Changes between Version 103 and Version 104 of TBR/BSP/AVRTest
Ignore:
Timestamp:
Feb 3, 2013, 10:54:11 PM (7 years ago)
Author:
C Rempel
Comment:
/* AVR-LibC Development Branch */
Legend:
Unmodified
Added
Removed
Modified
  • TBR/BSP/AVRTest
    v103 v104
    228228 *  to submit [http://distribute.atmel.no/tools/opensource/Atmel-AVR-Toolchain-3.4.1/avr/avr-patches.tar.gz patches] to the [http://www.sourceware.org/bugzilla/ bugzilla] at Sourceware to lower the learning curve for getting AVR-Ada up-and-running...
    229229 *  to enhance the build system for the AVR so it can be made with make instead of make -k, so compiler problems that are really problems can be identified
    230 =  AVR-LibC Development Branch  =
     230=  AVR-LibC/AVR-Ada Development Branch  =
    231231
    232232'''Note: '''stub.
    238238
    239239If building with Ada support
     240 *  In Ubuntu is was necessary to append the three lines below to ~/.bashrc [http://stackoverflow.com/questions/7412548/gnu-stubs-32-h-no-such-file-or-directory]
     241        ~/.bashrc
     242 export LIBRARY_PATH=/usr/lib/$(gcc -print-multiarch)
     243 export C_INCLUDE_PATH=/usr/include/$(gcc -print-multiarch)
     244 export CPLUS_INCLUDE_PATH=/usr/include/$(gcc -print-multiarch)
     245
    240246 '''~/$''' mkdir AVR_ADA && cd AVR_ADA # make a directory for building the AVR Ada toolset
    241247 '''~/AVR_ADA$''' wget http://sourceforge.net/projects/avr-ada/files/avr-ada/Source\ Dist/avr-ada-1.2.1.tar.bz2 # get the source
