16 | | |Board_URL = http:/manufacturer.com/ExampleBoard |
17 | | |Architecture = Architecture |
18 | | |CPU_model = Model name |
19 | | |Monitor = uBoot, uMon |
20 | | |Simulator = Yes. [wiki:Developer/Simulators/SkyEye Skyeye] |
21 | | |Aliases = Any RTEMS BSP Aliases? |
22 | | |RAM = XXX MB |
23 | | |NVMEM = 32 MB Flash, 16 KB EEPROM |
24 | | |Serial = one. UART part name. |
25 | | |NICs = one. NIC part name. |
26 | | |Other = anything else you need to say |
| 16 | |Board_URL = http://www.cogcomp.com/csb_csb637.htm |
| 17 | |Architecture = ARM9 - arm920t |
| 18 | |CPU_model = Atmel AT91RM9200 |
| 19 | |Monitor = Micromonitor - uMon |
| 20 | |Simulator = No |
| 21 | |Aliases = No |
| 22 | |RAM = 64Mbyte 32-Bit SDRAM (external) |
| 23 | |NVMEM = 8Mbyte 16-Bit StrataFLASH |
| 24 | |Serial = 4 general purpose (Driver), 1 debug (Driver) |
| 25 | |NICs = 1 integrated 10/100 Ethernet |
| 26 | |Other = - |
33 | | Describe the board here. Include links to manuals, brochures, etc. |
| 34 | External memory |
| 35 | 16MB SDRAM 64MB SDRAM |
| 36 | |
| 37 | Video buffer: |
| 38 | 1MB 8MB |
| 39 | |
| 40 | Video driver: |
| 41 | S1D13706 S1D13506 |
| 42 | |
| 43 | PHY Layer: |
| 44 | LXT971ALC BCM5221 |
| 45 | Driver for 4 USARTs in polled mode |
| 46 | Driver for LCD and console mirror |
| 47 | Driver for uMon |
| 48 | ?? Some GPIO or interrupts moved arround. |
| 49 | |
| 50 | The csb637 BSP was developed and tested using the KIT637 V6 Development Kit from Cogent. This Development Kit is composed by the CSB637 Single Board Computer, the CSB937 Main Board for the Target, Optrex LCD (T-51750AA, 640x480), LCD Inverter(xx) and Touchscreen (not supported in this BSP). |
| 51 | The IDE and USB (host and device) interfaces are also not supported. The SD and Compact Flash card drivers are still under development. |
| 52 | This BSP were added in the RTEMS 4.10 version. |
| 53 | Cogent CSB637 product page is http://www.cogcomp.com/csb_csb637.htm |
| 54 | Atmel AT91RM9200 product page is http://www.atmel.com/dyn/products/product_card.asp?part_id=2983 |
| 55 | uMon page is http://www.umonfw.com/ |
41 | | Describe the download procedure. |
| 67 | To download RTEMS executables in the KIT637 V6 Development Board using TFTP firstly the [rtems_executable_file.exe] must be transformed from .exe to .bin. Run the following command in the environment where RTEMS is installed and in the PATH where the [rtems_executable_file.exe] is stored: |
| 68 | arm-rtems4.10-objcopy -O binary [rtems_executable_file.exe] [rtems_binary_file.bin] |
| 69 | After the change to [rtems_binary_file.bin] run the following commands in the terminal window: |
| 70 | tftp xxx.xxx.xxx.xxx get /PATH/[rtems_binary_file].bin 0x20100000 |
| 71 | --> xxx.xxx.xxx.xxx is the IP set |
| 72 | --> PATH is the complete path of the TFTPServer where the file [rtems_binary_file.bin] is stored |
| 73 | call 0x20100000 |
| 74 | |
| 75 | The execution should start from the external SDRAM (0x20100000 address). |
