Changes between Version 19 and Version 20 of TBR/BSP/Genmcf548x
Ignore:
Timestamp:
11/10/18 19:29:31 (5 years ago)
Author:
Kathryn
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • TBR/BSP/Genmcf548x
    v19 v20
    22
    33
    4 {{Infobox BSP
    5 |BSP_name     = MCF548x
    6 |Manufacturer = ColdFire
    8 |caption      = PhyCORE-MCF548x
    9 |Board_URL    = http://pdf1.alldatasheet.com/datasheet-pdf/view/184676/FREESCALE/mcf5485.html
    10 |Architecture = Freescale Coldfire
    11 |CPU_model    = MCF548x
    12 |Monitor      = uBoot, uMon
    13 |Simulator    = N/A
    14 |Aliases      = No
    15 |RAM          = DDR SDRAM: 64 to 128 MB.
    16 |NVMEM        = 32 MB Flash
    17 |Serial       = Two RS-232 Serial Ports & Two TTL Serial Ports.
    18 |NICs         = one. NIC part name.
    19 }}
     4= Infobox BSP =
     5||'''BSP_name'''     ||MCF548x||
     6||'''Manufacturer''' ||ColdFire||
     7||'''image'''        ||PhyCORE-MCF548x_Web_03.jpg||
     8||'''caption'''      ||PhyCORE-MCF548x||
     9||'''Board_URL'''    ||http://pdf1.alldatasheet.com/datasheet-pdf/view/184676/FREESCALE/mcf5485.html||
     10||'''Architecture''' ||Freescale Coldfire||
     11||'''CPU_model'''    ||MCF548x||
     12||'''Monitor'''      ||uBoot, uMon||
     13||'''Simulator'''    ||N/A||
     14||'''Aliases'''      ||No||
     15||'''RAM'''          ||DDR SDRAM: 64 to 128 MB. ||
     16||'''NVMEM'''        ||32 MB Flash||
     17||'''Serial'''       ||Two RS-232 Serial Ports & Two TTL Serial Ports.||
     18||'''NICs'''         ||one. NIC part name.||
     19
    2020= Overview =
    2121
    2525                                        <div class="padMe5"></div>
    2626                                          <ul>
    27 <li>ColdM5485CFE Fire Engine Module (SOM-ETX), including:
     27* ColdM5485CFE Fire Engine Module (SOM-ETX), including:
     28  * MCF5485CZP200 Processor
     29  * 64MB DDR-SDRAM
     30  * 16MB Flash
     31  * Graphics Controller
     32  * USB Host Controller
    2833
    29 <ul>
    30 <li>MCF5485CZP200 Processor</li>
     34* LCD Display Connector - includes integrated LCD, touch, and backlight connector for Display Kits
    3135
    32 <li>64MB DDR-SDRAM</li>
     36* DVI Connector
    3337
    34 <li>16MB Flash</li>
     38* Two 10/100 RJ45 Ethernet connectors
    3539
    36 <li>Graphics Controller</li>
     40* Two PCI slots (32 bit, 33 or 66MHz, 3.3V)
    3741
    38 <li>USB Host Controller</li>
    39 </ul>
    40 </li>
     42* Serial Ports
     43  * Two RS-232 Serial Ports
     44  * Two TTL Serial Ports
    4145
    42 <li>LCD Display Connector - includes integrated LCD, touch, and backlight connector for Display Kits</li>
     46* Two CAN 2.0B Interfaces
    4347
    44 <li>DVI Connector</li>
     48* USB 2.0
     49  * One High Speed Device (on Fire Engine)
     50  * Four High Speed Host ports
    4551
    46 <li>Two 10/100 RJ45 Ethernet connectors</li>
     52* SPI
    4753
    48 <li>Two PCI slots (32 bit, 33 or 66MHz, 3.3V)</li>
     54* RTC
    4955
    50 <li>Serial Ports
     56* Mechanical:&nbsp; Mini-ITX
     57  * 6.7" (170mm) long by 6.7" (170mm) wide by 1.3" (33mm) high
    5158
    52 <ul>
    53 <li>Two RS-232 Serial Ports</li>
     59* Cables
     60  * Serial Cable (null modem)
     61  * Universal 5V Power Supply
     62  * BDM Cable
     63  * Ethernet Crossover
     64  * USB Function Cable
    5465
    55 <li>Two TTL Serial Ports</li>
    56 </ul>
     66* Modules offered in industrial temp range: -40 to 85C
    5767
    58 </li>
    5968
    60 <li>Two CAN 2.0B Interfaces</li>
    61
    62 <li>USB 2.0
    63
    64 <ul>
    65 <li>One High Speed Device (on Fire Engine)</li>
    66
    67 <li>Four High Speed Host ports</li>
    68 </ul>
    69 </li>
    70
    71 <li>SPI</li>
    72
    73 <li>RTC</li>
    74
    75 <li>Mechanical:&nbsp; Mini-ITX
    76
    77 <ul>
    78 <li>6.7" (170mm) long by 6.7" (170mm) wide by 1.3" (33mm) high</li>
    79 </ul>
    80 </li>
    81
    82 <li>Cables
    83
    84 <ul>
    85 <li>Serial Cable (null modem)</li>
    86
    87 <li>Universal 5V Power Supply</li>
    88
    89 <li>BDM Cable</li>
    90
    91 <li>Ethernet Crossover</li>
    92
    93 <li>USB Function Cable</li>
    94 </ul>
    95 </li>
    96
    97 <li>Modules offered in industrial temp range: -40 to 85C</li>
    98
    99 </ul>
    100
    101 <p><strong>Fire Engines</strong></p>
     69<p>'''Fire Engines'''</p>
    10270
    10371<p>The M5485EVBGHS development kit contains a module, called a Fire Engine, which can be purchased from Freescale in production volumes.&nbsp; <font face="Arial">The MCF5485 Fire Engine is a complete system on module (in SOM-ETX format)&nbsp;offering essential features for industrial and embedded networking applications.&nbsp; The use of the Mini-ITX baseboard included in the M5485EVB, or a custom peripheral board generated by the customer makes the Fire Engine the ideal foundation for&nbsp;developing embedded computing products. The Fire Engine provides a common reference pin-out on its expansion connectors, which enables customers to easily scale to next generation microprocessor Fire Engines when new functionality or performance is required.</font></p>
    157125
    158126
    159 {{Test Report
    160 |Version = CVS head
    161 |Date    = DATE
    162 |User    = [wiki:User:WhoTestedThis User:WhoTestedThis]
    163 |Report  = reports that something happened.
    164 }}
     127|||| '''Test Report''' ||
     128||'''Version''' ||CVS head||
     129||'''Date'''    ||DATE||
     130||'''User'''    ||[wiki:User:WhoTestedThis User:WhoTestedThis]||
     131||'''Report'''  ||reports that something happened. ||
     132
    165133= References =
    166134
