Changes between Version 7 and Version 8 of SOCIS/2016
Ignore:
Timestamp:
Jul 20, 2016, 3:07:34 PM (5 years ago)
Author:
Saeed Ehteshamifar
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • SOCIS/2016
    v7 v8
    4747* Jul 06: Prepared and tested Vagrant scripts to setup/build rtems and setup/build slingshot. Started changing test suite template to include a label that is moved to the next test case whenever a test case crashes.
    4848* Jul 13: Added parsing output of test cases execution. Added support to tolerate crashes of test cases by proceeding to the next test case and re-making the test suite. This method is NOT scalable since it involves re-making the test suite. Going to execute test cases dynamically via RTEMS libdl to cope with this issue.
    49 * Jul 20: Executed a test suite with more than 600 test cases to test the slingshot's function in auto-skipping crashed test cases and also find out some faults that lead to failures. Read RTEMS 4.5.0 Evaluation Report (by Critical Software) to see how they cope with crash and also have a basis to compare slingshot with. Going to update Vagrant scripts, build instructions, change the test suite template, and modify slingshot to dynamically run test cases.
     49* Jul 20: Updated the blog. Executed a test suite with more than 600 test cases to test the slingshot's function in auto-skipping crashed test cases and also find out some faults that lead to failures. Read RTEMS 4.5.0 Evaluation Report (by Critical Software) to see how they cope with crash and also have a basis to compare slingshot with. Going to update Vagrant scripts, build instructions, change the test suite template, and modify slingshot to dynamically run test cases.
