago)
- Author:
Roskotheslayer
- Comment:
/* Board Setup */
Legend:
- Unmodified
- Added
- Removed
- Modified
v29
v30
36 | 36 | * Using HAL Package |
37 | 37 | |
38 | | * The JMR3904 HAL package should be used when targeting the |
| 38 | *The JMR3904 HAL package should be used when targeting the |
39 | 39 | actual hardware. The same package can also be used when |
40 | 40 | running on the full simulator, since this provides an |
43 | 43 | `target sim --board=jmr3904' should be used from inside gdb. |
44 | 44 | |
45 | | * The jmr3904 target provides the packages needed to run |
| 45 | *The jmr3904 target provides the packages needed to run |
46 | 46 | eCos on a Toshiba JMR-TX3904 board. This target can also |
47 | 47 | be used when running in the full simulator, since the simulator provides an |
