Changes between Version 22 and Version 23 of TBR/BSP/Jmr3904
- Timestamp:
- 11/29/10 20:32:31 (13 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
TBR/BSP/Jmr3904
v22 v23 35 35 `target sim --board=jmr3904' should be used from inside gdb. 36 36 37 The jmr3904 target provides the packages needed to run 38 eCos on a Toshiba JMR-TX3904 board. This target can also 39 be used when running in the full simulator, since the simulator provides an 40 accurate simulation of the hardware including I/O devices. 41 To use the simulator in this mode the command 42 `target sim --board=jmr3904' should be used from inside gdb. 37 43 = Using The BSP = 38 44
