Changes between Version 11 and Version 12 of SOCIS/2017
Ignore:
Timestamp:
Aug 16, 2017, 2:52:26 PM (2 years ago)
Author:
Mikail Yayla
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • SOCIS/2017
    v11 v12
    103103  * After I have solved the problem with the pattern iteration, I will start to implement a soft-error technique that also follows the pattern, but uses error detection to execute the correction versions (SDR).
    104104
     105* August 16
     106 * What was done:
     107  * This week I finished implementing the first fault tolerance technique (of four) and fixed the pattern iterator. Tasks can now follow the pattern to execute the corresponding task version. I also completed the implementation of the algorithms which generate R- or E-patterns, which guarantee that (m,k)-reqiurements hold.
     108 * Current issues
     109   * How to cleverly implement fault injection and error detection, I am collecting ideas and will meet with my mentor Kuan to discuss the implementation.
     110 * Plans for the next week:
     111  * Next week, I will work on a fault injection and fault detection mechanism, so that I can implement the fault tolerance technique which uses fault detection.
     112
    105113
    106114= Final Report (RTEMS Fault Tolerance) =
