Changes between Version 88 and Version 89 of TBR/BSP/AVRTest
Ignore:
Timestamp:
Feb 2, 2013, 2:23:44 AM (7 years ago)
Author:
C Rempel
Comment:
/* Building AVRTest (Simulator) using GCC Testing Toolchain */
Legend:
Unmodified
Added
Removed
Modified
  • TBR/BSP/AVRTest
    v88 v89
    172172 set_board_info ldflags "/home/georg/source/avrtest/exit-atmega128.o -Wl,-u,vfprintf -lprintf_flt -Wl,-Tbss=0x802000,--defsym=__heap_end=0x80ffff ..
    173173
    174 Change back to the build directory and run gcc-tests
     174Change back to the build directory and run gcc-tests, the Ada tests will fail until AVR-Ada is installed, so pass the '''--keep-going''' (-k) flag to gcc
    175175 '''~/gcc-testing/avrtest$''' cd ~/gcc-testing/build-avr-gcc
    176  '''~/gcc-testing/build-avr-gcc$''' make check RUNTESTFLAGS="--target_board=atmega128-sim" avr.exp > test.log
     176 '''~/gcc-testing/build-avr-gcc$''' make -k check RUNTESTFLAGS="--target_board=atmega128-sim" avr.exp > test.log
    177177
    178178The AVR-GCC tester will probably want to open a second terminal to build avr-gnat while avr-gcc is being tested...
